Pipe Wrap To Stop Leaks. Does It Work
Old 05-11-2010, 07:22 PM   #1
rstarre's Avatar
Rewards Points: 93
Menards and Lowes sells a fiberglass pipe wrap for 20 dollars. It is suppose to work on copper and galvanized water pipes. There is suppose to be an expoxy on the wrap that creates a chemical reaction when expose to water, thus sealing the leak forever. Has anyone tried this product yet? I have a small dripping leak in a 1/2 inch copper water line. Since I have little experience installing copper water lines, do you have to take to copper elbow completely off to re solder it? Or can I just put new solder over the existing connection?
rstarre is offline
Old 05-11-2010, 07:27 PM   #2
Wood Butcher
bhock's Avatar
Trade: Remodels/Custom Cabinets/Granite Countertops
Re: Pipe Wrap To Stop Leaks. Does It Work
Not a plumber but I do know that you shouldn't just add solder to the joint. The solder will not suck into the joint and just be a bandaid at best.
bhock is offline
Old 05-11-2010, 07:36 PM   #3
BCConstruction's Avatar
Trade: Construction
Rewards Points: 2,394
As long as you can get most of the water from the pipe you could just heat the elbow and if your lucky get the solder to flow and seal but more than likely you will have to heat the elbow remove it then clean fitting and pipe then flux and resolder. Pretty simple as long as you can get the water out of the pipe. A wet and dry vac works very well for this.
www.bcconstructionllc.com
BCConstruction is offline
Old 05-11-2010, 07:38 PM   #4
AustinDB's Avatar
Rewards Points: 592
fiberglass tape to stop a leak in copper pipe sounds like an egg in the radiator...might get you to your destination, but you're still going to need a new radiator.
AustinDB is offline
Old 05-11-2010, 07:46 PM   #5
The Grand Wazoo
KillerToiletSpider's Avatar
Rewards Points: 1,864
Mighty Putty fixes everything.
KillerToiletSpider is offline
Old 05-11-2010, 09:16 PM   #6
rstarre's Avatar
Rewards Points: 93
I never used MIGHT PUTTY on anything. Does it really work?
rstarre is offline
Old 05-12-2010, 07:54 AM   #7
Trade: Construction
The crazy thing is that stuff does work. I used to use it years ago on my windsurf boards way before it was ever branded mighty putty. Stuff is super strong and goes of underwater. Dont know if i would trust it on a bad bit of copper though. Your prob asking for trouble.
Old 05-12-2010, 03:40 PM   #8
Blakely Home Solutions
robman1961's Avatar
Trade: plumbing repairs/handyman/home maintanence
drain water out of line and resolder or cut it out and use shark-bite fitting
You are the only one that can tell yourself you're a failure.
robman1961 is offline
The Following User Says Thank You to robman1961 For This Useful Post:
MACPLUMB (05-18-2010)
Old 05-12-2010, 03:47 PM   #9
Jaf's Avatar
Trade: Builder
Rewards Points: 250
Three options...
A) Call a plumber.
B) Drain water, remove fitting, flux and solder new fitting.
C) Wrap an old mop string around the leak.
a) wife's answer
b) my answer
c) grandma's answer
Jaf is offline
The Following 4 Users Say Thank You to Jaf For This Useful Post:
BuildersII (05-19-2010), MACPLUMB (05-18-2010), neolitic (05-12-2010), Tinstaafl (05-12-2010)
Old 05-12-2010, 04:57 PM   #10
tbronson's Avatar
Trade: Project Management
Rewards Points: 250
EB Green will save the day for you. Seriously. It will seal the leak for sure. If you can find some. Its used as a Damage Control tool on Navy ships and its better than 100 mile an hour tape we used to use. We called it that because even at 100 mph it wouldn't come off and make you loose your gear.
tbronson is offline
Old 05-12-2010, 05:27 PM   #11
AustinDB's Avatar
Rewards Points: 592
Originally Posted by tbronson View Post
EB Green
bubble head?
