Trade: Electrician
Pump Short Cycles
Looking at a home has a well and pump is in the cellar. Noticed that the pump kicks on and off alot. The pump is set up with a bladder tank about 5 gals. What needs to be done to keep the pump from running like this. Runs about 3 times when a toilet is flushed.
Structural Engineer
Trade: Mechanical, Structural
Re: Pump Short Cycles
Couple things to check:
Cut in/cut out pressures might be whacked out. Bladder may have failed. Forgetting about whatever else is in the system, right now the pump is being told to turn on, then off real quick, then on, then off, etc. Obviously the pressure switch is dictating what the pump is supposed to do. So either the pump switch cut in/cut outs are too close, or the bladder is shotski. If the bladder is shot, then the pump is basically pumping against an incompressible fluid (water), and reaching cut out very quick. With a properly charged bladder, the pump stays on a while and compresses the air in the bladder, then cuts off at cut-off pressure. When you open a faucet, the air in the bladder maintains pressure in the system so the pump won't have to come immediately. Check the switch, then check and see if air or water comes out of the tank's Schrader valve. Water is bad. Go the depot to pick up a tank if it's needed. Here's a link: http://www.inspect-ny.com/water/WPControls7.htm |
| The Following User Says Thank You to Aggie67 For This Useful Post: | B&C (02-13-2009) |
Trade: EC/ACR
Regarding the air bladder, I would just add that sometimes the pressure in the bladder gets low over time because of a leaky Schrader valve. I had this happen on my tank a couple of years ago.
I replaced the leaky valve core added air to the bladder to bring it back up to proper precharge inflation and all has been well since. The amount of precharge pressure is usually adjusted to 2 PSI below the cut-in pressure setting of the pressure switch. My system is set for 40/60 PSI, so I keep the air bladder precharge at 38 PSI. You would need to check and adjust the air bladder pressure with the water storage tank empty. Edit: I just noticed that the OP said the storage tank is 5-gallons! If that's not a typo, then a larger tank would probably be in order. Last edited by DuMass; 02-14-2009 at 10:09 PM. Reason: add comment |
#4 | |
Trade: Electrical & Carpentry
Re: Pump Short CyclesQuote:
Structural Engineer
You can get a Schrader valve tool from bike shops and refrigeration supply houses. We get ours from Grainger, because they come in kits with a couple extra cores. It's a pretty simple swap out.
#6 | |
Trade: EC/ACR
Another thing was that mine only came with a cheap plastic valve stem cover that was basically just a dust cap, so I replaced it with a metal valve stem cover that actually had a seal in the tip for a little added leak protection. What concerns me though, is that with a brand new tank and that rate of air loss, I think I would have probably returned it under warranty as it could have a pinhole leak somewhere in the air bladder itself. |
With a tank that small, is it a variable speed constant pressure well system?
These are the only well systems that should use a tank that small. Otherwise you will get the get the constant cycling that you have noticed. |
Trade: Power Jack Foundation Repair
check the fuse first. Is the pump coming on?
If the pump runs it may have lost it's "prime". To primp the pump turn off the power to the pump, close the valve between the pump and tank, remove the plug at the top of the pump housing, fill the pump slowly with clean water till full, reinstall the plug and turn the power back on. Slowly open the valve between the pump and tank, you should hear water rushing by the valve and you are done! If that failed then make a "well string" by tying a weight on a long string (like a kite string) and lower it in the well to measure how much water is in the well. If there is little to no water wetting your string, the well has gone dry. If you have 3 or more feet of standing water, the pump may have lost it's "prime" again. reprime as nesasary. This may be caused by a faulty foot valve in the well or a leak in the well pipe. Time for professionals then, for you have come to the limit of my experience.
building a french drain maybe a mind numbing task but you can just leave it to the experts~ |
13 Licenses & Counting
Trade: Water well drilling & pumps
If the pump isn't a VFD (Variable Frequency Drive) - such as the Gould's Aquaboost or Balance Flow, the Franklin SubDrive or MonoDrive, or the Grundfos SQE, then install a cycle stop valve.
Also, check the pressure tank - if it's a bladder/diaphragm tank, and you drain the system and the tank doesn't hold air pressure, even after charging it, your tank is junk. Get a new one. Get a larger one if you don't want to use a VFD or Cycle Stop Valve, otherwise, install the VFD or CSV and a new 5 gallon tank.
Pierce Kiltoff, CWD/PI, JKA Well Drilling and Well Pumps & Filter Supply - Map Facebook Monroe, Washington, (360)-794-7300 Serving the Entire Seattle Area, including King, Snohomish, & Pierce Counties, WA |
| Exterior grade sump pump? | Jeeper1970 | Plumbing | 1 | 12-27-2008 10:16 AM |
| heat pump ? | allaroundcomfor | HVAC | 2 | 10-29-2008 09:15 PM |
| Any well or pump info on this site????? | Jacey | Plumbing | 13 | 09-13-2008 10:01 AM |
| myson controller pump 3 port?? | big moo | Plumbing | 1 | 09-02-2008 03:48 PM |
| Graco Endurance Pump | Brockster | Painting & Finish Work | 2 | 09-22-2007 07:42 PM |
