Rough-in Measurements For Bathroom Sink
I need to install a sink in a bathroom remodel. What is the standard rough in measurements for the watersupply and drain? I need to get the wall closed in. Thanks. I've done plumbing before but don't do it enough to remember all of the dimensions.
Trade: Consultant
Re: Rough-in Measurements For Bathroom Sink
Depends on the sink- is it a pedestal or a countertop sink? If it's a pedestal, you'll need to get the dimensions from the manufacturer (they all post their roughin dimensions on line now). If it's a drop-in, you'll need to figure out the top height, then drop your roughs low enough to get below the bottom of the sink, allow for the trap, etc.- again, having the manufacturer's sheet would help greatly.
Bob |
Chief Toilet Mover
Trade: Bathroom Remodeling
Here you go
Trade: Plumbing Contractor
Typical self rim lav on a 32" +/- counter top rough the waste at 21" for a residential with a pop up drain, 23" for a commercial with grid strainer.
I rough the waters typically 3" off center and 2-3" higher than the drain. Or on a commercial i rough both to the wall side of the lav, leaves more room for ada accessibility. |
| Need help! Hole for sink cut too big! | sage | Plumbing | 32 | 02-05-2009 03:10 PM |
| Residential Rough in Estimate Central Florida | Surface Tension | Plumbing | 7 | 06-17-2007 12:23 AM |
| Relocating pipes for pedestal sink | jerome8283 | Plumbing | 44 | 09-19-2006 08:41 PM |
| Bathroom sink question | Robie | Plumbing | 6 | 12-07-2005 10:23 PM |
| sink pump | zbwmy | Plumbing | 1 | 11-11-2005 03:47 PM |
