Replacement Of Toilet Shut-off Valve
Old 01-10-2018, 02:39 PM   #1
svankirk's Avatar
Trade: Handyman & Light Remodeling
Rewards Points: 186
Hi folks,
I recently replaced a leaky shut-off valve for my toilet. I'm not a licensed plumber, so I'd like to know whether what I did is what an expert would have done. (This was a repair in my own home. Since I'm not a licensed plumber, I don't do plumbing work for my business.)
After removing the compression fitting, the 1.5" stub-out that remained had two compression-ring indentations in the copper pipe. I was planning to install a press-fit, 1/4-turn shut-off valve. I didn't feel comfortable that the fit would be good, given the compression-ring indentations. I cut off the indented portion of the copper stub-out, sweated on a coupler and a new stub-out, cut the stub-out to a more reasonable length, and installed the press-fit shut-off valve. Before attaching the new valve, the stub-out was approx. 3.0"-3.25" (instead of 1.5" as it had been). Everything is leak-proof & working fine, and it has been for a few weeks now.
So here are my questions:
1. Is this what an expert would have done? Or would the press-fit fitting have been just fine if installed over the old indented stub-out? In other words, did I make the repair harder than it needed to be (again!)?
2. Would the repair be up to code? If it matters, I live in the state of WA, in the Seattle metro area.
Thanks!
Steve
Simply Renewed Spaces
svankirk is offline
Old 01-10-2018, 06:49 PM   #2
MarkJames's Avatar
Trade: Handyman Services
Rewards Points: 11,275
Re: Replacement Of Toilet Shut-off Valve
Was the "indented thing" the ferrule? I leave the ferrule and nut, and use them on the new valve.
MarkJames is offline
Old 01-10-2018, 07:10 PM   #3
Renaissance Man
superseal's Avatar
Rewards Points: 4,950
Once "compression" has been made, your not supposed to re-use the ferrule. You can get way with it sometimes if installed correctly the first time around and wasn't over tightened, but should be viewed as bad practice.
supersealconstruction.com
superseal is offline
Old 01-10-2018, 07:14 PM   #4
Renaissance Man
superseal's Avatar
My only question for you Steve is why after the effort of sweating on an extension, why didn't you just sweat a valve on?
The Following 3 Users Say Thank You to superseal For This Useful Post:
Inner10 (01-10-2018), NJGC (01-13-2018), Tinstaafl (01-10-2018)
Old 01-10-2018, 07:22 PM   #5
svankirk's Avatar
Rewards Points: 186
Hi guys,
Just to clarify: the indented rings in the copper stub-out were the depressions left by each side of the old compression sleeve/ferrule.
I removed the old ferrule like this:
https://cdn2.tmbi.com/TFH/Step-By-St..._SHUTOF_08.jpg
and the depressions were like the one shown here (only one is visible in the photo):
https://cdn2.tmbi.com/TFH/Step-By-St..._SHUTOF_10.jpg
I didn't want to slide a Shark-Bite-style (i.e. push-to-connect) fitting over the two "indent rings", so I cut off this portion of the copper stub-out and finished the repair as described previously.
Hopefully that clears things up. Let me know, if not.
Thanks for the help!
Steve
svankirk is offline
Old 01-10-2018, 07:30 PM   #6
MarkJames's Avatar
Next time leave the ferrule and nut.
Point take, SuperSeal (but it usually is fine).
Old 01-10-2018, 07:31 PM   #7
svankirk's Avatar
Rewards Points: 186
Well, the short-but-humbling answer is that I'm a plumbing newbie and didn't think of it. Which is why I figured I'd check with the experts.
So it sounds like a better option would have been to sweat on a valve, too?
In that case, would it have looked like this:
1. cut off "damaged" portion of copper stub out (as I did)
2. Sweat valve onto new stub out (do this in the garage, rather than in the cramped space under the toilet)
3. Sweat coupler onto new stub & valve combo (also done in the garage)
4. Sweat coupler/stub/valve combo onto stub out under toilet.
Is that what I should have done?
Thanks!
Steve
svankirk is offline
Old 01-10-2018, 07:34 PM   #8
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 10,638
Thanks!
Steve
I think what he means is why bother sweating on the extension? If you had a long enough stub to burn on a coupler why not just put the valve on and save the 10 bucks on the shark bit valve?
Inner10 is offline
Old 01-10-2018, 07:50 PM   #9
svankirk's Avatar
Rewards Points: 186
Ohhhhhhh... OK. So I should have used a "sweat valve" and put it on right over the old stub?
In that case, should I have cut off the old stub because of the depression rings, or could I have sweat a new valve on right over it?
