Trade: Landscape
Pros/Cons Flex Line Vs PVC For Waterfalls
We are installing Waterfalls now and would like to move to flex lines for ease of install, but still balking at the 4 bux a foot distributer wants, even at our discount. Anybody know plumbing supply place we could shop to beat this price and has anyone had problems with the flex? Some of our distances are pretty lengthy to cover at the rate were quoted. Thanx guys..I know one of you guys know. BTW..we are in Texas if that factors in.
Re: Pros/Cons Flex Line Vs PVC For Waterfalls
I pay about a buck a foot,
stick w the ridgid in landscape application. mulch can harbor insects that may eat the flex... sorry but looks like you're stuck leveling trenches.. ray |
Plumber
Trade: Plumbing
Is there any reason why you can use pex pipe , you can get maybe 100 feet for about $30 buxs or poly pipe , Just input for you .
Trade: Plumbing & Electrical
use Pex, but make sure it's not exposed to light. The UV will "ruin" the pipe. Which BTW I have a few feet of pressurized pex in the back yard for about 6 months, still holding but I want to see how long till it fails.
bury pex???
btw typical h2o fall application calls for 2" and up.... what sizes is pex available in? |
Trade: Landscape
Re: Pros/Cons Flex Line Vs PVC For Waterfalls ....The flex pipe offered thru pond supply I work with is a black 1.5 inch line, corregated to flex, and made for burying in dirt. Anyone out there know about it? And better prices?
im on tier one pricing, so im not a good example
ask you salesman for better pricing... you do know you can do that? flex is junk, in my book... |
Trade: Landscape
Can you expand on that? Like what is it you dislike about flex hose..and are you sure we are talking about the same thing? This is like the stuff pond supply places cell, not that drain line stuff.
schedule 40 corrugated flex pvc...
there is a thread somewhere in the pool forum ray |
#10 | |
Re: Pros/Cons Flex Line Vs PVC For WaterfallsQuote:
"BURIED PEX WATER SERVICE LINES Fittings Consult manufacturer for proper fittings for water service application. Trench Preparation Trench bottom shall be solid with no hollows, lumps, rocks, or other materials that could damage the tubing. Laying the Tubing Tubing should be laid with sufficient slack (snaking) to accommodate any contraction due to cooling prior to backfilling. Tubing will expand or contract approximately 1 inch in length for each 10O F change in tubing temperature for each 100 feet of tubing. Minimum bending radius requirements for PEX tubing shall be followed. See “Bending the Tubing” Table, Page 6. Inspect tubing for damage. Remove and replace damaged sections. In poor soil conditions, such as mud, rock, black gumbo, or clay, it is necessary to excavate deeper and use good clean fill or granular fill to smooth the trench bottom. Penetrating Foundation or Basement Walls When PEX is run through a basement or foundation wall, it must be protected by a rigid sleeve that spans the distance from within the wall out to the undisturbed soil in the pipe trench. The purpose of this protective sleeve is to prevent shearing of the PEX tubing at the wall in the event there is settlement in the backfill around the wall. At the point where the sleeve terminates inside the foundation or wall, the space between the PEX and the sleeve should be sealed to prevent leakage into the building. Note: Petroleum-based caulks or sealants should not come in direct contact with PEX. Slab-on-Grade Installation Laying and Supporting Tubing Under Slab Only continuously-run lengths of tubing without fittings shall be used when installing PEX under a slab. All connections shall be outside or above the slab. Tubing shall be completely buried by a suitable, easily compacted, backfill material such as sand or pea gravel. PEX tubing should be installed under the re-bar, re-mesh or Do not use blocking for support, or to change the tubing’s elevation.INSTALLATION HANDBOOK: Cross-linked Polyethylene (PEX) Hot and Cold Water-Distribution Systems Copyright © 2006 PPFA" |
Technical Specialist
Trade: HDPE Pipelines
HDPE is also flexible. It is easy to install. You might consult some distributors on pricing. HDPE is different than PEX. It is great stuff.
Trade: Landscape
Great!..I'll check into it..
Last edited by Jacey; 08-17-2007 at 07:40 PM. Reason: didn't catch the consult for pricing.. |
2" flex 100 foot roll cost me 125$.....
......Less with the jaw & More with the paw..... |
Trade: Landscape
Re: Pros/Cons Flex Line Vs PVC For Waterfalls |
The Grand Wazoo
With HDPE the price difference is probably only about twenty bucks, an irrigation supply company can give you an exact price, it is the stuff they use for irrigation systems.
a 100ft roll of 1.5 costs me 100$
| Shingles Nailed Above Nail Line.. Help!! | Unregistered | Roofing | 24 | 04-20-2011 09:14 PM |
| Using Flex Pipe | dirt diggler | Pool Construction & Enclosures | 8 | 02-25-2007 04:30 PM |
| Flex 3" waste line??? | andybuildz | Plumbing | 11 | 01-21-2007 11:28 AM |
| Straight Horizontal Line | Speer007 | Carpentry | 17 | 12-15-2006 06:26 PM |
| Replacing residential sewer line | threequez | Plumbing | 1 | 10-17-2006 05:09 AM |
