Polyethylene For Gas Line
Old 09-19-2008, 02:46 AM   #21
tool junkie's Avatar
Trade: GC - Jobsite superintendent - General tool collector
Re: Polyethylene For Gas Line
Originally Posted by Grumpyplumber View Post
I'd rather own one of 50 homes that developes water stains, or rotted framing than the one home that explodes while my wife and kids are asleep.
good point!
-----oo00oo-----
If i understood the source of my addiction I would get help,
meanwhile I'll just buy another tool today.
-----oo00oo-----
tool junkie is offline
Old 09-19-2008, 12:08 PM   #22
AtlantaPlumbers's Avatar
Trade: Commercial Plumbing
Originally Posted by 22rifle View Post
If your logic is correct then let's use copper and soldered joints for gas.
See how that flies.
AtlantaPlumbers is offline
Old 09-19-2008, 12:15 PM   #23
Handle It!
MALCO.New.York's Avatar
But 22.........
You have to understand that I NEVER argued copper for gas. Reverse logic is NOT part of the Deductive Reasoning Process.
I did argue that I do not like PEX and was just stirring, (I did pretext my post by saying so), in order to find out MORE about the why and how you guys like it.
It is an attempt to force you guys in to arguing me in to believing in PEX. So many of you use it and I am trying to understand and believe the why!
Unfortunately my attempt failed. Although I do appreciate your post on "metal to metal".
Thank You!
Ultimate Wisdom---------
MALCO.New.York is offline
Old 09-19-2008, 02:11 PM   #24
22rifle's Avatar
Trade: Plumbing & HVAC, I specialize in Hydronic Heating and more specifically in Radiant Floor Heating
Originally Posted by MALCO.New.York View Post
But 22.........
I was stalling for time to get to the real issues. I had a splitting headache, was under a bunch of stress, and wasn't hitting on all cylinders.
So I stalled for time.
Hey, at least I am honest about it. LOL
22rifle is offline
Old 09-19-2008, 02:18 PM   #25
Handle It!
Old 09-19-2008, 03:10 PM   #26
22rifle's Avatar
I was saying... my post about the copper pipe was stalling for time.
22rifle is offline
Old 09-19-2008, 05:02 PM   #27
Handle It!
Aaaaahhhhh!
Old 09-19-2008, 11:09 PM   #28
Ummm... that sounds like PMS cause thats exactly how my wife gets
-----oo00oo-----
-----oo00oo-----
Old 09-19-2008, 11:29 PM   #29
CA PLMBR's Avatar
Trade: Plumber
Originally Posted by tool junkie View Post
good point!
Hey tool junkie,
I am certified in PE butt/socket fusion. I have installed it underground for attached condominiums. I ran it from one end of the building (7 banked meters) to the other. It was a 2 lb system so I was able to make all the runs in 1" (able to run up to 200') except the last unit which had to be run in 1 1/4". I have full confidence in this piping and it connections butt or socket. From my understanding you are not allowed to run this piping in or under a building so the exploding house theory is out. I believe it is superior to metal because there is no rust factor, no leaking threads, nor any broken pipes from earth movement such as our notorious earthquakes here in Cali. This pipe is also the primary mode of delivery of gas in my area by SoCal Gas Co. Only difference is that you must run a yellow leader wire (I believe at least 18 guage) alongside of any runs made for location purposes. This piping is also ideal for those accidental (I forgot to call Dig-Alert/Didn't know what those yellow flags were for) back-hoe hits because the gas company can repair these line is record time with saddle-type repair fittings. I also am from the school of less fitting the better. Well how about a 500' roll of PE as apposed to close to 24 sections of pipe to cover the same run. It's a no brainer if were talking about statistics you just narrowed the chances of a fitting leaking by (gets out calculator) a whole FRIGGIN lot. Come on guys I truly believe there are alot of things to learn from the old tymers but don't dismiss a product simply because it's not "the way we've always done it". Sometimes new ideas are good. As for the CSST I don't think it's just a remodelers wet dream I believe it has its place. As for not using metal seals comment from 22rifle I have used 2 types of CSST (Gas-tite and Trac-Pipe) and both have metal to metal seals. They are flare connections made at time of install. The fittings are brass and the connections are made after you install the brass nut on the (plastic coated) stainless steel corrugated piping then you place 2 moon-shaped 1/2 rings into the last groove of the pipe (that you just cut). Finally you place the nut on the brass fitting tighten and the stainless steel bends to meet the surface of the flared brass fitting. In my experience although more expensive and usually engineered as branch lines and not for main feed this piping also allows for less fittings. I have not seen more leaks come from the CSST connections as opposed to IP connections. Once a person is well versed in the install of this piping I feel it is a good product. Now with my municipalities fireproofing has been an issue with multifamily units. They had issue with the plastic covering. They required us to strip the sections going through the firewall or fire envelopes. I used this piping for very difficult 3 story multifamily units with no chases and many beams. I had to run across up to 8 units with 1 1/2" piping. Without this product the potential for leaks would have been enormous due to having to hug the ceiling and dip below 7 units worth of beams. With IP this would have required 4-90s each dip not to mention any other jogs I had to make. With the CSST it took 2 guys to feed the 1 1/2" piping through the units. As for having floppy connections...we never used the CSST to stub out we always had a stub-out connected to a drop connected to a 90 and another 1' section and a coupling. That way we could secure that 1' section to the joisting or truss assuring that nothing done to the stub out would affect the CSST. I don't think CSST is going to put IP out of business but I believe it has it's place. I hope this post helps.
