Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Plumbing
Old 05-31-2009, 05:57 AM   #1
Trade: Roofer
Replacing a Porcelain Sink
Hey Guys,
I need to replace my bath porcelain sink. The sink is oval and under-mounted to granite. It has clamps, what appears to be silicone as well as wood supports that came with the cabinet. Would simply removing the clamps with a little shimming get the old sink out? Can someone offer some pointers on this as well as installing the new sink? I've read that some use epoxy? I'm not sure if this sink was installed using epoxy but if so how do I remove it?
jerome8283 is offline   Reply With Quote
Old 05-31-2009, 06:59 AM   #2
jarvis design's Avatar
Take the clamps off and pray that epoxy wasn't used!! Then take a knife and cut through the silicone that was probably used to mount the sink.
Note: if epoxy or another form of adhesive was used, you may have to smash the sink then grind off whats left off the granite.
Bathrooms built for Life.
www.JarvisDesignBuild.ca
jarvis design is offline   Reply With Quote
Old 06-06-2009, 09:10 PM   #3
Trade: Roofer
I got it off. It was silicone. Thx
Blue Sink donovplmb01 General Discussion 9 04-17-2009 09:33 PM
Looking for porcelain tile that mimics slate hillblazer Flooring 8 02-28-2009 01:13 PM
switch near sink Jm H Electrical 23 02-27-2009 11:29 AM
Replacing double window w slider 1st time dvlscapes Carpentry 5 09-03-2008 01:26 PM
sink draining to slow nywoodwizard Plumbing 23 11-02-2007 07:50 PM
