Ridged Copper Supply To Dishwasher ?
On a service call last night I found a ridged 1/2" copper supply line going directly to the dishwasher. Seems like a pretty dumb idea to me. Vibrations from the machine could loosen pipe fittings. Not to mention that it is a pita to disconnect and reconnect. Anybody see this before ? I have to go back to the house for some other work, and I'm gonna cut off some of the ridged line and put a flex line to the dishwasher.
Trade: Finish Carpentry
Re: Ridged Copper Supply To Dishwasher ? Home owner install
Until about 8 or 10 years ago
all I saw was either ridged or soft copper water lines.
Trade: Professional Handyman
Seen a few.
They usually get cut out and a SS braided line installed.
The cat box ain't gonna clean itself. |
Trade: Electrical & Carpentry
Almost every dishwasherone I have ever come across in my area are soft copper lines. They set the dishwasher in & then ran the line, so you had to unhook it to pull it out. I always talk the homeowner into installing a new SS dishwasher hose along with new valve under the sink as you usually have to change the connections anyway & usually the valve leaks by.........
Trade: Squirrel Handler
Wait until you run into a dishwasher with a gravity drain, with a galvanized water supply, installed before the last two floors (you have to cut them up in place to get them out) with a finished basement or no basement at all (condo). I have seen tons of them in my days of doing kitchens, I suppose they're not as common these days.
Some people climb mountains. I take out the trash. But we both do it for the same reason. |
Trade: plumbing
Many dishwashers years ago required 1/2" OD minimum so they would get enough volume of water to operate properly. Don't think that is so important anymore or at least I hope so as the flex supplies are very small.
#8 | |
Handle It!
Re: Ridged Copper Supply To Dishwasher ?Quote:
I can not recall, but it is a Number or a Letter. THANKS
#9 | |
Type M?
Handle It!
Trade: Plumbing & Gas Contractor
Both type L and K are available in rolled coils.I'm not sure about type M,I never use the cheap stuff.
| The Following User Says Thank You to threaderman For This Useful Post: | MALCO.New.York (02-05-2009) |
Trade: plumbing
It is refered to as L soft
The Grand Wazoo
Soft copper is also sold as refrigeration tube.
Where are the ridges on the tube that the OP was referring to?
#14 | |
Handle It!
.Well, you know...... He was seeking advise.![]() But it is up to us as Tradesmen, to give PROPER advice concerning Rigid Copper versus the Flexible Stuffs. Do you suppose he fixed it using his Ridgid Tools??? Sooner or later, with enough practice, he will get over that ridge and be well on his way to being a Plumber versus a Plummer!
Something to One may be Nothing to another! Ultimate Wisdom--------- http://www.youtube.com/watch?v=OW-cnizLDEE Last edited by MALCO.New.York; 02-06-2009 at 07:28 PM. |
| Pex vs Copper: Meter to house | stillwater | Plumbing | 51 | 09-17-2008 10:47 PM |
| Copper roofing | Trimac | Roofing | 2 | 08-21-2008 10:42 PM |
| Dishwasher recall - please read and forward on to others | SuperiorBuilt | General Discussion | 2 | 03-17-2008 02:37 PM |
| Painting new gal. gutters copper | DeanV | Painting & Finish Work | 0 | 06-22-2006 09:39 PM |
| Copper vents -vs- plastic/aluminum | shopman | Roofing | 2 | 03-01-2006 08:51 AM |
