Re-Plumbing/Turn Off Water?
Old 10-01-2009, 08:22 PM   #1
NInman311's Avatar
Trade: Building
Exclamation
I need some plumbing advice. I have a home in Virginia but I live in Florida. We just got a call from our neighbor, who checks on the house, that we had a pipe break. My husband hopped on a flight and is there now with a mold remediation company. House was built in the 70's and has copper pipes. A plumber also came out and had to fix pipes in 3 places. He says that we should consider replumbing the house. Im skeptical and don't know if that is really necessary but I might be wrong. How do you determine if it's one of those things that you have to do or if you should consider doing? And how much does a replumb typically cost?
Also, we were told to keep the water/electric on and keep the house above freezing in the winter to keep things like this from happening. The water is on a well pump so if we turn the electric off, we don't run the risk of having a never ending running pipe if one breaks. I guess my other question is what is the best way to protect our home from major leaks again from down here in Florida. We visit just a few times a year up there and don't want any more leaking pipes/broken pipes if we can help it. Thanks for any advice
NInman311 is offline
Old 10-01-2009, 08:42 PM   #2
solar guy
naptown CR's Avatar
Trade: solar contracting
Re: Re-Plumbing/Turn Off Water?
You are at the end of the life of the copper pipes. You are on a well which I suspect acid water is eatng the pipes. I would suggest replacing with CPVC or pex and make sure the pipes grade back to a central drain. Shutting off the water is a good idea as it limits the amount of potential damsge but is not fool proof.
naptown CR is offline
Old 10-01-2009, 09:22 PM   #3
the pipe master
protechplumbing's Avatar
Trade: plumbing, solar
Disregard what that guy just said.
First we need to know if those pipe leaks were pinholes from corrosion or splits from ice damage. If it was just splits than no, that in and of it's self is not grounds for a total repipe. If the pipes are corroded on the inside and pinhole leaks are springing up then I would recommend repiping.
When copper starts to pinhole it's usually the beginning of the end.
If the pipes were damaged be freezing and you decide to repipe them, DO NOT USE CPVC AS THE GUY ABOVE SAID. CPVC does not do well in the cold. If freezing is the issue your best bet is to install a quality brand of pex pipe with bronze (not brass, there is a difference) fittings. The installing plumber should take great care not to install pieces of pipe shorter than 12" as short pieces lose their freeze resisting properties. Have frost resistance hose bibs installed. Freeze valves are cheap insurance as well. And I shouldn't have to tell you but insulate the pipes. Closed cell polyethylene would be the best choice. The thicker the better.
Plumber, Repiping, Replumbing, Leak Detection, Solar Water Heater, Polk County Plumber, Lakeland Plumber, Winter Haven Plumber
protechplumbing is offline
Old 12-01-2009, 10:36 AM   #4
Matt Weinstein's Avatar
Trade: Plumbing
At the risk of advertising a product, there is another solution to pinhole leaks in copper piping. Put (pinhole leaks copper) into a search engine and find it yourself. My company, as well as others perform this sort of work and it has been used in thousands of applications both residential and commercial. Check it out and feel free to write back if you have any questions.
Matt Weinstein is offline
Old 12-01-2009, 03:46 PM   #5
oldgoat's Avatar
Trade: painter
[COLOR=black][FONT=Verdana]If the pipes were damaged be freezing and you decide to repipe them, DO NOT USE CPVC AS THE GUY ABOVE SAID. CPVC does not do well in the cold. If freezing is the issue your best bet is to install a quality brand of pex pipe with bronze (not brass, there is a difference) fittings.
Curious why you would believe that CPVC doesn't do well in the cold. I've had it under my house for years without a problem and it isn't wrapped and the crawl space isn't heated. Actually I've been told by plumbers that it was better than copper since copper conducts the cold and CPVC doesn't. For my money I'd have no problem with using CPVC again.
oldgoat is offline
Old 12-01-2009, 04:47 PM   #6
mrmike's Avatar
Trade: Electrical & Carpentry
I am not a Plumber but around here in Northern NY where it gets really cold-Down to -30 below, many summer homes are "winterized" I have done a few myself. All the pipes are drained & an air compressor is used to force all of the water out of them -usually from the top down-with connections opened up near the supply,etc. Then RV anti-freeze is put in all the drains including a washing machine, toilets bowls &tanks and other "water appliances". With "city water" it is best to turn the water off out by the street.
As far as your copper pipes they have stood the test of time-and I would be surprised if they need replacing ! Joints that break are usually poor soldering jobs- and alot of pipes break where a different metal is screwed into a copper fitting & corrodes at that point & ends up breaking..............
mrmike is offline
Old 12-01-2009, 04:52 PM   #7
DavidC
DavidC's Avatar
May I add to the confusion? Split cooper from freezing can be reliably repaired by an experienced plumber. I wouldn't start chasing pinhole leaks unless you need a hobby.
CPVC is probably OK in the right hands. But our city only allows it for home owner self installations and besides that I just don't like it.
