Plugging Sewer Pipe That Is To Be Retired
Old 07-05-2006, 03:11 PM   #1
personalt's Avatar
Trade: GC/Developer
I am doing some excavating on a job where I exposed two old 4 inch sewer pipes entering the house through the foundation wall.
I normally leave it for the plumber to cap but he takes this week for vacation. The plumber is doing new mains so we cut this back to right where it enters the foudation.
I have a 4 inch test plug in there now but what is the best way to retire this pipe good? The plug is doing an okay job but because the pipe isnt in the greatest shape during the last rain the backed up sewer water pushed past and flooded the site.
do I just cap this with a rubber cap or do I fill the end of the pipe with something?
personalt is offline
Old 07-05-2006, 04:06 PM   #2
jmic's Avatar
Re: Plugging Sewer Pipe That Is To Be Retired
Person,
You didn't mention what kind of pipe it was, in any case I'd clamp a 4" fernco cap on it, you could also mix a little concrete and pour over after installing the fernco but I really don't see a need for it.
Joe
jmic is offline
Old 07-05-2006, 04:11 PM   #3
personalt's Avatar
Trade: GC/Developer
4" cast iron. The issue with the fernco is that the pipe is got so much crude on it, the pipe isnt really round.
When I did a switch from cast to PVC in my house I hit it with the grinder to clean it up but that was a pain in the ***.
Is there something that could go inside to plug it? ie stick a rag light material inside and push it maybe a foot down and then put concrete in the pipe? The only issue with that is I would almost have to drypack it since it would otherwise just leak out.
Old 07-07-2006, 12:16 AM   #4
Gmads's Avatar
Trade: Utility Contractor
You could use a 4" butterfly plug. It fits inside the pipe. Picture an oreo cookie with a bolt thru it and a butterfly nut. Tighten the butterfly nut by hand and it will squeeze the filling (rubber gasket) to seal with the inside of the pipe.
Gmads is offline
Drain Pipe denick Excavation & Site Work 18 07-12-2009 04:41 PM
3" sewer pipe? elarofcrankcase Plumbing 6 02-28-2007 08:37 AM
Sewer stub Moscow Plumbing 2 02-27-2007 05:18 PM
Sewer Odor in upstairs bathroom Mobylola Plumbing 5 10-31-2006 07:59 PM
SDR 35 PVC sewer pipe lengths dayexco Excavation & Site Work 17 05-15-2006 10:58 PM
