Propane Line Proximity
Old 09-27-2007, 09:18 PM   #1
mdshunk's Avatar
This is a question for the plumbers, gas fitters, and site utility guys. Are you aware of any distance requirements in the mechanical codes or fuel gas codes that specify how close a direct buried propane line may be to an electrical conduit buried in the same ditch? There's nothing in my electrical codes that would prevent them from touching each other in the same ditch, but I want to make sure that I'm not going to violate some other code that I don't know about. Application is a remote propane generator.
Thanks!
mdshunk is offline
Old 09-27-2007, 09:23 PM   #2
The Grand Wazoo
KillerToiletSpider's Avatar
Re: Propane Line Proximity
Thanks!
I don't see a problem with that, what material is your conduit, and what material is the propane line? I'm guessing they are both plastic.
KillerToiletSpider is offline
Old 09-27-2007, 09:37 PM   #3
mdshunk's Avatar
The propane is a CTS sized yellow plastic crap, and my conduit is PVC and has 120/208 wiring.
mdshunk is offline
Old 09-27-2007, 09:40 PM   #4
The Grand Wazoo
There is no code that I know of that will not allow them in same ditch. I have run many pool heaters where the conduit and gas are in the same six inch trench.
Old 09-27-2007, 09:42 PM   #5
I'm a Mac
Chris Johnson's Avatar
Trade: ICF Construction
I always though that they had to be seperated by a min. 5' in the same ditch if they were running parallel to each other and if the crossed over they had to be a min. 12" seperation by sand.
Chris
Chris Johnson is offline
Propane vs Oil Trueheat HVAC 10 09-27-2011 03:08 PM
Shingles Nailed Above Nail Line.. Help!! Unregistered Roofing 24 04-20-2011 09:14 PM
Propane tank relocation... ruskent HVAC 4 03-19-2007 01:05 AM
Straight Horizontal Line Speer007 Carpentry 17 12-15-2006 06:26 PM
Replacing residential sewer line threequez Plumbing 1 10-17-2006 05:09 AM
