Trade: renovator
Pre-calculate DWV Pipe Lengths Between Fittings?
Gentlemen,
I've always beena measure and cut guy for abs dwv piping. But I was wondering, is it possible to determine the exact length of pipe that's required between two fittings to get a perfectly-seated install if you know the exact distance between the vertical axes of the fittings? Example: Installing a toilet drain. Between the center of the main stack and the center of the toitlet flange is x-inches. Immediately below the flange will be a 3" 90-degree elbow. The pipe will conform to the 1/4"-per-foot slope already built into the fittings. It'll join a santee at the stack. I could put the santee in place, hold the elbow in place, take a measurement between the fittings and add two times teh pipe insertion depth. OR, is there a way to calculate the pipe length from the x-inches, pre-assemble the riser, elbow, horizontal pipe and santee, so that it slips perfectly into the centres of the passages after assembly? Thanks. |
Trade: renovator
Re: Pre-calculate DWV Pipe Lengths Between Fittings?
Got it - you gotta have the tech specs on the exact parts you're using. The catalog of my fittings' manufacurer lists centerline-to-seat dimensions. Measure centerline-to-centerline, subtract the centerline-to-seat dimension for the fitting at each end, should give a perfect fit IF you seat the pipe perfectly.
For example, while the centerline-to-seat dimension for a 3" elbow is 3", and you can see the logic behind that, the centerline-to-seat dimension for a sanitee is 3 1/16". So my pipe length will be x - 6 1/16" for a perfect fit. Of course I suppose that only works on short runs where the triangle made by the 1/4"-per-foot slope is insignificant. On a 20-foot run, let's see, that'd be 240-inch horizontal, 5"-vertical, makes the hypoteneuse = sqrt(240^2 + 5^2) = 240.05", a difference of 0.05", or somewhere between 1/16" and 1/32" - ok, so never mind, we're good for pretty much any run. Very nice. Last edited by bob_cntrctr; 01-20-2009 at 01:17 PM. |
| Kitec attached directly to copper pipe? No fittings | A.D. Const | Plumbing | 29 | 03-31-2009 08:26 AM |
| Question: Stainless Steel Pipe Fittings and Valves | jasonltsp | Plumbing | 0 | 01-06-2009 02:42 PM |
| Very clean galvanized pipe. | silvertree | Plumbing | 14 | 09-14-2008 03:47 PM |
| pipe fittings | dayexco | Excavation & Site Work | 21 | 06-24-2006 02:36 PM |
| SDR 35 PVC sewer pipe lengths | dayexco | Excavation & Site Work | 17 | 05-15-2006 10:58 PM |
