Trade: carpenter/ handyman
Plastic Toilet Bolts?
Maybe this is common now in new $300K+ homes, but it' a first for me. The toilet was rockin' & surprisingly, it wasn't the cheap bolt, but the plastic nut had cracked open? The toilets were also no-name Mexico products that seem to hold only a tiny amount of wax at the flange & even that little bit wants to squirt out the sides of the toilet when you seat it?
Steve |
#2 | |
The Grand Wazoo
Re: Plastic Toilet Bolts?Quote:
#3 | |
Pro Plumber
Trade: Plumber
And this question is what? |
Pro Plumber
Trade: Plumber
Made in Mexico.
Trade: Home Remodeling and Repairs
Manufactor keep bringing on that plastic materials and we will stay in business as a handyman.
thank-you |
Well Ron,
I was curious as to whether this was an isolated thing here is Texas or this crap was being install in fine homes throughout the country. So I figured that you yanks would enlighten me? Steve |
Pro Plumber
Trade: Plumber
Only plastic nuts and washers I've come across where for the tank to bowl, what a joke, don't recall the make of that toilet but I did not use them.
Allrounder Home Services
Trade: Painting, Remodeling, Handyman
The only plastic nuts/bolts I have seen or would consider using are for attaching the seat.
Trade: Plumber
I recall hearing something about plastic Johnny bolts, or maybe it was just the nuts.
I can't imagine anything plastic holding a toilet down without movement or problems cracking from tightening. |
Trade: Master Plumber
So you guys have not tried the newer /plastic closet bolts ???
They are pretty good ! Sioux Chief makes them ,,,,, yes the plastic nut can crack if you get real tight with it . However ,,,, After tightening , sitting on the bowl ,then a little more tight ,,, then silicone the bowl to the floor ,,, I have not had any trouble with these . Been using them 6-8 months ,,, NO CALL BACKS !! Just a different opinion . CP |
Trade: plumber
Thats all we use in the new homes now.We tested them in the shop and the screws holding the metal ring to the plywood ripped out before the bolts or nuts cracked !! I have not heared of any problems in the field either.
Do it like it was YOUR house !! |
Future Mod...
i too use them from the basic toilet change out to multi million dollar new houses and even have used them in light commercial....very easy to work with....although i still use chrome plated copper closet supplies
#13 | |
The Grand Wazoo
Trade: Plumbing
5/16 solid brass bolts here
#15 | |
Try 'em ,,, you'll like 'em ! |
#16 | |
The Grand Wazoo
I have bad visions of a loose toilet on the 36th floor of a condo building ruining the ceiling of the unit below.
Al Smith
so instead of paying the exorbitant price of like 3 dollars (or less) for a set of brass johnni bolts and nuts your getting the plastic ones for.....what?? Is this what your building your reputation on? And you were getting call backs for the brass ones? Time to do some firing of your staff i would say.
#18 |
Journeyman Plumber
Trade: Plumbing
obviously brass is superior , but the plastic saves a little bit of time cuttin the excess off..... and for the guy who does only high rise work .. do you really have to apply that to every post you make? even as subtly saying the 36th floor, that cracks me up
#19 |
Trade: Plumbing & Gas Contractor
Re: Plastic Toilet Bolts? |
#20 |
Trade: plumbing
| Is everybody using the toilet gaurd to keep subs from peeing in the toilet? | Mike Finley | General Discussion | 38 | 03-17-2008 10:36 AM |
| Toilet Challenge | Vermaraj | Plumbing | 40 | 11-09-2007 09:04 PM |
| Toilet Problems | McCall Builders | Plumbing | 4 | 01-31-2007 08:24 AM |
| Portable Toilet | AFI | Painting & Finish Work | 32 | 10-23-2006 12:19 AM |
| proper job replacing toilet? | soxfan | Plumbing | 4 | 12-31-2005 01:12 PM |