CA PLMBR is offline
Old 09-20-2008, 12:00 AM   #30
DRIFTWOOD
Driftwood's Avatar
Trade: GEN CONTR.
Thumbs up
A man with facts and experience ! How will They ever handle THIS ?????
Driftwood is offline
Old 09-20-2008, 12:11 AM   #31
CA PLMBR's Avatar
Trade: Plumber
Thank you Driftwood,
My intent is not to challenge as much as to inform and share the experiences that I've had. I don't know everything but the subjects I post on I feel I have something to offer. I have yet to post a question but I am digging deep. My questions will probably be more along the lines of how best to advertise or how best to grow with my business. I am hoping that the information I share will inspire those with the experience in the areas of my lacking come to my aid. Best wishes to all.
CA PLMBR is offline
Old 09-20-2008, 12:23 AM   #32
Teetorbilt's Avatar
With my experience with PE, I would not use it for anything especially gas.
I've posted this before. I worked for a company that used PE for pneumatics. A customer got some cleaning agent on the tubing and you could literally crumble the stuff between your fingers. We never figured out what it was but it's an OTC cleaner.
Albert Einstein
Teetorbilt is offline
Old 09-20-2008, 12:37 AM   #33
CA PLMBR's Avatar
Trade: Plumber
I respect your opinion Teetorbilt. However per the manufacturers PEX is photo-sensitive (UV exposure) and petroleum sensitive. As long as you keep it out of the sun and do not use any petroleum products on it you should be fine. Everything has it's Kryptonite. Copper is sensitive to Acidity and Alkalinity. We know about galvi. Just my opinion. My Kryptonite is my wife. She makes me weak in the knees.
CA PLMBR is offline
Old 09-20-2008, 01:21 AM   #34
Teetorbilt's Avatar
I've also seen a class action suit against Zurn? One of the connector companies. They're much better materials out there, everybody just wants to go CHEAP.
I engage the concept and use it, 12 yrs. without a single failure. I just use PU or Teflon tube and stainless steel connectors. This was learned from 7 yrs. of PE failures which occurred just after the Qest debacle.
It's all about money. My way, I'd CONSIDER putting in my own home. At the cost of doing it right why not stay with the tried and true (copper)?
Albert Einstein
Old 09-20-2008, 06:07 AM   #35
22rifle's Avatar
Hey CA-PLMBR... Your description of how you install CSST is exactly how I do it. I hope you understood that I meant I won't use the non-metal to metal seal type but do use the metal to metal types.
I am certified in Gastite, Trac-Pipe, and Wardflex. It's the Wardflex I won't use.
22rifle is offline
Old 09-20-2008, 11:26 AM   #36
Grumpyplumber's Avatar
Trade: Plumber
Exactly the same here, not a fan of CSST but when I have to use it, no graphite washers, no annealed (weakened) tubing.
Grumpyplumber is offline
Old 09-20-2008, 11:39 AM   #37
DRIFTWOOD
Driftwood's Avatar
Trade: GEN CONTR.
I never complain about crawlers ,but I had the worst one in My life 2 years ago!
Thank You gas tite . Building back East,We had nice basements! Still can't figure out why the West doesn't have them! But the old S.F. homes do.
OH, Seams like My threader gains about 100 lbs. a year! I use My back hoe to load it into the chevy, from the shop, when alone.
What Is The List Of Every Line Item Possible For Roof Replacemts From Insurance Cos.? Ed the Roofer Roofing 15 08-31-2008 04:19 AM
What Is The List Of Every Line Item Possible For Siding Jobs From Insurance Cos.? Ed the Roofer Windows, Siding and Doors 0 08-27-2008 08:20 PM
Line levels Tscarborough Masonry 26 03-15-2008 12:58 PM
So I was popping a straight line today.... wallmaxx Framing 10 01-22-2008 09:23 AM
Straight Horizontal Line Speer007 Carpentry 17 12-15-2006 06:26 PM
