Plumbing Codes?
Old 01-06-2007, 08:28 PM   #1
Pro Plumber
Ron The Plumber's Avatar
Trade: Plumber
Plumbing Codes?
Thought it would be nice to know about other areas.
In Oregon water service has to be buired 12" below frost line, frost line here is 12", so min depth on a service is 24".
What is it where your at?
Ron The Plumber is offline
Old 01-06-2007, 08:34 PM   #2
kennewickman's Avatar
Trade: General/Plumbing Contractor
Re: Plumbing Codes?
Washington, min. 24" We usually go 36" here in eastern WA, gets a little colder than on the west side of the state.
kennewickman is offline
Old 01-06-2007, 08:34 PM   #3
mdshunk's Avatar
Re: Plumbing Codes?
12" below frost depth. 24 + 12 =36" min burial depth.
mdshunk is offline
Old 01-07-2007, 01:20 AM   #4
QWIKWHIP's Avatar
Trade: Heating, Cooling & Plumbing
Re: Plumbing Codes?
12" below frost line here as well. 48" + 12" = 60"
JCW Residential Services
Heating - Cooling - Plumbing
QWIKWHIP is offline
Old 01-07-2007, 01:23 AM   #5
mdshunk's Avatar
Re: Plumbing Codes?
Now that's a deep water line. Wonder what the guys in Canada do? They must bury their water lines somewhere near the core of the earth.
mdshunk is offline
Old 01-07-2007, 04:33 AM   #6
gitnerdun's Avatar
Trade: plumber
Re: Plumbing Codes?
In Fl 12" is the standard practice, but the code does not specify. Yeah, I know, we got it so easy. I use a 3" wide shovel to dig 'em in. Remember, we get 95 degrees in summer with 90% humidity, yuk!
gitnerdun is offline
Old 01-07-2007, 01:40 PM   #7
Mark Twenhafel's Avatar
Trade: resi elec newbie
Re: Plumbing Codes?
Here in Tucson there is no frost line, 'cept at the top of nearby Mt. Lemmon (9157 ft), where the frost line is 24".
Minimum depth is 2 ft for water, 3 ft for sewer, they can be joint trenched and 1 ft sand embedment required for each.
Mark Twenhafel is offline
Old 01-09-2007, 08:46 PM   #8
Pro Plumber
Trade: Plumber
Re: Plumbing Codes?
In Oregon, EQ straps are required, two straps on 65gal and lower and 3 straps on 80gal and 120gal gal tanks.
What does your code require, if any straps at all?
Old 01-10-2007, 12:48 AM   #9
K2's Avatar
Re: Plumbing Codes?
Colorado Springs were 5' for water lines and 6 ' in some parts of our county.
No minimum depth for sewer. WTF? you get a little blockage in a pipe that is buried 2" at -30 degrees f and your ucked.
Everybody burries the sewer 5 ft anyway but some things are hard to understand.
K2 is offline
Old 01-10-2007, 12:51 AM   #10
It is what it is
doubleaction's Avatar
Trade: Roofing, Remodeling, Concrete
Re: Plumbing Codes?
Our frost line is 42"
doubleaction is offline
Old 01-10-2007, 08:18 PM   #11
MR7853's Avatar
Trade: plumbing
Re: Plumbing Codes?
42" cover for water, 24" for sewer.
MR7853 is offline
Old 01-12-2007, 03:51 PM   #12
plumber jay's Avatar
Trade: plumbing
Re: Plumbing Codes?
To start i will say that i live in Ontario canada. Our plumbing code is quite different than anywhere else in Canada or the States.
My code states (in short)
It is impractical to bury water service below frost line so
1 insulation is formed to fit around and encapsulate the pipe or
2 a sheet of insulation at some level above the buried pipe.
the width of a sheet of insulation may be calculated using the following formula
Width of insulation
W= D + 2 (f-x) -0.3
W = width of insulation (metric)
D =outside diameter of pipe (metric)
X = insulation Depth (metric)
F = estimated frost depth (metric)
I do not do this type of work and i am not really sure if the guys around here follow this confusing formula
plumber jay is offline
Old 01-14-2007, 08:29 PM   #13
Pro Plumber
Trade: Plumber
Re: Plumbing Codes?
New code book says 2 staps, thats all water heaters
Old 01-16-2007, 11:52 PM   #14
Moonray's Avatar
Trade: Plumbing
Re: Plumbing Codes?
30" water service in Ky + 18" for sewer.
Moonray is offline
Old 01-17-2007, 08:31 PM   #15
gitnerdun's Avatar
Trade: plumber
Re: Plumbing Codes?
What is frost?
under-slab plumbing / DIY ruger9 Plumbing 28 03-09-2009 01:31 PM
plumbing codes question for new construction?? national Plumbing 19 07-12-2007 05:54 AM
Difference in Plumbing up north Vs. south jdrew6788 Plumbing 3 10-02-2006 04:59 AM
Locating plumbing in an outside wall Mike Finley Plumbing 15 09-09-2006 07:49 AM
NJ plumbing codes santehnik Plumbing 0 03-06-2005 09:10 PM
