Post Tricks Of The Plumbing Trade Here.
Old 02-02-2008, 11:54 AM   #121
Pro Plumber
Ron The Plumber's Avatar
Trade: Plumber
Re: Post Tricks Of The Plumbing Trade Here.
Originally Posted by gitnerdun View Post
Just curious, how does code say you can't?
UPC 606.2
Copper Water Tube Joints in copper water tube shall be made by the appropriate use of approved fittings properly soldered or brazed together.
Your way is not an approved fitting.
Ron The Plumber is offline
Old 02-08-2008, 10:22 PM   #122
AJX4's Avatar
Trade: Plumber
In some cases, using a copper strap, or a coupling cut in half lengthwise,soldered in place to patch a pinhole leak. Works when cutting pipe is not an option.
And I know exactly this situation; idiot trim guy shoots a nail through the trim board right above the bottom plate and you cannot cut into the plate or access from underneath to do a 2 coupling repair. Cutting out the 2by4 would be nice but if your' pulln the toilet or moving a cabinet, against a tub with no way for a sawsnall or minihack, you improvise. fear of causing a fire can also be a consideration when dealing with pvc in the mix. I've never done your method but I can see where the event could play out and be better than some plumbers actually solder. Improper method is seen too much in my area and those ringed solder connections is just poor makeup of the joint, contamination or too lazy to sand. I ever catch a plumber not sanding pipe or fittings because their new I'm firing them on the spot. My guys know better than that nonsense BS.
AJX4 is offline
The Following User Says Thank You to AJX4 For This Useful Post:
Ben81 (02-05-2012)
Old 02-20-2008, 08:30 PM   #123
smellslike$tome's Avatar
Trade: plumbing
Discovered this today. Sorry if it's already been posted but I didn't feel like reading all 7 pages. If done very carefully, you can drive a talon strap (snail clamp or whatever you may call them) nail into a mortar joint. I suspect that this may not always work depending on how the mortar was mixed and how long ago but today I got caught without any other means of strapping a 6' piece of pex pipe so I tried it. First one went in like a champ, second went half way in and then I bent the nail, carefully pulled it out, tried number three in the same hole and it worked like a dream. Now I don't really know how long it will take the nail to corrode away but I'm thinking a loooooong time. I was surprised it even worked at all but it did.
Looking For A Birmingham Plumber The Best Plumbing in Alabama
smellslike$tome is offline
Old 02-26-2008, 01:33 AM   #124
plumbmaster's Avatar
Trade: service plumbing
old rusted out pop up nut cant be removed, or once you remove the nut you cant get the top off. most people get out the mini hacksaw and cut for 30 -45 min very annoying. now all you have to do is get out you dremel or rotory drill and install a metel grinding disk and slowly cut away inside of pop up. this takes practice and you will break alot of disk at first. do not force disk let it do the work. place spinning disk down inside pop up from top and cut metal or plastic between overflow holes on pop up after 2 cuts pop up falls apart. I dont even try to remove nut any more 20-30 seconds and pop up is cut.
plumbmaster is offline
Old 02-26-2008, 01:34 AM   #125
Originally Posted by Squench View Post
When using a toilet auger, take a piece of 3/4 pipe insulation and slide it down over the bend in the auger. Keeps down on the scratches, and keeps picky homeowners happy.
if you do scratch any porceline you can use pumice stone to take off scratches with out hurting porceline.
Old 02-26-2008, 01:37 AM   #126
Iuse a little bit of stem grease on water valves or any water fittings that are compression or threaded. easier to install and take off if you still have that customer 3-10 yrs from now.
Old 02-26-2008, 01:49 AM   #127
Pro Plumber
Trade: Plumber
Remove the old wax off that wall hung toilet with a torch so the new neoprene gasket will bond to the toilet surface, warm the wax and wipe it off.
I said warm it up don't over heat the porcelain.
