Curt
Guest
Posts: n/a
Plumbing Question
I have a dilemma. My bathroom tub faucet is dripping and I can't budge the allan key screw to fix it. I've had a plumber in to take a look, he can't budge it and says he's going to have to go in from behind to fix it...put a hole in the wall and take it out that way. Is there any other way to do it, like trying to drill the allan key screw out?
#2 | |
Unregistered
Guest
Posts: n/a
Re: Plumbing Question
There's a bunch of thing's I've tried over the years. You could try tabasco sauce (eats away the corrosion) or even soldering flux and heat. It all depends if you can get replacement parts for it. If you can, you can get quite destructive, as long as you don't damage the valve body. If not.... you need to be careful!
Good Luck! Quote:
#3 | |
gunslinger
Guest
Posts: n/a
Re: Plumbing QuestionQuote:
| under-slab plumbing / DIY | ruger9 | Plumbing | 28 | 03-09-2009 01:31 PM |
| plumbing codes question for new construction?? | national | Plumbing | 19 | 07-12-2007 05:54 AM |
| boiler plumbing question | 72chevy4x4 | HVAC | 2 | 05-06-2007 08:26 PM |
