Post Tricks Of The Plumbing Trade Here.
Old 10-15-2015, 08:50 AM   #241
Master
Squench's Avatar
Trade: Plumbing
Rewards Points: 99
Re: Post Tricks Of The Plumbing Trade Here.
Wet vac also good for catching the glug glug when replacing w/h gas control valves and elements. Only had issues once or twice over the years, once when the element had ruptured/exploded and wouldn't come out the hole and I had to break it off inside (now if it doesn't come out first try I put it back in and drain) and once on a whirlpool elect when, I saw the 1 3/8 element sticker and thought "ok so what?" so what indeed all others are 1 1/4 but I didn't know it yet. What a pain oddball reverse thread thermocouple and oddball elements hate whirlpool
Squench is offline
Old 10-15-2015, 11:12 AM   #242
Anti-wingnut's Avatar
Rewards Points: 3,186
Originally Posted by madmax718 View Post
I use self clumping kitty litter on toilet removals. Add in 2 cups gets all the water in the trap. Scoop out what you can (unless replacing toilet). sprinkle a cup into the tank too, only if your replacing the tank. Otherwise it can get messy.
Originally Posted by Tinstaafl View Post
Seems to me a wet vac would be a lot less messy than wet kitty litter...
A guy has to keep his edge. If he followed your advice he would have to change his avator to just plain Max718.
Anti-wingnut is offline
Old 10-15-2015, 07:00 PM   #243
avenge's Avatar
Rewards Points: 2,568
Best trick I've learned about plumbing.....hire a plumber.
avenge is offline
The Following 2 Users Say Thank You to avenge For This Useful Post:
hammer7896 (10-15-2015), SamM (10-15-2015)
Old 10-16-2015, 12:14 AM   #244
The Grand Wazoo
KillerToiletSpider's Avatar
Rewards Points: 1,854
It's a lot cheaper to do it before you try to do it yourself, you save the aggravation fee.
KillerToiletSpider is offline
Old 10-16-2015, 02:59 AM   #245
Hair Splitter
TNTSERVICES's Avatar
Trade: General
Rewards Points: 2,624
I bought a bucket vac just for that purpose.
Tried & True on Facebook
Tried & True Website
TNTSERVICES is offline
Old 10-16-2015, 06:46 AM   #246
madmax718's Avatar
Trade: General
Rewards Points: 3,202
You still have to dump the wet vac. And now you have a wet... vac. With poop water. Which now you have to clean. or have it slosh around. And then let dry. otherwise it will grow mold. And its clumping kitty litter!
I've also used a travel john (its a nylon mesh filled with diaper crystals in a barf bag basically). Take it out, drop it in with mesh. In 1 min, it will soak up all the water.
Just costs more to use than clumping kitty litter.
We get a lot of odd folks in NY. I guess Im one of them. One guy I worked with loved smashing toilets. Just didn't make sense, makes a huge mess, with shards of pieces everwhere, and water everywhere. Just.. nasty. He'd demo the toilet before the rest of the bathroom.
madmax718 is offline
Old 10-16-2015, 06:50 AM   #247
madmax718's Avatar
Trade: General
You mean one of those 5 gallon bucket attachments? I never thought of that for some reason. Does it work well?
The Following User Says Thank You to madmax718 For This Useful Post:
TNTSERVICES (10-16-2015)
Old 10-16-2015, 08:18 AM   #248
90%-er
onmywayup's Avatar
Rewards Points: 1,224
I can't tell you how many times I've fixed a slow or clogged drain by plugging up all the other drains in the room and putting a shop vac over the drain in the sink with a work glove wrapped around the joint to make a good seal.
Sucks the clog back out the way it came in, and beats the crap out of snaking a line more times than not.
onmywayup is offline
Old 10-16-2015, 09:00 AM   #249
Hair Splitter
Trade: General
Works awesome!
Old 10-16-2015, 09:02 AM   #250
Hair Splitter
Trade: General
I would bet that the water in the toilet is cleaner than most light switches.
The Following 2 Users Say Thank You to TNTSERVICES For This Useful Post:
Fouthgeneration (10-18-2015), TurnkeyConst (10-17-2016)
Old 10-16-2015, 09:11 AM   #251
Xtrememtnbiker's Avatar
Trade: General Remodeling
Rewards Points: 230
I use a suction gun for the water in the toilet. It's small and I don't waste a vac on it.
Xtrememtnbiker is offline
Old 10-16-2015, 12:08 PM   #252
avenge's Avatar
Ya I have 5 shop vacs, no cats and zero kitty litter.
I have pussy close by but I don't make it poop and pee in a box.
avenge is offline
Old 10-16-2015, 04:33 PM   #253
Hair Splitter
Trade: General
I bought the bucket vac at HD with an extended warranty.
Old 07-05-2016, 11:05 PM   #254
hydromechanic's Avatar
Rewards Points: 16
Strap wrench for slip couplings in tight spaces
hydromechanic is offline
Old 12-15-2016, 09:30 PM   #255
Woodworker
ShadowLynx's Avatar
Trade: General Contractor, Remodeling, Finish Carpentry
Rewards Points: 154
Keep a couple 5' sections of fence posts from an old galvanized link fence in the truck to use as a strong arm. Simply slip the the steel tubes over the handle of your pipe wrenches to out muscle those rusted couplings. They are lighter and easier to use than black pipes.
ShadowLynx is offline
Old 07-19-2017, 06:21 PM   #256
Git R Done
DemRem's Avatar
Rewards Points: 202
Recently used a windshield cut out tool to remove a sink and it worked awesome, even despite the fact that it had to cut through the toughest construction adhesive (somebody used that rather than regular silicone to glue down the sink).
Ultrawiz is the best and get various lengths of blades to go with it
Also recently converted a paintball CO2 tank (which I refill using a 5lb tank) into a drain cleaner. 1000psi seems to be quite effective on clogs. Obviously it's not good for every situation and you must use it carefully haha BTW I thought I'd mention that the remote line for the tank has a valve to control the flow just in case anybody is freaking out after reading this
DemRem is offline
Tricks of the Trade Journeyman T General Discussion 65 03-18-2014 12:08 AM
Trade Magazines (Plumbing) tzzzz216 General Discussion 7 01-07-2006 01:51 AM
