Building & Remodeling
Trade: Building & Remodeling Contractor
Replacing Lead Main
One of my rentals has a lead water main that has 2 holes in it near the meter that previous owner patched with scraps of rubber and hose clamps. We have excavated to the curb box to replace with copper. The city will only replace from main to curb box if it is bad so we are stuck with cutting the lead just past the stop and going with copper from there to meter only. Question is how to connect the copper to the lead? Was the lead sweated to the stop originally. City is no help at all.
Thanks for any help. |
Trade: Plumber
Re: Replacing Lead Main
You're going to need a plumber.
The city won't turn the water on without a licensed plumber & permits for the work. |
Moderator
It was most likely a wiped joint.
Lead work is nothing to learn on. Its practically a lost art in most parts of the country younger. I would recommend you get someone with experience out there to make the repair. Your costs are deductible since this is rental property. This is nothing like PVC or ABS or PEX. You can screw it up royally even if you think you've done everything properly.
Double A
If I cut the lead 6" or so past the stop is there no way to join copper to it other than a wiped joint. The chances of finding an old plumber with experience in this is slim to none. Sure would be nice if the city would step up to the plate and replace their portion of pipe and a flared stop. We would be from the stop to the meter and backfilled in an hour. So much for the lead fear. |
The Grand Wazoo
Professional Instigator
The fear that Lead water pipes are gonna kill you or your tenants.
#7 | |
The Grand Wazoo
Re: Replacing Lead MainQuote:
The chances of lead poisoning from a water service is about the same as knocking down the Sears Tower with a 4 oz. ball peen hammer.
#8 | |
I think its bunk myself but water service replacements run 3-10K around here. |
I know that if you run Middle Sis's
water on a real lead test kit 1st thing in the morning, it'll turn color. After the water's been running a bit it's cool.
Pro Plumber
Trade: Plumber
Never seen a lead water service here.
The Grand Wazoo
I'm in more danger of lead fumes from melting the lead to wipe a joint on a lead water service than I ever am from the service itself. The last wiped joint I did was on my water service last summer.
Pro Plumber
Trade: Plumber
I would not even know how to do a wiped joint for a water service, interesting, I can't see how it could hold up to the pressures given.
#13 | |
#14 | |
The Grand Wazoo
A wiped joint is twice as thick as the pipe it is joining at the joint point. There is no good way to describe how to make a wiped joint, I have looked for pics in the past with little luck, the only way I can convey would be to show you.
Pro Plumber
Trade: Plumber
Long ways to Chicago
But now I have seen wiped lead bends here for the closet flange, never done one myself.
#16 | |
The pipe looks diseased.
Trade: Remodeling / Carpentry
Published 1910 I'm sure the illustrations will look familier to some of us.
http://books.google.com/books?id=ked...um=5&ct=result |
#18 |
The Grand Wazoo
He was using an old candle then.
#19 |
#20 |
Trade: Plumber
I'm with Ron here..have only found extremely old lead pipes under crawspaces here.
I don't wanna get into a debate or semantics, but to even hiint at using lead on potable here would get a very adverse reaction from anyone in the biz. |
| What Internet lead services should do to corner the market | Mike Finley | Business | 45 | 03-26-2010 09:17 PM |
| Internet Lead Service Busted Red-handed--gotta Read!! | morganexteriors | Marketing & Sales | 39 | 01-18-2010 07:02 PM |
| New Lead from contract wars | Any Season | General Discussion | 0 | 04-26-2008 06:03 PM |
| Replacing drain main, easier to go around? | Bill in VaBeach | Plumbing | 2 | 12-14-2007 01:58 PM |
| Main beam sagging 1/2 inch? | AllGoNoShow | Construction | 10 | 10-12-2006 08:20 PM |
