Relocated Tub Drain Patched? - Plumbing - Contractor Talk
Old 06-01-2017, 08:30 AM   #1
artinall's Avatar
Trade: Repairs & Finishing
Rewards Points: 2,170
If concrete is broken out to locate a tub drain, and the tub set, shouldn't the concrete be patched, rather than leaving exposed pebbles?
artinall is offline
Old 06-01-2017, 09:18 AM   #2
General Contractor
greg24k's Avatar
Rewards Points: 7,516
Re: Relocated Tub Drain Patched?
But Of Course
greg24k is offline
artinall (06-01-2017)
Old 06-01-2017, 09:45 AM   #3
artinall's Avatar
Originally Posted by greg24k View Post
But Of Course
Found it left this way... what might be the reasons it needs to be patched? Possible freezing?
artinall is offline
Old 06-01-2017, 07:35 PM   #4
avenge's Avatar
Rewards Points: 3,132
Well I certainly wouldn't part of my slab left open with gravel over dirt. If for no other reason you're a hack if you don't patch it.
avenge is online now
The Following 2 Users Say Thank You to avenge For This Useful Post:
greg24k (06-03-2017), hdavis (06-01-2017)
Old 06-01-2017, 09:54 PM   #5
hdavis's Avatar
Rewards Points: 2,993
If it's slab on grade, insects and rodents.
hdavis is offline
MarkJames (06-02-2017)
Old 06-02-2017, 08:29 PM   #6
tgeb's Avatar
Rewards Points: 1,478
Mostly rodents....
www.gebcon.com
tgeb is offline
Old 06-02-2017, 10:19 PM   #7
hdavis's Avatar
Originally Posted by tgeb View Post
Mostly rodents....
In termite country, they'll come in through and gap in the slab (if they aren't killed before they get there).
That would have to be made an accessible treatment point for periodic application.
hdavis is offline
Old 06-03-2017, 01:18 PM   #8
artinall's Avatar
Mostly rodents....
Can they actually bore their way that far through pea gravel?
artinall is offline
Old 06-03-2017, 01:35 PM   #9
Big Johnson's Avatar
Trade: Contractor and Grunt
Rewards Points: 4,632
"Subterranean termites live in underground colonies (nests), that may be 5 to 10 feet below the surface. They're only about 1/8 inch long yet, the workers forage hundreds of feet, traveling underground, surfacing periodically, searching for food (wood) to feed the colony. If they find the wood your house is built of they can do a lot of damage."
http://www.factsfacts.com/MyHomeRepair/termites.htm
Big Johnson is offline
Old 06-03-2017, 06:25 PM   #10
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 2,607
I've seen quite a few instances where the gravel has subsided from the slab, leaving quite enough space for critters to travel in the gap. Have to admit though, I've never seen evidence they did so.
Tinstaafl is offline
Old 06-14-2017, 07:32 PM   #11
artinall's Avatar
What about a possible entry for radon?
artinall is offline
Old 06-14-2017, 07:44 PM   #12
Capra aegagrus
Tinstaafl's Avatar
Absolutely. If you buy into the whole radon thing.
Old 06-14-2017, 07:50 PM   #13
artinall's Avatar
Huh?
artinall is offline
Old 06-14-2017, 08:38 PM   #14
Capra aegagrus
Tinstaafl's Avatar
If you accept that radon is the big hairy monster we should be quaking in our shoes at, by all means you should ensure that the lower levels of your house are hermetically sealed.
While there is some statistical evidence that in some areas radon can raise the likelihood of health problems, IMO it's been way overblown by opportunists and isn't nearly as dangerous as they would like to have us believe. Crossing the street is dangerous too.
The Following 2 Users Say Thank You to Tinstaafl For This Useful Post:
Fouthgeneration (06-14-2017), overanalyze (06-14-2017)
Old 06-24-2017, 04:02 AM   #15
Ernie in Dawson's Avatar
Trade: Plumber/Gasfitter
Rewards Points: 168
I agree. Up here, they are actually making us put in a 4 inch vent pipe before the slab is poured that has to go all the way out through the roof. They are now saying the radon can seep through the poly barrier and the concrete and kill us all, yet I see old farm houses that have nothing but a dirt crawlspace and the owners have been there for decades with no significant health issues. I think there are a lot of opportunists who prey on peoples fear of getting cancer.
Ernie in Dawson is offline
Old 09-19-2017, 05:56 AM   #16
Jerry L. Garcia's Avatar
Trade: Denver Bath & Kitchen Remodel Group
Rewards Points: 30
Rodents are the one that is mostly found.
Jerry L. Garcia is offline
Flat roof drain to municipal sewer - winter freeze? bob_cntrctr Plumbing 10 05-17-2013 02:28 PM
Wet basement, just making sure my thoughts are correct HandicappedHome Excavation & Site Work 7 10-12-2012 06:17 AM
Drain Hell darr1 General Discussion 13 07-25-2012 09:40 AM
Bathroom sink strainer drain issue with venting stanfordconst Plumbing 1 05-19-2011 06:06 PM
Gurgeling sound in Tub Drain???? painter213 Plumbing 6 06-22-2010 04:11 PM