Old 03-24-2008, 12:17 AM   #128
Service Manager
plumbsharpWA's Avatar
Trade: plumbing
Originally Posted by Herk View Post
I carry a setup for that. Nipple, ball valve, hose adapter. I want the ball valve to be in the off position to stop the water flow as quickly as possible. But the ball valve usually won't spin because the handle hits the floor. So, I turn the valve off, remove the handle, then do the quick swap. Once the rig is screwed into the heater, replace the handle.
It's also a good idea to carry cut-off pieces of short hose to use when there's a floor drain close by, rather than using a 50-hose all looped up on the floor.
Why don't you just use a washer supply line? That would eliminate the hose adapter AND you now have the short hose if floor drain is close by. i felt stupid when it took me loosing 3 hose adapters to figure it out... and 3 trips to supply house( extra long lunch break that i didn't want)!
plumbsharpWA is offline
Old 03-24-2008, 12:23 AM   #129
Service Manager
Trade: plumbing
Thumbs up
Thanks for the water heater tricks. Just found this site today. I wish I found it 6 months ago, BEFORE a 78 unit condo conversion. Was running around with 6 garden hoses to try and be efficient at draining and all i needed was a compressor? I guess apprentice is p/c for dumb ass?
Old 04-11-2008, 01:04 AM   #130
Alan1981's Avatar
Trade: Plumbing Apprentice
Originally Posted by Ron The Plumber View Post
Need to remove a Shark Bite fitting, (not that you use them anyways), can't find the tool used for this purpose, use 1/2", 3/4" and 1" talons, they produce the same result
Awesome!
Alan1981 is offline
Old 04-11-2008, 01:06 AM   #131
Alan1981's Avatar
Originally Posted by Double-A View Post
I put pipe dope on my lettuce to keep it from sliding off my hamburger.
Alan1981 is offline
Old 04-28-2008, 01:58 AM   #132
thecrow71's Avatar
Trade: plumbing
You can use your pex tool to reshape soft copper tube 1/2 head for 1/2 cu and so on. Slides right in. Just be sure to not over expand.
thecrow71 is offline
Old 06-01-2008, 10:32 PM   #133
cos's Avatar
I usually use my dremel with the mini cut-off wheel for closet bolts.
Anybody else?
Also works for getting old kitchen faucet nuts off to. (Saves me time anyway).
cos is offline
Old 07-13-2008, 08:48 PM   #134
Service Plumber
plumberman's Avatar
Trade: Plumber
Cutting ductile iron 4" and below. Instead of using the cut off saw. Use your rachet cast iron cutters works everytime.
plumberman is offline
Old 08-11-2008, 12:20 AM   #135
novicepro's Avatar
Trade: general contracting
when a piece of bread or those pills or vacuuming isn't stopping that leaky pipe when sweating, put a compression ball valve and stop cussing
novicepro is offline
Old 08-11-2008, 07:48 AM   #136
stp57's Avatar
Trade: carpenter/ handyman
Dremel tool works great, but wear glasses. Those cutting discs will fly when they break.
Steve
stp57 is offline
Old 09-06-2008, 08:08 PM   #137
MDFinestKid's Avatar
Trade: Plumbing Heating
Originally Posted by mottyk View Post
Hey Ron please excuse my ignorance but what is a talon? BTW here in NYC my plumber says that SharkBite is only approved for hot water heat, not for water supply.
Thanks
shark bites are used for domestic hot and cold, not legal in some states. I believe Cali
MDFinestKid is offline
Old 09-06-2008, 08:19 PM   #138
Ever hade a problem with your toilet flanges being to low? Befor setting your toilet flang in the rough break apart a 3" j-hook and place under the flange befor screewing it down. This will rais you flange to floor level.
Old 09-06-2008, 08:39 PM   #139
explain what is a pumice stone please for my future use
Old 09-06-2008, 08:44 PM   #140
You can also use a water pump with a washing machine hose and will pump out 40 or 50 gallon under 5 mins gaurantee faster than a compressor.
Tricks of the Trade Journeyman T General Discussion 62 05-21-2009 06:12 AM
Trade Magazines (Plumbing) tzzzz216 General Discussion 7 01-07-2006 01:51 AM