I vote for PEX properly installed if you're going to replumb. Hopefully ProTech will come back and explain the differences between the brass and bronze fittings, I'm curious. For our occasional jobs we use PEX piping but can't say without looking what the fittings are and I'm curious.
Good Luck
www.CookContractingLLC.com
DavidC is offline
Old 12-01-2009, 07:08 PM   #8
TulsaRemodeler's Avatar
I'm not a liscenced plumber but my gut instinct says pex wont last 30 years or even 20. I like things made out of metal for supply plumbing.
TulsaRemodeler is offline
Old 12-01-2009, 07:08 PM   #9
Lots of weird response for a 2 month old
problem from a poster as phony as
a $3 bill.
He's 19, has a wife, a home in Florida and
Virginia, runs a construction company
and doesn't know any plumbers.......
Just sayin'.
neolitic is offline
The Following 2 Users Say Thank You to neolitic For This Useful Post:
protechplumbing (12-05-2009), stp57 (12-05-2009)
Old 12-01-2009, 07:14 PM   #10
a $3 bill.
Just sayin'.
Ohh, pex will do just fine then.
Old 12-01-2009, 07:14 PM   #11
DavidC
DavidC's Avatar
Damn, I was hoping to learn something. Damn.
Oh well,
Good Luck
DavidC is offline
Old 12-01-2009, 07:35 PM   #12
http://www.contractortalk.com/f44/he...or-here-43750/
neolitic is offline
Old 12-01-2009, 09:33 PM   #13
DavidC
DavidC's Avatar
I was thinking more on the differences between bronze or brass fittings with the pex. I can only remember to check post dates 1 day in a row.
Good Luck
DavidC is offline
Old 12-01-2009, 09:56 PM   #14
Old 12-02-2009, 04:24 AM   #15
747's Avatar
There is a right way to leave a house and a wrong way. Start watching ask this old house. Maybe you could catch the rerun where rich Tretheway went to a guys house and did exactly that. Basically showing him everything to do before he walked away for a season.
Ps. To the one poster i do remember him pulling out the air compressor. There was actually a whole list of things which needed to be addressed.
747 is offline
Old 12-05-2009, 12:17 AM   #16
the pipe master
PEX is an elastomer that is crosslinked so that it remains flexible and remebers it's shape. CPVC is naturally brittle and has to have plasticizers added to the resin to make it flexible. These plasticizers eventually are destroyed or leeched out of the resin and the resin returns to it's natural brittle temper. Pex will expand when frozen and then retracts again when thawed. Pex remain flexible at low temperatures while cpvc becomes brittle (just like it's parent compound PVC). Pex is not effected by oil like cpvc. if your house is winterized via using and air compressor oil from the compressor can enter the pipe and cause the resin to become soft or brittle depending on the hydrocarbon makeup. CPVC is damaged by exposure to vegetable oils (even when in smoke form), caulking, contact with NM cable (Romex), oil based paints, many pesticides, tar, lubricants (WD40, PB, liquid wrench, 3-in-1 oil). CPVC does not dampen pressure waves (water hammer) as well as pex does.
Brass vs bronze: Some parts of the country have water chemistry that will de-alloy aka de-zincafy some types of brass. Bronze is far more resistant to this de-alloying. If your area does not have said water type then there is no problem with using yellow brass.
Good Luck
The Following 2 Users Say Thank You to protechplumbing For This Useful Post:
DavidC (12-05-2009), stp57 (12-05-2009)
Old 12-05-2009, 12:19 AM   #17
the pipe master
You're right, you're not, and your wrong.
Old 12-05-2009, 09:19 PM   #18
I assume you are a liscensed plumber, proof here that liscensing is BS. Make a killing off doing fast pex jobs and let someone do it again right later
Old 12-05-2009, 09:26 PM   #19
the pipe master
I'm a third generation licensed master plumber that has been specializing in diagnosing the underlying reasons for distribution piping failures for over a decade and doing repipes. My teachers before me used pex and have shown a track record of 15 years of use without failures. Pex has a 30 year track record of use in Europe.
I put my name on all of my repipes for 25 years, do you? Oh that's right, your not even a plumber and you probably don't even know what pex is and what makes it different than other polymers do you? That won't stop you from talking smake on the internet though.
Bring it.
Old 12-05-2009, 09:36 PM   #20
Bring it.
Aight, I was a really good mechanic before most guys graduated highschool. I'm 45 now and all I need is common sense to tell me plastic of any kind is not the best for supply plumbing. Even if the pipe lasts the compression fitting are going to fail.
Hot water problem PLUMBINGITALL Plumbing 7 01-24-2009 11:15 AM
Water heater right size. flashheatingand Plumbing 0 01-11-2009 03:02 PM
water damage and condensation bigblue General Discussion 2 01-10-2009 01:11 PM
Help Water in Basement LG2720 Construction 12 01-17-2007 02:40 AM
Brick Footer and Water Proofing emtaboy Excavation & Site Work 24 07-24-2006 09:48 PM
