Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Plumbing
Old 10-31-2009, 09:22 AM   #1
JonM's Avatar
Placing toilet
I did a job last week and it included a granite tile (12 x 12) floor...I will be having the toilet placed Tuesday....what, if anything, should be placed between the toilet and the floor. I have seen plumbers puty on regular ceramic tiles, but I wouldn't want to have the oils bleed into the granite tiles.
JonM is offline   Reply With Quote
Old 10-31-2009, 09:30 AM   #2
Chief hand holder
bert0168's Avatar
Trade: Residential Remodeling
I have seen the putty on floors before and IMHO it's done if whomever set the toilet isn't sure of the wax ring seal (read hack).
Looks like crap and I would be worried about oil bleed as well.
I would think if the floor is solid and flat it is unnecessary. If the floor isn't flat the toilet shouldn't be set until it is.
Bring on the plumbers!
bert0168 is offline   Reply With Quote
Old 10-31-2009, 09:32 AM   #3
Mellison's Avatar
Trade: Home Improvement General Contractor
I have seen plumbers use plaster,caulk and putty.
My preference has always been the same grout used for the floor.
"Enjoy Every Sandwich" Warren Zevon
Mellison is online now   Reply With Quote
Old 10-31-2009, 09:33 AM   #4
genecarp's Avatar
structolite
genecarp is online now   Reply With Quote
Old 10-31-2009, 10:46 AM   #5
The Grand Wazoo
KillerToiletSpider's Avatar
Trade: Plumber
They make putty that is safe for use on marble, granite, and other stone surfaces.
KillerToiletSpider is online now   Reply With Quote
Old 10-31-2009, 11:16 AM   #6
Chief hand holder
bert0168's Avatar
Not being a plumber, why would the toilet need to be puttied, grouted, caulked or otherwise sealed to the floor beyond the wax ring?
Old 10-31-2009, 11:43 AM   #7
The Grand Wazoo
Trade: Plumber
I don't use wax rings.
Old 10-31-2009, 11:51 AM   #8
Mellison's Avatar
The wax ring seals the "plumbing".
The other methods help, in addition to the jonnie bolts, fasten the bowl to the floor.
Old 10-31-2009, 01:24 PM   #9
Super B
skyhook's Avatar
Trade: General Contractor Lic. since 1984
Keeps to pee and cleaning chemicals out.
I run blue low tack tape around the base of the bowl and floor. Then poly-seam seal (caulk), press it in deep with finger, wipe off excess with a damp sponge, remove tape.
skyhook is offline   Reply With Quote
Old 10-31-2009, 01:45 PM   #10
Chief hand holder
bert0168's Avatar
OK. Makes sense to me. I still don't like the looks of ones I've seen.
But maybe I haven't seen one done properly yet. (or is that the point..................)
Old 10-31-2009, 02:47 PM   #11
Super B
skyhook's Avatar
The bowl might not always sit flat on the floor. In that case, sanded grout might be a solution. Everybody has seen toilets and urinals with a 1/2" of moldy caulking. Any gaps of more than 1/8" are better when filled with grout first, than a thin layer of silicone or good grade caulking to keep it in place.
New toilet plumbing donaldcarter55 Plumbing 5 05-21-2009 08:15 PM
Toilet install Jjheezy Plumbing 6 04-03-2009 08:52 AM
Employee clogs customers toilet hbelectric General Discussion 33 12-24-2008 07:25 PM
Is everybody using the toilet gaurd to keep subs from peeing in the toilet? Mike Finley General Discussion 38 03-17-2008 09:36 AM
Toilet Challenge Vermaraj Plumbing 40 11-09-2007 09:04 PM
