Post Tricks Of The Plumbing Trade Here.
Old 07-12-2007, 12:10 PM   #81
PARA 1's Avatar
Trade: PLUMBING
Cool
Re: Post Tricks Of The Plumbing Trade Here.
The Plumber .. He's The Best. "we Both Live In The Slab Leak Capital Of The World." P.s. I Get 10% $.
PARA 1 is offline
Old 07-12-2007, 05:45 PM   #82
The plumber's Avatar
Trade: master plumber/owner
aww!!! Are you trying to get a discount on your next leak locate.
The plumber is offline
Old 09-18-2007, 05:56 PM   #83
wiggikins's Avatar
Trade: Keepwarm
Question
Originally Posted by tzzzz216 View Post
Want a nice looking solder joint clean fitting and pipe then use a leaded pencil and go around the pipe about a 1/16 " down from the fitting and the solder wont run past the lead .
Why not wipe solder away with wire wool,it,s a helluva lot easier and less labour intensive.
Keith.
wiggikins is offline
The Following User Says Thank You to wiggikins For This Useful Post:
Ben81 (02-05-2012)
Old 09-21-2007, 01:05 AM   #84
irate808's Avatar
Trade: plumbing
Keith.
Can you explain what youre talking about?
irate808 is offline
Old 12-06-2007, 10:25 PM   #85
Journeyman Plumber
kyle181's Avatar
Trade: Plumbing
prime your pipe before you glue it
kyle181 is offline
Old 12-15-2007, 09:04 PM   #86
Moderator
Double-A's Avatar
If you're running 1/2" soft copper for something and the very end of it is not straight, you can use the chuck end of a self-feed bit inside the copper to straighten it.
The 7/16" O.D. of the bit is quite close to the 1/2" I.D., and many self-feeders have a flair as they transition from the six-sided chuck end to the business end that will take out any out-of-round condition with a few light taps.
This is of course assuming you don't own the proper tools to do this, or those same said proper tools are out in the truck, "buried under something, in one of the tool boxes."
New York Times, July 20, 2006
Double-A is offline
Old 12-15-2007, 09:08 PM   #87
Pro Plumber
Ron The Plumber's Avatar
Trade: Plumber
Interesting, what about 3/4" soft copper pipe?
Ron The Plumber is offline
Old 12-15-2007, 09:11 PM   #88
The Grand Wazoo
KillerToiletSpider's Avatar
Swage tools work well on copper tube.
KillerToiletSpider is offline
Old 12-15-2007, 09:12 PM   #89
Pro Plumber
Trade: Plumber
Need to remove a Shark Bite fitting, (not that you use them anyways), can't find the tool used for this purpose, use 1/2", 3/4" and 1" talons, they produce the same result
The Following 2 Users Say Thank You to Ron The Plumber For This Useful Post:
Ben81 (02-05-2012), Cuzino (07-09-2009)
Old 12-15-2007, 09:22 PM   #90
Moderator
Double-A's Avatar
My hands used to be strong enough to get most of the bend out of 3/4" L soft but not anymore. I have trouble with 1/2" now, which is what led me to recall the self-feed bit trick. I think the bit would be too small for the 3/4". I think I'd be walking out to the truck to get my rounding pliers and 3/4" pin die.
You can solder coupling and short piece of hard drawn to add length for leverage, or just run it long and sweat/cut off extra after straightening...
Damnit... I don't have a good answer for 3/4".
Double-A is offline
Old 12-15-2007, 09:23 PM   #91
Moderator
Double-A's Avatar
Don't bet your toolbox on it
I just won't bury them in a wall or slab. We use them mostly for temp water runs and for temp caps to allow demolition to move on without major water disruption.
Double-A is offline
The Following User Says Thank You to Double-A For This Useful Post:
Ben81 (02-05-2012)
Old 12-15-2007, 09:31 PM   #92
The Grand Wazoo
A set tool for 3/4 inch drop in anchors works real well.
Old 12-25-2007, 10:36 AM   #93
Abulance Driver
mottyk's Avatar
Trade: Contractor
Hey Ron please excuse my ignorance but what is a talon? BTW here in NYC my plumber says that SharkBite is only approved for hot water heat, not for water supply.
Thanks
mottyk is offline
Old 12-26-2007, 12:20 PM   #94
Moderator
Double-A's Avatar
Called a Tube Talon by Sioux Chief. Used to hang all types of tubing. because it grips the O.D. so well, it makes removing a Shark Bite fitting easy.
Double-A is offline
Old 12-28-2007, 02:58 PM   #95
Abulance Driver
mottyk's Avatar
Trade: Contractor
Thanks
mottyk is offline
Old 12-30-2007, 09:47 AM   #96
Pro Plumber
Trade: Plumber
Hate getting those leaks on the bottom of pop-up drain where the rubber washer butts up to the porcelain after it's installed? Slop some pipe dope on it before to tighten it down. Works every time.
Old 12-30-2007, 10:03 AM   #97
threaderman's Avatar
Trade: Plumbing & Gas Contractor
I always do that.I also put a little dope on the tank-to-bowl gasket on the softer foam gaskets.
threaderman is offline
Old 12-30-2007, 03:20 PM   #98
Moderator
Double-A's Avatar
I put pipe dope on my lettuce to keep it from sliding off my hamburger.
Double-A is offline
Smatt (03-16-2011)
Old 12-30-2007, 06:30 PM   #99
Plumber
All Clear Sewer's Avatar
Trade: Sewer Rat
Double-A Does it work????
www.all-clear-sewer.com
All Clear Sewer is offline
Old 12-30-2007, 09:58 PM   #100
Moderator
Double-A's Avatar
It makes me hungry every time I run black gas pipe.
It doesn't do much for the taste of the burger, but my clean shirt and lap thank me.
Double-A is offline
Tricks of the Trade Journeyman T General Discussion 62 05-21-2009 06:12 AM
Trade Magazines (Plumbing) tzzzz216 General Discussion 7 01-07-2006 01:51 AM
