Pipe Dumps In Basement
Old 05-13-2008, 06:06 PM   #1
fourcornerhome's Avatar
Trade: home improvement contractor
I am starting a basement finish project. HO has washer and dryer on 2nd floor.The drain for the over flow pan (I guess you call it that), is on the wall and dumps on the basement floor. I am finishing the walls and can't leave the pipe there so my question...could I run the pipe to the drain by the furnace (2" drain with AC pipe going in )about 20' away or, to the sump pump about 50' away?
fourcornerhome is offline
Old 05-13-2008, 06:38 PM   #2
Plumber / Carpenter
Bill's Avatar
Trade: Virginia Building and plumbing contractor
Send a message via Yahoo to Bill
Re: Pipe Dumps In Basement
Most locals wont let you dump washer machine water on ground. I would try to find a waste line you could tap into
Is it beer thirty yet
Virginia Department of Licensing
Virginia Plumbing Codes
Bill is offline
Old 05-13-2008, 07:02 PM   #3
This is not washer water, just a safty over flow pan ,for a burst hose ,for example.
Old 05-13-2008, 07:07 PM   #4
Pro Plumber
Ron The Plumber's Avatar
Trade: Plumber
Drain it to where ever you see fit, but it has to go to a drain or to the outside.
Ron The Plumber is offline
Old 05-13-2008, 07:13 PM   #5
Plumber / Carpenter
Bill's Avatar
I was more or less thinking of if it overflowed or the tub leaked
Bill is offline
Old 05-13-2008, 07:23 PM   #6
Thanks guys,,,I was hoping the drain in the furnace room was OK because it was so much closer ,but because of it's size,I wasn't sure it was allowed.
Old 05-13-2008, 07:30 PM   #7
The washer is pumping into a wall box
now isn't it?
Bet that is less than a 2" hole?
Unless it's just a drip the damn pan
will over flow any way.
neolitic is offline
Old 05-13-2008, 07:37 PM   #8
Pro Plumber
Trade: Plumber
If the hose burst do you really think the water will spray into the pan only, the pan is no safety catch for a burst hose.
Pan under washer is meaningless IMO
Old 05-13-2008, 07:55 PM   #9
The Grand Wazoo
KillerToiletSpider's Avatar
Not if it is in a condo on the twenty fifth floor.
KillerToiletSpider is offline
Old 05-13-2008, 08:17 PM   #10
Workin' Hard & Havin' Fun
BreyerConstruct's Avatar
Trade: Deck Designer/Builder
But on the 18th, it's worthless! The threshold is floor 20, below, don't bother, above, better do it.
~Matt
BreyerConstruct is offline
Old 05-14-2008, 07:08 PM   #11
anyhow....thats what they got. I just want to make sure that I run this pipe properly so there are no disasters caused by me..I am surprised that the pipe was not in a drain allready.
Old 05-14-2008, 07:27 PM   #12
Pro Plumber
Trade: Plumber
Do you really think if a hose supply was to burst open that the pan will catch all the water. A pan will not contain all the spaying water, water will spay out in many directions and not just spray towards a pan.
The best thing one can use is the no-burst ss washer hoses, and in the case for the washer it's self going bad on the pump, then a pan would help out there, but not for a hose burst.
Old 05-14-2008, 07:37 PM   #13
The Grand Wazoo
We pipe all the way to the washer connection in copper, with a union on each side so that the washer can be moved.
Old 05-14-2008, 07:42 PM   #14
Pro Plumber
Trade: Plumber
Wow, interesting, never seen a washer hard piped to the connections. This is a first for me.
Old 05-16-2008, 10:08 AM   #15
OK,,,forget the burst hose..bad example..I'll rephrase the question.If you installed a tray under a washer in a 2nd floor laundry that drains past the 1st floor and into the basement,with a 1" pipe,and had two choices to run this pipe to,one being sump pump about 50' away or the floor drain in the furnace room at about half that distance,which would you choose? Correction on floor drain size..it is 3".
Old 05-16-2008, 10:15 AM   #16
Pro Plumber
Trade: Plumber
Dump to floor drain.
Old 05-16-2008, 10:29 AM   #17
Thanks Ron..I will do it today.
Drain Pipe denick Excavation & Site Work 18 07-12-2009 04:41 PM
Why basement & main on same system? Cache HVAC 5 05-15-2008 12:25 PM
Gas Pipe Question.... drbigfresh Plumbing 9 02-28-2007 03:51 PM
HELP! Basement floor disaster Profiter Construction 5 07-11-2006 09:01 PM
How to trace gas pipe? karma_carpentry Carpentry 15 11-30-2005 11:47 AM
