Pinhole Leak
Old 01-01-2018, 12:08 PM   #1
Renaissance Man
superseal's Avatar
Rewards Points: 5,362
Pinhole Leak
My neighbor called in a panic last week stating he found a leaky pipe just beyond the water meter in his basement so I shot over to see what was going on.
Turns out, he had a small pinhole leak behind a ground clamp where a metal screw had been in contact with the copper pipe and he was scheduled for meter replacement the following day.
I told him no worries as I applied a temp fix of rubber and a band clamp to stop the leak and told him as soon as the meter was replaced, i'll stop over and pull out the bad section of pipe and install new.
Well, as with any plumbing job...easier said than done once we discovered the only upstream valve in the house that could shut us down had a bent valve stem and seat washer that was all but gone...and would not shut off the water.
Back to the garage I go to find my curb key and out in the frozen tundra we go to find the curb stop. Once located and three times later of carefully rotating the stop back and forth, we got it to fully shut off.
I thought this might be a good time to whip out the Jet Sweat tool, but it turns out we didn't need it nor could we have used it since the supply line (K type soft copper) took a flowing bend right below the slab which would have prevented the tool from being inserted anyway.
While at the supply house I snagged myself some new guts for my own tub overflow assembly while I was there...wife went to take a bath the other night and discovered the linkage was broken.
Pinhole leak-img_4603.jpg   Pinhole leak-img_4604.jpg   Pinhole leak-img_4688a.jpg   Pinhole leak-img_4689a.jpg   Pinhole leak-img_4690.jpg
Pinhole leak-img_4692.jpg   Pinhole leak-img_4695.jpg   Pinhole leak-img_4697.jpg   Pinhole leak-img_4698.jpg   Pinhole leak-img_4705.jpg
supersealconstruction.com
superseal is offline
The Following User Says Thank You to superseal For This Useful Post:
overanalyze (01-01-2018)
Old 01-01-2018, 12:59 PM   #2
tjbnwi's Avatar
Rewards Points: 3,456
Re: Pinhole Leak
I had to look up the Jet Swet, might come in handy some day.
tjbnwi is online now
The Following 3 Users Say Thank You to tjbnwi For This Useful Post:
goneelkn (01-01-2018), Inner10 (01-01-2018), MarkJames (01-01-2018)
Old 01-01-2018, 05:11 PM   #3
Radical Basement Dweller
Robie's Avatar
Rewards Points: 11,528
Re: Pinhole Leak
Sure beats the heck out of a piece of bread...
Democrats are doing more to undermine our country than Russians could ever hope to.
Robie is offline
The Following 2 Users Say Thank You to Robie For This Useful Post:
Artworks (01-01-2018), overanalyze (01-01-2018)
Old 01-01-2018, 06:26 PM   #4
Always Learning
overanalyze's Avatar
Trade: Builder/Remodeler
Rewards Points: 900
Re: Pinhole Leak
That is friggin cool!
overanalyze is offline
Old 01-01-2018, 06:56 PM   #5
rrk's Avatar
Rewards Points: 1,906
Re: Pinhole Leak
they have been around a long time, at the plumbing supply places they are usually right over the counter. Along with the cutters to cut plastic pipe from the inside
rrk is offline
superseal (01-03-2018)
Old 01-01-2018, 07:29 PM   #6
tjbnwi's Avatar
Re: Pinhole Leak
I have a full set of the inside cutters, never seen the Jet Swet before.
Old 01-01-2018, 07:35 PM   #7
MarkJames's Avatar
Trade: Handyman Services
Rewards Points: 12,977
Re: Pinhole Leak
Or how about this one?
MarkJames is offline
The Following 4 Users Say Thank You to MarkJames For This Useful Post:
Bummie (01-02-2018), goneelkn (01-01-2018), overanalyze (01-02-2018), Robie (01-01-2018)
Need help finding a leak! Gary L Roofing 12 01-14-2014 03:28 PM
Do you think this will leak???? stombaugh85 Roofing 14 01-12-2013 07:38 AM
Pinhole leaks in copper pipe FStephenMasek Plumbing 16 11-08-2012 06:59 AM
Union pinhole leak Higgins Plumbing 1 02-22-2012 02:52 PM
Refrigerant Leak Detection Articles MechAcc HVAC 7 10-09-2009 04:42 AM
