Trade: flooring
Radiators
i have an old radiator that is to long for were i want to move it. from its design (as far as i can tell) i should be able to loosen the top and bottom bolts that go through all the sections, bang off a few sections, shorten the bolts and reconnect? any advice, its at my sisters house i've never tried this before.
Pro Plumber
Trade: Plumber
Re: Radiators
I'm so glad you got it all figured out, since you never done this before.
Re: Radiators
I've seen it done, but even expert plumbers hesitate to do it. You have about a 90% chance of having a leak unless the mating surfaces are prepared well, and even at that it still might leak. You'll also have to have means to thread the "bolt", since it only has threads for a few inches on the end.
Trade: flooring
Re: Radiators
i'd love to sit down with a master plumber and have him walk me through it. thats not gonna happen. my sister is givin me a great opt. to try something and i'm gonna work at it till i get it right. she's got other rads to use if this don't work. what whould be my best bet for making sure the mating surfaces are true?
#5 | |
The Grand Wazoo
Re: RadiatorsQuote:
Now is assembly time, you are going to need a can of a product called Expando, some plumbing suppliers carry it, most don't, you may have to try and get it from a heating contractor, you have to have it so do what needs to be done. Mix the Expando per the directions on the can and apply a liberal coating to all mating surfaces, put them together and run you pinning rods through and put the nuts on and tighten down to snug and leave it sit for an hour to allow the Expando to set, then tighten the nuts down tight, making sure to do it evenly, and use a compressor to pressure test it. Sectioning radiators is hit or miss, it is not guaranteed to work. Good Luck.
| remote thermostat | chris n | HVAC | 1 | 01-02-2008 09:27 AM |
| HVAC system advice | kremlin | HVAC | 1 | 11-10-2007 08:32 PM |
| Radiators | Paul B | HVAC | 10 | 05-07-2007 07:29 PM |
