Pipes Squeeling---need Help
Hey guys, I'm having an issue with the water pipes in my home squeeling, this only happens when one of the three anti-scald tub/shower valves is being used, not with any other water source. any ideas and what might be going on.
A gun in the hand is better than a Cop on the phone !!! |
Trade: Plumbing & Gas Contractor
Re: Pipes Squeeling---need Help
If it's only happening at one valve it sounds like there may be something loose/out-of-alignment/broken at the valve,or a partially blocked port [such as solder].That's what I'd look for first.
Sorry, I should have worded it differently. it happens when any of the three valves is being used, not just one specific valve.
Is the diverter in the spout?
I have one that you can hear any where in the house when it's pulled up for the shower.
Pro Plumber
Trade: Plumber
Pressure increase on the house, have a PRV on this house? Could have gone bad. Test the pressure.
thanks guys, No reducing valve in the house (don't need one)
it happens on our shower valve (Delta anti-scald--shower only) our kids valve (delta anti-scald--tub/shower-- either spout or shower use) our guest bath valve (delta anit-scald---tub/shower--either spout or shower use).
Moderator
How old are these valves?
I've run into the pressure balance spool causing this problem on one shower. Replacing the spool solved this problem. There were two others just like it in the house, but they did not cause this situation when used. This was on a Delta 600 series faucet.
two of the valve are about 6 years old and the third is about 2 years old.
Trade: Plumbing
What is the water pressure and when did this start?
Pro Plumber
Trade: Plumber
Throw on a pressure gauge on the outside hosbibb and tell us what the pressure reads.
Moderator
If those valves are that new, then I'm with Ron. Check the incoming pressure to the house. Don't go off what anyone 'tells' you the pressure is unless they measure it.
You can buy a pressure test gauge from any good plumbing supply house for under $20.00 that will screw on any hose bibb.
| Ripping pipes | Bob Nelson | Plumbing | 1 | 02-14-2008 11:16 AM |
| Paint PVC vent pipes above roof? | DMC | Plumbing | 16 | 12-22-2007 08:33 PM |
| pipes sweating water | carp 101 | Plumbing | 4 | 01-14-2007 01:06 PM |
| CAC pipes freezing | meone | HVAC | 1 | 09-23-2006 08:58 AM |
| New Shower Pipes | eager2start | Plumbing | 3 | 08-22-2006 05:49 PM |
