Plumbing In Exterior Wall
Old 03-07-2011, 07:08 PM   #1
coyotehills's Avatar
Rewards Points: 18
Have customer that wants to convert a soaking tub area to a5'x7' walk in shower. The tub area is partially in a bump out along the 7' side. To place the supply lines in middle of the of the 5' side they would be located in an exterior wall. I do not want to do this as it can get kinda cold in Missouri. Would I run into freezing problems and or moisture issues (mold) if I placed a full 2x4 wall in front of the exterior walls. The supply lines and mixing valve would the be placed in one of the wall bays of new wall. Thanks for any advice.
coyotehills is offline
Old 03-07-2011, 07:17 PM   #2
I'm on a boat!
J L's Avatar
Trade: Yacht carpenter
Rewards Points: 3,440
Re: Plumbing In Exterior Wall
That's what we would do down here in GA. If you frame up a second stud wall in front of the other one and insulate it, make sure you remove the vapor barrier on the existing insulation in the exterior wall. The new insulation would then have a vapor barrier.
I can't speak for how this would work in Missouri though.
J L is offline
Old 03-07-2011, 07:32 PM   #3
Rewards Points: 18
What if I left existing wall intact and placed new wall in front of same?
Old 03-07-2011, 07:36 PM   #4
Future Post Deleter...
rex's Avatar
Trade: Nothing
Rewards Points: 1,092
what does the plumber have to say about it????
rex is offline
Old 03-07-2011, 07:36 PM   #5
I'm on a boat!
J L's Avatar
I wouldn't if you plan on insulating the new interior wall. The vapor barrier from the exterior wall needs to be removed if the interior wall is to be insulated. Leaving the vapor barrier on the exterior wall could trap moisture in the insulation between the 2 vapor barriers and lead to mold and rot.
At the end of the day it's not a lot of additional work to remove the wall coverings and do it right.
J L is offline
Old 03-07-2011, 07:43 PM   #6
MplsGC's Avatar
Rewards Points: 25
I think you would want to be sure how well insulated that existing wall is and this is almost impossible to do by just looking at it. You could have a home inspector with a thermal image camera take a look for you. Probably cost you a couple hundo. One little bypass could freeze those pipes. I wouldn't risk it. If you have room you could put a layer of rigid foam over the exiting wall then build your new wall. Although you may run into moister issues doing this. Good luck!
MplsGC is offline
Old 03-07-2011, 07:52 PM   #7
Rewards Points: 18
Is this the consensus?
1. Remove existing drywall
2. Remove existing vapor barrier
3. Insulate old and new cavities properly
4. Install new vapor barrier to new wall
5. Install 1/2" cement board
Old 03-07-2011, 07:55 PM   #8
I'm on a boat!
J L's Avatar
#1 - Consult your plumber on methods for exterior wall plumbing in your area.
#2-#6 as you have listed.
J L is offline
Old 03-07-2011, 07:57 PM   #9
TimNJ's Avatar
Rewards Points: 2,698
Run your water lines on top of the insulation so the pipes are right behind the wallboard. The heat loss through the drywall should keep the pipes above the freezing point. And don't run them through any studs if possible.
TimNJ is online now
Old 03-07-2011, 11:54 PM   #10
Smatt's Avatar
Trade: Plumber
Rewards Points: 152
Spray the exterior walls with spray in insulation as extra insurance. Can not hurt.
Smatt is offline
Old 03-08-2011, 04:20 AM   #11
Guy who makes things
UALocal1Plumber's Avatar
Trade: Plumbing
Rewards Points: 254
Do not run plumbing in exterior walls
UALocal1Plumber is offline
Old 03-08-2011, 05:33 AM   #12
General Contractor
greg24k's Avatar
Rewards Points: 7,358
Rule of thumb, never use plumbing in the exterior walls.
greg24k is offline
Old 03-08-2011, 06:42 AM   #13
I'm on a boat!
J L's Avatar
How about an interior wall framed up against an exterior wall? Our plumbers here approve that method but freezing is not as big of a concern here as it is up north.
J L is offline
Old 03-08-2011, 06:51 AM   #14
Mike's Plumbing's Avatar
Trade: ooo
Rewards Points: 2,000
We do this in Wisconsin and it works. I don't like to do it and I wont warranty anything on outside walls so I have them sign a disclaimer with the understanding the sacrificing common sense can have consequences.
Mike
see ya!
Mike's Plumbing is offline
The Following User Says Thank You to Mike's Plumbing For This Useful Post:
J L (03-08-2011)
Old 03-08-2011, 07:14 AM   #15
General Contractor
greg24k's Avatar
If weather is not a concern, you can run the pipes on the outside. If you have seasonal weather changes and temperatures dip to single digits and can stay for long period of time, no plumbing should be installed in the exterior wall. You can build the wall up, you can insulate pipes and walls, double walls, foam the wall cavity... but the rule of thumb remains the same. Even if you run the water pipes inside of a garage, if a bathroom is located over the garage and has a shower or a sink on the exterior wall, the water line projection should be from the floor and not the wall.
greg24k is offline
J L (03-08-2011)
Old 03-08-2011, 08:14 AM   #16
MplsGC's Avatar
Rewards Points: 25
Are you talking both supply lines and DWV? Ideally no plumbing in exterior walls but is it more expectable to run DWV in exterior? How about just vents?
MplsGC is offline
Old 03-08-2011, 09:27 AM   #17
Thom
thom's Avatar
Rewards Points: 4,748
You don't want the water spraying on the door if you can help it. convince the customer to put the shower head on the interior wall adjacent to the commode and angled into the shower room. If you want a shower head on each side, put the water lines on the wall the door is on, one on each side of the door, and run lines to personal showers on the adjacent wall.
There is one more possibility. If the client really wants shower heads, not personal showers, and really wants them on the exterior walls as shown in your picture, put the controls on the interior wall, adjacent to the door with the shower line only going into the exterior wall. Use a tub/shower control with a tub spout on the wall below the controls so that when the water is turned off the shower line drains.
thom is offline
Old 03-08-2011, 04:44 PM   #18
Trade: Plumbing
Rewards Points: 254
There's really only one way to say this: Do not run plumbing in exterior walls.
Keith
Old 03-08-2011, 04:57 PM   #19
Rewards Points: 18
Thanks to everyone for your great input and suggestions. I'm meeting with the customer tonight and will let them know that they want the shower heads on the interior walls as close to center as possible. I think with an articulated shower arm the head can be positioned near center but the plumbing will be safe in an interior wall,
Thanks
Old 03-08-2011, 06:59 PM   #20
Smatt's Avatar
Trade: Plumber
Rewards Points: 152
Thanks
If they want a shower head on the exterior wall install a hand held on a slide bar. Put in a six port valve with a standard shower head in conjunction with the hand held.
Though I agree I frown against the shower head raining on the door discourage this strongly with the water lines on the outside wall.
Smatt is offline
Walmarts Got Some Great Prices on Plumbing Supplies Wethead Plumbing 82 06-18-2012 10:55 AM
Looking for Plumbing or Landscaping work in Central Arkansas. Joshd123 Help Wanted or Looking For Work 0 03-03-2010 08:13 AM
plumbing and electrical permits johnisimpson General Discussion 13 12-09-2008 07:06 PM
DIYers in the Plumbing Forum 22rifle Plumbing 49 06-22-2008 11:42 PM
Plumbing Warranty Issues -- who's fault is it? Pineflakes Plumbing 2 05-19-2008 09:58 AM
