Remove/replace Radiator
Old 07-07-2007, 12:49 PM   #1
Back from the dead...
ProWallGuy's Avatar
Trade: Paperhanger/Painter
I'm putting together a bid for a plaster repair/paint job. One large section of failing plaster is directly behind a radiator, so I can't get to it. I need someone to remove (I guess 'cap off') the radiator, and come back a couple days later to replace. Is this something I need a licensed plumber to do, or will a 'handyman' suffice?
I know I'm not going to touch it!
ProWallGuy is offline
Old 07-07-2007, 12:53 PM   #2
The Grand Wazoo
KillerToiletSpider's Avatar
Re: Remove/replace Radiator
It has a union on the inlet and outlet side, right on the radiator, so as long as the system is shut down you can do it yourself.
KillerToiletSpider is offline
Old 07-07-2007, 01:07 PM   #3
mdshunk's Avatar
If it's a steam system, and the boiler is off, no problem for a handyman to R&R.
If it's a hot water system, the system will need to be drained down a bit to remove the radiator, and then when it's reinstalled, the system will need to be repressurized and that radiator bled. It is a very real possibility that a larger portion of the building will need the radiators bled also, depending on how much needed drained down to remove that radiator.
mdshunk is offline
Old 07-07-2007, 02:39 PM   #4
ProWallGuy's Avatar
Thanks for the info guys, but you must have missed this part:
I know I'm not going to touch it.
I know my trade, and my own limitations. This isn't something I want to dick with and waste my own time trying to figure it out. If I screw something up, I don't want to have to be liable for it. Just like I hope you guys don't try to patch/touch up walls (*coughMDcough*). It is a very old historic home, waaaay expensive. I'd rather have someone who has done this before handle the headache. If I can't find someone, I'll tell the homeowner to find someone.
Old 07-07-2007, 02:46 PM   #5
mdshunk's Avatar
I know. I thought you were trying to decide whether to hire a handyman or a plumber. In either case, I'd hire a plumber. It's just a little bit more simple of a job on a steam system, and a bit more comlex for hydronic.
I do understand that outside of the northeast, not all plumbers are also "heating guys". In the northeast, plumbing and heating are nearly the same trade, and most plumbing companies say "...plumbing and heating". In other areas you might need to get an HVAC man or a "furnace man" for such work.
mdshunk is offline
Old 07-07-2007, 07:25 PM   #6
Electro-Mech. Contr.
MechanicalDVR's Avatar
Trade: Mechanical Contractor
Want a professional job, hire a professional. Call a plumber.
"Injustice anywhere is a threat to justice everywhere" mlk
100% Union and Proud of It
MechanicalDVR is offline
Old 07-08-2007, 12:08 AM   #7
Grumpyplumber's Avatar
Trade: Plumber
Tell me about it!
12 hour day piping in a boiler replacement.
Got a call this morning about a furnace duct system from a referral from another boiler and had to explain the difference.
I think I really gotta get into it...make things less complicated to explain.
Grumpyplumber is offline
Old 07-08-2007, 12:47 PM   #8
747's Avatar
If thats a historical home and that radiator has never been touched a plumber might have to bring out the big pipe wrenches to get that thing unhooked. MD. is rite where i live plumbers are also heating and airconditioning but the minute you go north its hvac. Suburbs north of Kankakee county....will,cook counties. Finally where i live my plumber feels comfortable working on those system in the old victorian homes but some guys don't.
747 is offline
Old 07-08-2007, 08:46 PM   #9
Trade: Plumber
OR if it's the baseboard type you need a pressing tool.
replace cast iron radiator with in-wall convection? zmusashi Plumbing 3 07-30-2007 03:47 AM
Pricing Radiator cover MANTUS Finish Carpentry 0 06-14-2005 01:24 PM
Painiting Hot Water Radiator. chrisintroy HVAC 3 03-24-2005 11:07 PM
