Removing A Radiator
Old 02-20-2008, 07:45 PM   #1
fast pasquale's Avatar
Trade: Hardwood flooring contractor
Removing A Radiator
So I have a boiler. It's a two pipe system. There are no vents on the radiators. So Im guessing this is a hot water gravity system?.. Anyways... I have the 2nd fl bathroom gutted and need to remove the radiator for a few weeks. I believe the supply pipe is 3/4 inch and the return is 1/2. What does this entail?? Can I just shut the system off.. wait for the radiator to cool off and back off each union and then cap it??...or is there more involved than this.. Thanks so much!!
Chris Frate
Pasquale Floors
fast pasquale is offline
Old 02-20-2008, 08:05 PM   #2
The Grand Wazoo
KillerToiletSpider's Avatar
Re: Removing A Radiator
You'll have to bleed off the air in the system when you fire it back up, but that's about it.
KillerToiletSpider is offline
Old 02-21-2008, 03:12 PM   #3
masterk's Avatar
Trade: Plumbing
I would tie the 2 together with a bleeder valve to let the air out.
masterk is offline
Old 02-21-2008, 10:54 PM   #4
mas.. I dont understand.
Chris Frate
Pasquale Floors
Old 02-21-2008, 11:17 PM   #5
mdshunk's Avatar
He's saying that in addition to just connecting the two "ends", but a tee in that new pipe with an auto-bleeder to make an easy spot to get the air out. Might not be a bad idea, but you also might not have an aesthetically good place to do that. Not really a requirement anyhow. The more places you can bleed from, the easier the bleeding job is. No big deal either way.
mdshunk is offline
Old 02-21-2008, 11:19 PM   #6
Thanks Md.. long time no talk. As always.. you're very helpful..Hope all is well.
Chris Frate
Pasquale Floors
Old 02-21-2008, 11:28 PM   #7
mdshunk's Avatar
You talked about capping off the ends, but that might not be what you need to do. If you have steam, you'd cap both ends. If you have a hot water monoflow tee system, you'd cap both ends. If you have 2-pipe hot water, then you'd cap both ends. If you have a loop system, you'd connect both ends with a short piece of pipe, or nothing on that loop will work. You're gonna have to puzzle on your system a bit to figure out what you have. Since you said 3/4 in and 1/2 out, you're likely on 2-pipe or monoflow hot water, but double checking would be a good thing.
mdshunk is offline
Old 02-21-2008, 11:30 PM   #8
I have a 2 pipe steam system. I have a boiler with a site tube. It doesn't have vents on the side of the rad's.
Chris Frate
Pasquale Floors
Old 02-21-2008, 11:45 PM   #9
mdshunk's Avatar
Groovy. There you go then.
mdshunk is offline
Removing a radiator temporarily fast pasquale HVAC 1 02-21-2008 10:43 PM
Removing Tar from slab Brickie Concrete & Paving 2 12-29-2007 09:59 PM
remove/replace radiator ProWallGuy Plumbing 8 07-08-2007 08:46 PM
Removing Tile over hard wood flooring CMSuper Flooring 10 04-28-2006 10:43 AM
Removing stain from a french door or replace? Mike F Painting & Finish Work 6 03-22-2004 10:46 PM