AustinDB is offline
Old 05-13-2010, 02:58 PM   #12
jrr02005's Avatar
Rewards Points: 75
The piece of bread trick works great too, for situations like this
jrr02005 is offline
Old 05-13-2010, 05:49 PM   #13
Trade: Construction
They make a synthetic version of that now. I bought some a couple years ago and never had to use it yet. So no idea how well it works. Just remember to remove the airators on the faucets before opeing the system back up.
Old 05-13-2010, 06:21 PM   #14
Construction Connoissuer
CCCo.'s Avatar
Trade: Construction Remodeling - Renovations Repairs
Location: Kirklin, IN "Proudly Serving Central Indiana Area"
Rewards Points: 1,320
Well pictures would definetly help,....But I would leave the super tape on the shelf for a desperate Hack.....
Any tom, dick, or harry can put in a sharkbite connector, elbow or watever you need,......for 7-10 dollars.
James Crow - Crow Contracting Company, LLC - Central Indiana Remodeling Contractor
Facebook l Youtube l Merchant Circle
Home, Kitchen & Bath Remodeling - ~ - Facility Maintenance & Repair Solutions
Want to contact us? - Call ~ 765.279.8271
CCCo. is offline
Old 05-13-2010, 06:42 PM   #15
tbronson's Avatar
Rewards Points: 250
Originally Posted by 72chevy4x4 View Post
bubble head?
No. Crunchy. But my uncle was a bubble head and during a family gathering where we were swapping stories I mentioned 100 mph tape and he topped me with EB Green. One of the things that stuck was that it was one of the most jacked items because of its utility. If Senior Chief's are poaching it then it must be damn fine stuff.
tbronson is offline
Old 05-18-2010, 11:45 AM   #16
jrr02005's Avatar
Rewards Points: 75
I didn't know that, whats it called and where can you get it. For all the repair and retrofits I do I would use it all the time
jrr02005 is offline
Old 05-18-2010, 12:39 PM   #17
boman47k's Avatar
Rewards Points: 2,006
Should he leave the tap open, to prevent pressure buildup? Hate the thought of a pipe exploding in someone's face. Of course, it may not be necessary in his situation.
boman47k is offline
Old 05-18-2010, 01:59 PM   #18
Trade: Construction
I bought the pack i have from Lowes. It's just called plumbers bread. It was with all the solders and fluxes.
Old 05-18-2010, 09:53 PM   #19
Paul
PrecisionFloors's Avatar
Trade: Hard Surface Flooring
Rewards Points: 1,004
Ha! This one made me laugh..sounds like our cans of vulcanizing tape. I was an Airdale Tweak for 6 years...
Precision Floors
(772) 237-9900
PrecisionFloors is offline
Old 05-19-2010, 02:15 AM   #20
BuildersII's Avatar
Trade: General
Rewards Points: 250
No. Solder doesn't stick well to an oxidized surface, which is why you have to clean even brand new shiny fittings (because the O2 in air causes a thin layer of oxidized copper on the surface that can cause a failure.) You have to pull everything apart, clean everything, flux (prevents oxidation because heat accelerates oxidation reactions) and solder.
As to some of the other comments about pipes blowing apart from heat if you don't open a faucet valve, I can't speak to that, but all the valves should be open anyway to accommodate drainage of the lines. Water in the lines will absorb all of the heat and not allow the copper to get hot enough to solder.
BuildersII is offline
PITA customer telling me what to charge knothead Business 11 07-16-2009 05:57 PM
Do You Check Your Work katoman Electrical 40 05-28-2009 08:43 PM
looking for work, fema or site work. earthworks land Help Wanted or Looking For Work 0 04-07-2009 10:38 AM
plumber refuses to finish work Chris Simms General Discussion 7 03-25-2009 06:02 PM
