Raising Well Head
Old 06-13-2007, 09:29 PM   #1
General Contracting
LNG24's Avatar
Trade: Real Estate Broker, Property Manager
Raising Well Head
I have a well head that is currently 48" below grade. I need to raise it above grade. Pitless Adapter, Pipe, Coupling, and wire.
I have done a tremendous amount of elextrical and plumbing, but never did a well before. I have the head excavated out already. At $1,200 to $2000 quotes for raising it 5' I am seriously considering doing it myself.
I would appreciate any feedback on either doing it myself or not.
LNG24 is offline
Old 06-13-2007, 09:38 PM   #2
mdshunk's Avatar
Re: Raising Well Head
I understand raising the well head and the wiring, but why raise the pitless? That's a royal pain, for little benefit. If you need to lift the pump later on, they'd just have to use a longer piece of pipe to snag the pitless, is all.
mdshunk is offline
Old 06-13-2007, 11:33 PM   #3
Grumpyplumber's Avatar
Trade: Plumber
That reminds me of a thing that happened to me a month ago...I told a fella on an estimate what it would cost to do some repairs after going 1/2 hour out of my way to meet him at his home - at his convenience, he told me "that seems a little expensive...I think I'll look it up online."
He never did get back to me....
Grumpyplumber is offline
Old 06-14-2007, 08:03 AM   #4
General Contracting
LNG24's Avatar
Grumpy: I am a contractor, so doing the work myself is in my ball park. I just never did a well head. Seems simple enough, but so is sodering a pipe, but if you never did it before, you would never know where to begin. The estimates I got are only putting a boot around the pipe, I guess like a large Fernco.
MD: It isnt a pitless now. I want to make it a pitless. I gues that makes it a Pit Well as there was a pit 4' down. Here are some pictures
LNG24 is offline
Old 06-14-2007, 02:31 PM   #5
Plumber
All Clear Sewer's Avatar
Trade: Sewer Rat
I`v been there a time or two myself
All Clear Sewer is offline
Old 06-14-2007, 02:32 PM   #6
Plumber
Trade: Sewer Rat
Digger thats a nasty hole you got there son
Better think about the frost line before you bring it up to grade
Why do you need to raise it anyway?
Old 06-14-2007, 03:19 PM   #7
jmic's Avatar
Hi Larry,
I don't think you'd want to use a fernco on your well casing, what they probably meant was a slip coupling for the well casing that would get welded on if in fact the section that you have there now is not threaded.
The situation you have there actually looks like a simple fix. I'd drill the pitless in the existing casing, maybe down a foot to leave enough room for the coupling. Just make sure that you don't drop the pump.
Joe
jmic is offline
Old 06-14-2007, 05:47 PM   #8
Kgmz's Avatar
Do it yourself.
Just get some well casing and someone with a portable welding truck to weld it together. And remember it has to be water tight, don't want any surface water leaking in.
I don't know what your frost depth is but if it is deep, you could put the pitless adapter where the current level of the top of the pipe is now. This way you won't have to change the piping in the well, but it will be a little harder to get the pitless adapter together that far down. Then just get some waterproof connectors to extend the wire higher if you need to, get a well top with electrical connection hole, run some pvc conduit up the side of the casing to the well top and connect the wires. Easy.
Also when you run a length of pipe above the pitless adaptor. Put a cap on the end so your hand won't slide off the end or a elbow and short pipe so you have a handle. And don't forget to extend the rope.
Kgmz is offline
Old 06-14-2007, 06:10 PM   #9
mdshunk's Avatar
That's a heck of a lot of work to be done there. I think 1,200 to 2K seems about right to me.
mdshunk is offline
Old 06-14-2007, 11:29 PM   #10
General Contracting
LNG24's Avatar
Thanks Guys,
Just to clarify; I didn't mean to imply that $1,200 to $2,00 was too much for the job...Better stated, It is too much for my check book at this time!
I called 3 more companies today. It seems that one company here operated under 5 different names. I guess they just keep buying up the competition. I had this exact job done in Vermont and it was well below these prices. The pay scale in that area was about the same as this area too, so I was shocked when I started to get the estiamtes.
The other tow companies came in at a price more of what I had in mind. Both quotes $700-800 right over the phone. That included pulling the pump and replacing the plastic pipe with Sch. 120.
As far as WHY, All Clear? The "pit" was holding water and the sanitary boot on top was no longer sanitary allowing muddy surface water (and who knows what else) to enter the well. Thus the reason this type of well is no longer permitted around here.
Why do you say it is a Nasty Hole? That was excavated out about a month ago and had sustained 3 super heavy rain storms. I should have just dug out the trench to the french drain, but I figured it would have been extended up much sooner than now.
FYI: that head is 48" below grade.
LNG24 is offline
How to install a manifold for shower head and faucet Randy32545 Plumbing 13 04-27-2008 01:58 AM
Over head for home office? Txbassboy Business 11 10-31-2006 10:28 AM
SW Raising Prices Again BMAN Painting & Finish Work 22 10-24-2006 02:22 PM
Raising a porch roof paintr56 Construction 5 05-10-2006 06:43 PM
Raising ceiling height in the LR and D- room. marcotte64 Construction 2 04-02-2006 10:33 AM