Also, could you point me to such a "sweat valve" so I can see an example. I did a quick search and saw lots of tub/shower valves, but didn't see much for a toilet shut-off.
Thanks - I really appreciate it.
Steve
svankirk is offline
Old 01-10-2018, 08:09 PM   #10
Renaissance Man
superseal's Avatar
Here's a few...
Replacement of toilet shut-off valve-brasscraft-shut-off-valves-ktr19x-c1-64_1000.jpg   Replacement of toilet shut-off valve-r14-c-5.jpg
Old 01-10-2018, 08:24 PM   #11
Renaissance Man
superseal's Avatar
I like threading nipples as well ...still superior to any sharkchit fitting.
Works on the same premise as using a drop ell for a showerhead or HH body spray.
Replacement of toilet shut-off valve-bathroom-pics-022.jpg   Replacement of toilet shut-off valve-bathroom-pics-024.jpg   Replacement of toilet shut-off valve-bathroom-pics-012.jpg   Replacement of toilet shut-off valve-img_1229.jpg   Replacement of toilet shut-off valve-img_1230.jpg
Old 01-10-2018, 08:32 PM   #12
svankirk's Avatar
Rewards Points: 186
Nice. Thanks for the visual. I really appreciate it.
So regarding my remaining questions:
1. Is there a code requirement as to how far the valve or stub can stick out?
2. If sweating on a valve like the pictures in the previous post, would you go right over the old stub, indents/depressions and all? Or would you cut off the "damaged" portion of the stub before sweating on the valve?
And I guess a third question would be this:
3. Would a REAL plumber have just put on a new compression valve rather than sweating anything? If so, would you just re-use the ferrule? (Ignore the latter question if it'll stir up a hornets nest. )
Thanks guys!
Steve
svankirk is offline
Old 01-10-2018, 08:34 PM   #13
svankirk's Avatar
Rewards Points: 186
Wow, Superseal - that looks way nicer than what I ended up with!
Steve
svankirk is offline
Old 01-11-2018, 07:19 AM   #14
This space for lease
RangoWA's Avatar
Trade: Tool jocky
Rewards Points: 3,172
I'm not buying the sweating on a valve. Seems very impractical to me. If that was the way to go that's the way they'd be when new and I have as of yet to see it. Every valve I've seen has been threaded. I haven't seen every home obviously but it wouldn't be the norm around here. I've replaced all mine with no issues.
RangoWA is offline
Old 01-11-2018, 07:31 AM   #15
Inner10's Avatar
There are a zillion ways to skin a cat, and all will out last the crappy flex line that goes to the toilet.
Inner10 is offline
Old 01-11-2018, 08:02 AM   #16
RangoWA's Avatar
Trade: Tool jocky
But there's the standard method that I've seen 100% of the time so far. Installed many in new home construction in the 80s. Braided flex lines are also the norm here.
RangoWA is offline
Old 01-11-2018, 08:40 AM   #17
B.Johnson's Avatar
Trade: Builder
Rewards Points: 646
Unless it's pretty old all they use is compression here. Judging by the age of things I've worked on I would say that they started with threaded, then sweat, and now compression. When I replace a compression valve I usually replace the nut and sleeve. 90% of the time I'm replacing the cabinet and I want the hole to be pipe-sized, not nut-sized.
Edit: I do think it's interesting how different methods trend in different parts of the country.
Home Designer Series Software
B.Johnson is offline
Old 01-11-2018, 09:09 AM   #18
RangoWA's Avatar
Trade: Tool jocky
By threaded I mean a compression ring with a threaded nut. I've never seen a valve threaded directly to a pipe in a home for kitchen or bath angle stops. Water heaters, yes.
RangoWA is offline
Old 01-11-2018, 09:33 AM   #19
kirkdc's Avatar
Trade: Remodeling (mostly kitch/bath)
Rewards Points: 2,684
I use the old ferrel and compression nut, never a problem.
Braided lines are the norm in CO. ( at least where I am)
kirkdc is offline
Old 01-11-2018, 10:13 AM   #20
B.Johnson's Avatar
Trade: Builder
Rewards Points: 646
Second picture in Post #11.
90 yr old window replacement? coworx Windows, Siding and Doors 3 04-26-2013 10:36 PM
Sloan flush valve wireless Plumbing 6 08-07-2012 03:37 AM
Stop Valve - Stem Replacement Only ? We Fix Houses Plumbing 3 06-18-2012 07:57 PM
Easy, toilet replacement fireguy Plumbing 21 05-12-2011 09:03 AM
Toilet seal gnxtc2 Plumbing 6 04-01-2011 04:25 PM
