Purple Primer Stain Remove - Plumbing - Contractor Talk
Old 10-10-2015, 02:09 PM   #1
CHB70's Avatar
Trade: Roofing, Siding, Gutters
Rewards Points: 91
Anyone have any luck getting purple primer off a tub with acrylic surface?
RSC Builders, Inc
Complete Roof
RSC Builders
CHB70 is offline
Old 10-10-2015, 02:14 PM   #2
MarkJames's Avatar
Trade: Handyman Services
Rewards Points: 14,325
Re: Purple Primer Stain Remove
Ouch, it's probably in the finish. Maybe use clear primer sparingly and dab it out. (You might want to research that further, though.)
MarkJames is offline
Old 10-10-2015, 03:19 PM   #3
Fire up the BBQ
griz's Avatar
Rewards Points: 3,646
Likely to have better luck making the whole tub purple...
griz is online now
The Following 2 Users Say Thank You to griz For This Useful Post:
BlueRidgeGreen (10-10-2015), TNTSERVICES (10-12-2015)
Old 10-10-2015, 03:29 PM   #4
GC/carpenter
Californiadecks's Avatar
Rewards Points: 4,402
Buffer with car polish. Just a guess. I'm going to need you to sign some paperwork first if you don't mind.
Californiadecks is online now
Old 10-10-2015, 03:45 PM   #5
MarkJames's Avatar
Do a search at plbg.com There are some good ideas there. (acetone, or Q-tips + clear cleaner were a couple.)
Old 10-10-2015, 07:13 PM   #6
river rider's Avatar
Trade: general contractor
Rewards Points: 458
Might try scrubbing it aggressively with the plumbers head till it buffs out.
river rider is offline
The Following 3 Users Say Thank You to river rider For This Useful Post:
KAP (10-12-2015), rrk (10-11-2015), superseal (10-10-2015)
Old 10-10-2015, 07:15 PM   #7
Tom M's Avatar
Rewards Points: 8,438
Oh boy.....the dreaded purple
Tom M is offline
Old 10-10-2015, 07:48 PM   #8
Renaissance Man
superseal's Avatar
Rewards Points: 5,630
Toothpaste will do it - I like Crest ultra white
supersealconstruction.com
superseal is offline
Old 10-10-2015, 08:24 PM   #9
FrankSmith's Avatar
Rewards Points: 5,124
No problem.
FrankSmith is offline
Old 10-10-2015, 08:24 PM   #10
tgeb's Avatar
Rewards Points: 1,586
Many years ago I worked for a plumbing outfit and it was prohibited to have primer on the trim out phase of the work. Back then there was no clear primer, but lots of ruined tubs.
Best of luck getting that cleared up.
www.gebcon.com
tgeb is offline
Old 10-11-2015, 12:15 AM   #11
Rewards Points: 458
.....or until the blood covers it all up.
Calling manufacturer sometimes can help a lot. If you can get through the useless cust svc. people and talk to a chem guy. Usually doesn't pay off, but I've had a couple great inputs on chem reaction matters. I'd actually say try a Canadian outfit if you can. They have been way more helpful overall.
Good luck with it.
Old 10-11-2015, 07:34 PM   #12
FrankSmith's Avatar
More great advice but don't forget that the product I showed you will take care of it with no trouble.
Old 10-11-2015, 07:48 PM   #13
SprayFinish's Avatar
Trade: Refinishing/Remodeling
Rewards Points: 122
laquer thinner or possibly a denatured alcohol
SprayFinish is offline
Old 10-11-2015, 07:51 PM   #14
Rewards Points: 122
I am not familiar with that product, but wouldn't it take away the gloss from acrylic and leave a dull spot?
Old 10-11-2015, 08:01 PM   #15
FrankSmith's Avatar
It's strange stuff. It softens the finish but somehow it rehardens and does no leave dull spots. I used it to get a bunch of stuff off my van that I thought would would be there forever. After washing it there is no signs of anything in any lighting.
Old 10-11-2015, 08:02 PM   #16
John the Builder
SmallTownGuy's Avatar
Trade: Carpenter/Builder
Rewards Points: 2,146
I'm guessing yes. But a couple minutes with 1000 grit followed by an auto buffer w/compound may save some sorry SOB's butt.
SmallTownGuy is offline
Old 10-12-2015, 04:44 PM   #17
This space for lease
RangoWA's Avatar
Trade: General
Rewards Points: 4,628
I'd be skeptical that it could be done chemically. I think the wet sanding buffing solution would work. Work your way up in grit to 1,500. I did many tons of work with acrylics and plastics is the sign biz. A word of warning, some chemicals can do some very strange things to plastics, even isoprophyl alcohol.
RangoWA is offline
The Following 3 Users Say Thank You to RangoWA For This Useful Post:
Californiadecks (10-12-2015), SmallTownGuy (10-12-2015), Tom Struble (10-12-2015)
Old 10-12-2015, 08:05 PM   #18
edward trowelhands
Golden view's Avatar
Trade: Diplomat
Rewards Points: 4,874
That stuff can really penetrate if it's a drop that doesn't dry right away. I had some leak in a bucket with a few fittings and it soaked in at least 1/16th inch. I sliced purple plastic away with a razor just to see.
Too bad it can't be bleached colorless (Or H2O2), rather than dissolved.
Half of all people are below average.
Golden view is online now
Granite counter top Stain kyletyler Kitchens & Baths 19 11-03-2015 08:44 PM
New Primer was really bad! JenniferTemple Painting & Finish Work 14 11-02-2011 07:05 PM
Satin Paint vs. Stain on Rough Cedar Siding Biker01 Painting & Finish Work 4 09-21-2010 11:18 PM
Final coating on stain grade doors Mike Finley Painting & Finish Work 1 09-20-2009 10:36 AM
can't get rid of bad primer smell....help please Zeebo Painting & Finish Work 17 12-10-2008 06:39 AM
