Polyethylene For Gas Line
Old 09-18-2008, 07:03 PM   #1
tool junkie's Avatar
Trade: GC - Jobsite superintendent - General tool collector
Question
More and more I get guys trying to sell me on the PE for gas idea and Im kind of an old school guy. Can I see some opinions for and against? Just doesnt seem durable. And what about local codes? At least in my city its not allowed for residential use. Thanks.
-----oo00oo-----
If i understood the source of my addiction I would get help,
meanwhile I'll just buy another tool today.
-----oo00oo-----
tool junkie is offline
Old 09-18-2008, 07:54 PM   #2
Plumbing is a Profession
nhmaster3015's Avatar
Trade: Plumbing & HVAC
Re: Polyethylene For Gas Line
I admit it kind of make me scratch my head also but around here the local gas utility is pretty much using it everywhere. I suppose I would too but I'm not set up for it yet.
nhmaster3015 is offline
Old 09-18-2008, 08:38 PM   #3
j_builder's Avatar
Trade: Specializing in residential remodeling
I haven't installed any PE gas lines for any residential projects (yet) but I have for swimming pool gas lines and let me tell you that its the way to go just need to buy more tools (110v electric heat fusion iron) also you'll need to take a short class to be certified for PE fusion.
Old School= pain cutting and treading all the Scotch-coat piping and wrapping with 10 mil tape "Boring".
j_builder is offline
Old 09-18-2008, 10:45 PM   #4
DRIFTWOOD
Driftwood's Avatar
Trade: GEN CONTR.
Used all over N. Calif. No joints on long runs!
Driftwood is offline
Old 09-18-2008, 11:22 PM   #5
22rifle's Avatar
Trade: Plumbing & HVAC, I specialize in Hydronic Heating and more specifically in Radiant Floor Heating
Do you mean for inside or for outside?
I am strongly against it for inside. (I think it's a PEX-AL-PEX that is being marketed for inside use, not PE.)
But outside? Better than steel by a long shot.
22rifle is offline
Old 09-18-2008, 11:24 PM   #6
threaderman's Avatar
Trade: Plumbing & Gas Contractor
I use it often,it's the only way to go.CSST is also legal but it has to be in a conduit,vented and grounded.I've done that as well.For the pe, if the fusion tool is not available they also make compression risers with insert fittings.The risers are coated iron and are very stable.
threaderman is offline
Old 09-18-2008, 11:25 PM   #7
Handle It!
MALCO.New.York's Avatar
My stir stick........
So you WILL use it indoors at 80-110 PSI for water but not for 1/4-2 psi gas.
Apparently you DO NOT TRULY trust the integrity?????!!!!!
Ultimate Wisdom---------
MALCO.New.York is offline
Old 09-18-2008, 11:27 PM   #8
Slow night tonight ....?
Old 09-18-2008, 11:39 PM   #9
DRIFTWOOD
Driftwood's Avatar
Trade: GEN CONTR.
Malco has an excellent point!!!
Old 09-18-2008, 11:44 PM   #10
Handle It!
My eyes are immune to wool. My mind is impervious to marketing and mass conditioning. My Heart is as pure as the driven Snow in a Romantic Novel because I have seen ALL there is to see concerning BS and the control implemented by those who have the power to do so.
Experience dictates position, understanding and Rank.
Now....Care to explain the "double standard"?
Old 09-18-2008, 11:49 PM   #11
mickeyco's Avatar
Trade: Squirrel Handler
A mouse chews a hole, or a nail or what ever, one you have some water, the other, you hit a light switch and BOOM!
mickeyco is offline
Old 09-18-2008, 11:52 PM   #12
Handle It!
But .................This will NEVER happen with copper. Water is MORE destructive than fire. Statistically.
Old 09-19-2008, 12:21 AM   #13
22rifle's Avatar
If your logic is correct then let's use copper and soldered joints for gas.
See how that flies.
22rifle is offline
Old 09-19-2008, 12:22 AM   #14
Handle It!
See how that flies.
You gotta point Riffle. (no errror in spelling)
Old 09-19-2008, 12:23 AM   #15
22rifle's Avatar
Only to the person who does not know how to interpret statistics correctly.
22rifle is offline
Old 09-19-2008, 12:27 AM   #16
Handle It!
Water IS statistically, yearly, Historically, more destructive than fire. PERIOD.
Not because of a hose leak......
Old 09-19-2008, 12:33 AM   #17
22rifle's Avatar
The standard for gas is a metal to metal joint. That makes a lot of sense to me. There are CSST brands out there that use a non-metal seal and I will not use them.
Gas is a completely different animal than water. Too many times I have seen air (a gas) leak where water would not. (Think T&S valves) So a metal to metal seal makes a lot of sense to me.
Now think about how and where gas lines stub out. Lots of times a gas line is stubbed out in places it can be easily bumped. Water heaters, furnaces, barbecues, etc. Also, many appliances connected to gas lines are movable. (Think dryer, range, etc.)
I don't know about you, but I am not interested in having those stub outs made of something that could bend and kink. Not am I interested in having appliances moved around that are connected to something that can bend and kink. There simply isn't the structural integrity there to risk all that.
I can't think of a single situation I use PEX in similarly risky situations. Except for fixture stub outs, any exposed piping would be copper on my job. That is one place copper has the advantage.
But still, a lot of it has to do with the differences between a gas and a liquid.
22rifle is offline
Old 09-19-2008, 12:36 AM   #18
22rifle's Avatar
Well, of course.
But that is a meaningless statistic in the narrow confines of this debate.
Here is the statistic that would matter.
On average, in any given building, will a gas explosion or fire cause more or less destruction than a water leak?
22rifle is offline
Old 09-19-2008, 12:47 AM   #19
Handle It!
Well, of course.
Uh....Let me get back to you on that one......I will have to research it.....
Touche' Mon Fre're'
Old 09-19-2008, 12:50 AM   #20
Grumpyplumber's Avatar
Trade: Plumber
I'd rather own one of 50 homes that developes water stains, or rotted framing than the one home that explodes while my wife and kids are asleep.
Grumpyplumber is offline
What Is The List Of Every Line Item Possible For Roof Replacemts From Insurance Cos.? Ed the Roofer Roofing 15 08-31-2008 04:19 AM
What Is The List Of Every Line Item Possible For Siding Jobs From Insurance Cos.? Ed the Roofer Windows, Siding and Doors 0 08-27-2008 08:20 PM
Line levels Tscarborough Masonry 26 03-15-2008 12:58 PM
So I was popping a straight line today.... wallmaxx Framing 10 01-22-2008 09:23 AM
Straight Horizontal Line Speer007 Carpentry 17 12-15-2006 06:26 PM
