Removing Old Drain/clean Out At Foundation Wall - Plumbing - Contractor Talk
Old 04-14-2011, 09:27 PM   #1
brianford's Avatar
Trade: general contractor
I'm in the process of finishing a basement. there is what looks to be the old waste line going through the foundation wall, (probably to the old septic system) If i could remove the first section of pipe i would be able to cheat the dry wall enough to get it by and hide the pipe in the wall. it seems as if the fitting is rock solid. I don't know if it is epoxied or what. It is either steel or cast iron. Any ideas to help get the pipe out.
If I am successful in removing the pipe what can I use to cap the pipe flush to the end of the joint. I need every 1/8th inch I can get to get the dry wall by.
brianford is offline
Old 04-14-2011, 09:43 PM   #2
Mike's Plumbing's Avatar
Trade: ooo
Rewards Points: 2,000
Re: Removing Old Drain/clean Out At Foundation Wall
Can you get a C.I. snapper on it? If you can then snap it clean and put an expansion plug in it.
Mike
see ya!
Mike's Plumbing is offline
Old 04-14-2011, 09:48 PM   #3
New Quirky Carpenter
William James's Avatar
Trade: Trim Carpentry and Remodeling
Rewards Points: 538
Call Mike!
Guilford, CT Remodeler and Carpenter Web-site Twitter@CraftsmanJay
Facebook
The great use of life is to spend it for something that will outlast it.
William James is offline
Old 04-14-2011, 10:00 PM   #4
The Grand Wazoo
KillerToiletSpider's Avatar
Rewards Points: 1,880
Dynamite.
KillerToiletSpider is online now
Old 04-14-2011, 10:16 PM   #5
Rewards Points: 538
Oops!
Call KTS! He's a little anal though!
And, um, retired. 
Facebook
Old 04-14-2011, 10:20 PM   #6
The Grand Wazoo
Originally Posted by William James View Post
Oops!
And, um, retired. 
Anal?
Moi?
Old 04-15-2011, 10:22 AM   #7
brianford's Avatar
Mike
cant get it close enough with a snapper and i think it would be a little tough to snap on the bell. right?
Old 04-15-2011, 03:46 PM   #8
Trade: ooo
No don't snap on a bell. Take a grinding wheel in an angle grinder and cut it flush. Just be dam sure it's no longer connected or needed because once you go down this road it's tough sailing if you need to use it again.
see ya!
support for wall andyhandy General Discussion 4 08-15-2009 03:50 PM
Cracked Foundation brc Masonry 4 08-02-2009 11:59 AM
Removing siding and Re-Insulate wall avillalobos Remodeling 7 06-17-2009 08:30 PM
Removing studs from a load bearing wall. Russ25nys Framing 36 06-13-2009 08:52 PM
Anyone have experience with Thoroseal to waterproof bsmt foundation? Jim S. Construction 1 08-26-2008 10:53 AM
