Trade: building
Root Killer
Is there a product that is safe for the environment? I need to use something for roots in my ground water drain that drains from my foundation into a brook. No sewer system involved with this - totally fresh ground water into freshwater brook.
Repair/Remodeling Tech.
Trade: Repair and Remodeling Services
Re: Root Killer
I've heard of people using rock salt (like for ice) to kill roots in drainage pipe...dunno if it works at all, but I've heard of it.
Jim P. |
Pro Plumber
Trade: Plumber
Re: Root Killer
Copper Sulfate
Found at most plumbing hardware stores. |
Trade: plumber
Re: Root Killer
Is copper sulfate detrimental to the brook? I have never heard of the salt idea, but I like it if it works. I have some extra salt around here. Or..........salt water is everywhere around Fl.
Pro Plumber
Trade: Plumber
Re: Root Killer
It maynot be safe, according to the data I've been reading up on.
Trade: plumber
Re: Root Killer
If it kills roots it probably would also kill algae and moss or whatever grows in the stream.
Trade: Contractor/ Business Owner/ Entrepreneur
Re: Root Killer |
Trade: plumber
Re: Root Killer |
Pro serviceman
Trade: Plumbing service/repair
Re: Root Killer
We have been a Root-X dealer (foaming root killer) for almost a year. I'll dig up the technical data and post it. Supposed to be much safer to the environment than copper sulfate. I must admit though, any chemical that kills something can't be totally safe for everything else
Re: Root Killer
Salt might be your best bet. Even here in FL there is a limit as to how much salt a plant can take. If you're away from the coast, it shouldn't take much.
Trade: building
Re: Root Killer
I have pine tree (or hemlock) roots taking over the orangeberg pipe I believe. There is about a 100' run from the house footers to the stream. I was thinking of putting whatever is best down the closest floor drain in the basement to attempt killing the roots. I can actually put a bucket at the end of the pipe to catch the runoff before it gets in the stream. The RR guys snaked out most of it, but, said they most likely will come back - although it took 40 years for this to happen and cause the ground water backup into the basement drains. Maybe doing it on a really rainy day will help if anything gets out - at least it will be really diluted by then. ???? I'm interested in finding out more about this RootX product.
| I finally figured out what is the root of all evil in the painting industry | Mike Finley | Painting & Finish Work | 26 | 06-30-2007 08:13 PM |
| Why are root canals so expensive? | ron schenker | Off Topic (Non Trade) | 34 | 10-23-2006 08:32 PM |
| A Time Killer | ProWallGuy | Off Topic (Non Trade) | 14 | 06-20-2006 11:08 AM |
| new landscaping and tree root concerns | rservices | Landscaping | 0 | 05-16-2006 08:14 AM |
| Tree root problem | steveprichard | Landscaping | 0 | 02-14-2006 04:46 PM |
