Replacing Cast Iron Hw Radiators W/ Hot Water Baseboards
Old 08-07-2012, 06:07 PM   #1
nycphotography's Avatar
Trade: general renovation
Rewards Points: 75
I buy and renovate foreclosed duplexes to rent.
In one house, several cast iron radiators were stolen.
I'm planning to replace the missing ones w/ modern baseboards, but I have two questions:
First, a 6' baseboard radiator seems to have less BTU capacity than a 3' 4 row cast iron one. Can you point me toward the resources I need to figure out how to get the right capacity? (I can read and do math, links are fine, but a walkthrough on calculating capacity on baseboards vs cast iron would be helpful).
Second, if I need 6' of capacity but only have 3' of wall space, what do I do? Stack two 3' baseboards one over the other? Can I plumb them in parallel, or do I have to run a return line across from one to the other? (think a bathroom that had a tall narrow cast iron radiator).
Third, I know the remaining cast irons will have latent heat causing imbalances. How would I balance them w/ the baseboards? Or should I just replace all the radiators w/ baseboards since they're so cheap?
Thanks,
John
nycphotography is offline
Old 08-07-2012, 08:42 PM   #2
Jackpine Savage's Avatar
Trade: General Contractor/carpenter
Rewards Points: 152
Re: Replacing Cast Iron Hw Radiators W/ Hot Water Baseboards
Thanks,
John
Been there done that. I'm not a heating guy, but the only way I could see it working is if you have two completely different zones for the two different types of heaters.
Fill a cast iron radiator with hot water, and it radiates heat for a long time. A fin tube is stone cold in a short time. Completely different animals.
Jackpine Savage is offline
Old 08-20-2012, 09:56 AM   #3
Rewards Points: 75
Can anyone point me to a reference to help w/ sizing the baseboards using the cast iron as a reference?
Looks like I'll be pulling the half of the cast iron that wasn't stolen and replacing ALL the cast iron w/ fin tube baseboards in both units (7 baseboards per unit). It's a lot cheaper than replacing the missing cast iron, and baseboards work great if sized correctly in a matched system.
Old 08-20-2012, 10:03 AM   #4
LRG WoodCrafting
Leo G's Avatar
Trade: Woodworker Extraordinaire
Rewards Points: 8,115
You can use a euro style radiator. They are tall like cast iron and might have the BTU capacity of them.
Sawdust Follows Me Everywhere
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is offline
Old 08-20-2012, 10:05 AM   #5
LRG WoodCrafting
Leo G's Avatar
These even look like cast iron but not as bulky. They have BTU listed
http://www.runtalnorthamerica.com/re...radiators.html
Carpenter by day.
http://lrgwood.com
Leo G is offline
Old 08-20-2012, 06:43 PM   #6
rrk's Avatar
Rewards Points: 1,520
I guess you already checked to make sure it is not steam heat, right?
The euro style like the Runtal are nice, there is another one who's name escapes me that I used to get from a place in N.H. That was also nice and cheaper than Runtal.
rrk is offline
Old 08-20-2012, 06:56 PM   #7
Box Builder
Morning Wood's Avatar
Rewards Points: 8,788
Who the hell steals a cast iron radiator? Those things are so heavy. Buderus makes a panel radiator too. They're ok
Morning Wood is offline
Old 08-21-2012, 07:56 AM   #8
Rewards Points: 75
The house is definitely hot water and not steam.
I guess I really need help reverse engineering the BTU capacity of the cast iron radiators, then from that I can size the baseboards.
Old 08-21-2012, 08:01 AM   #9
Guy who makes things
UALocal1Plumber's Avatar
Trade: Plumbing
Rewards Points: 254
I think you're giving yourself a headache for no reason. Pick up CI radiators to replace the missing units. Governale makes the common ones around here. They're similar in price to CI baseboard.
Copper baseboard may seem like a good idea in the rental unit, but they're subject to abuse and theft as well. Plus you'll never get the system to run well because the pipe and drops were designed for a certain BTU/hr in each area. there's no reason to mess with it.
Think of the labor needed to pipe in the new baseboard as well. Replace the radiators, you'll be done in 1 2 3.
Keith
"To pipe" means to install a plumbing system, not "to plumb". When someone says that they "plumbed the house in" I want to cringe. What you told me is that you held a 6' level against the wall.
UALocal1Plumber is offline
Old 08-21-2012, 08:24 AM   #10
Rewards Points: 75
For example, one radiator that was "almost stolen" is 24" tall, 5 rows, 22 sections.
This site says that's 3.0 x 22 x 170 = 11,220 BTU.
http://www.colonialsupply.com/resources/radiator3.htm
But a new baseboard says 330 BTU / ft. That means I need 34 FEET of baseboard??
Really?
Old 08-21-2012, 08:26 AM   #11
Rewards Points: 75
Keith
Really? I'll look for those this afternoon...
any suggestions where to buy in NJ or E PA?
Old 08-21-2012, 09:49 AM   #12
Trade: Plumbing
Rewards Points: 254
Just try a local plumbing supply. I don't know who's near you sorry.
Old 08-21-2012, 10:25 AM   #13
Rewards Points: 75
I called Governale, they referred a couple local houses. Only one in NE PA is in Stroudsburg. When the time comes, I'll call OCS too. They both do CI, both in Brooklyn.
$350 to replace one stolen radiator. With 2-4 missing, it becomes an even wash between buying $1500 of radiators or buying $1500 baseboards. Or maybe $750 in baseboards and consolidate the iron from two units into one.
Guess I should just replace the CI to avoid sizing and design problems in the future. Thanks.
As an aside, I just checked scrap prices... they're worth around $20 in scrap iron. Gotta love a meth head. Wrestling 200 lbs of iron out of a house to get $20 (or less) for scrap, and doing $500 damage in the process.
Old 08-21-2012, 10:41 AM   #14
Rewards Points: 75
Guess what I just found....
http://bed-stuy.patch.com/listings/k...ating-supplies
A huge warehouse of used radiators in Brooklyn... open 24/7.
That should help lower the cost of replacing them.
Old 08-22-2012, 11:12 AM   #15
Trade: Plumbing
Rewards Points: 254
Trust me, that **** will make you do crazy things.
Keith
Old 08-24-2012, 08:14 PM   #16
Repair & Renovation
Rich D.'s Avatar
Trade: R. Damato Construction
Rewards Points: 2,584
Get used radiators.. i know that place in brooklyn as posted above
“The bitterness of poor quality is remembered long after the sweetness of low price has faded from memory.” - Aldo Gucci
Rich D. is offline
Refinishing an Old Cast Iron Sink? sbcontracting Kitchens & Baths 6 08-17-2011 05:03 PM
Cast iron shower pans?? ruskent Remodeling 18 11-24-2009 07:29 PM
Has anyone heard of cold fusion welding for cast iron tmpnc Welding & Steel Trades 1 02-04-2009 12:24 PM
water heats water but doesnt circulate heat in baseboards geno49 HVAC 4 10-17-2006 07:38 AM
Cast Iron Pipe denick Excavation & Site Work 18 05-13-2006 08:32 PM
