Pilot Light On A.O. Smith Gas Water Heater Keeps Going Out
Old 09-07-2010, 09:51 PM   #1
dprimc's Avatar
Rewards Points: 590
The pilot light on my A.O. Smith gas water heater keeps going out. Happened several times last fall, then not at all over the summer. The weather has started to cool with a few cooler nights and the pilot was out again today?
Trying to determine if this is worth trying to repair or if I should just install new. When the light stays lit, it works great. I already replaced the thermo couple last year and that seemed to have no effect on things.
Online search brings up pages of people with similar issues. Just trying to get more professional advice.
Any feedback from those more educated in such things would be appreciated.
Model FDV 50 216. Dated '02.
dprimc is offline
Old 09-07-2010, 09:53 PM   #2
Wood Butcher
bhock's Avatar
Trade: Remodels/Custom Cabinets/Granite Countertops
Re: Pilot Light On A.O. Smith Gas Water Heater Keeps Going Out
If the new thermocouple didn't help there is a good chance its the gas valve itself.
Brett Hocking
Eagle Eye Construction/Aspen Custom Cabinets
Buffalo, WY
bhock is offline
Old 09-07-2010, 11:03 PM   #3
Future Post Deleter...
rex's Avatar
Trade: Nothing
Rewards Points: 1,092
welp your outa warranty....for the price of a new one id say replace it...40-50 standard vent nat gas heaters are cheap...try to get the same brand so the replacement will be eaiser
rex is offline
Old 09-07-2010, 11:17 PM   #4
dprimc's Avatar
Rewards Points: 590
After all the crap I've read about AO Smith I'd rather finds something else with a similar configuration.
Guess I was just hoping it could be fixed.
dprimc is offline
Old 10-03-2010, 11:51 AM   #5
General Contractor
ASMCHICO's Avatar
Trade: Multifamily Maintenance/Remodel
We see that a bit. In some models, the air intake screen on the bottom of the unit gets dirty & starts snuffing the pilot light when the burner cuts off. We made a funny little vacuum attachment & can usually clean the filter and solve the problem. Blowing the filter with compressed air from the burner side works ok too. Look at a diagram, I'm not talking about the combustion screen, there is another filter below the burner.
Good luck.
I know of an easier way to give the stupid thing more air, but I don't do it because of liability issues.
ASMCHICO is offline
The Following User Says Thank You to ASMCHICO For This Useful Post:
dprimc (10-03-2010)
Old 10-03-2010, 12:11 PM   #6
The Grand Wazoo
KillerToiletSpider's Avatar
Rewards Points: 1,864
Hot water is over rated.
KillerToiletSpider is offline
Old 10-03-2010, 12:13 PM   #7
dprimc's Avatar
Rewards Points: 590
Not at my house. Now when talking to the clients.....
dprimc is offline
Old 10-10-2010, 01:21 PM   #8
regionalserv
regionalmech's Avatar
Trade: plumbing and heating
if your shure it's not the thermocouple check to see if you are getting any back draft. also dependant on model there is a flame sensor you can oohm out and make shure that your getting a good reading
regionalmech is offline
Sparky needs advice with leaking water heater RJS3rd General Discussion 15 08-05-2010 10:35 PM
indirect water heater v.s. tankless world llc Plumbing 31 02-02-2009 10:28 AM
Water Heater noises & air sputtering at faucets LarryS Plumbing 10 01-10-2009 09:41 PM
Hot Water Heater making loud sound and vibrating the entire wall BKFranks Plumbing 9 10-27-2008 09:58 PM
Downsize a water heater thom Plumbing 4 10-15-2008 07:19 PM
