Pilot Light Goes Out.
Old 11-22-2017, 08:48 AM   #1
flashheatingand's Avatar
Trade: H.v.a.c.
Rewards Points: 3,474
I had a quirky service call that lasted awhile.
Originally, the issue was a pilot light issue. 12 year w/h. Thermocouple was corroded, and there was a bunch of rust on the burner assembly... Changed out the thermocouple, cleaned the pilot & burner, and all was good for about two weeks. Customer decided to just replace it.
Two days later pilot out.. Rel-it, checked gas pressure, with all other appliances fired, and it checked out. Hmmmph. Weird,....
About another three days, and no hot water. This time, I noticed puddling by the w/h nipples....no leaks. Relit, and called the tech service for any ideas. They sent me a new valve. I did not use it, as I found something that was amiss. Addressed this issue, and haven't had a call back since.
Any idea of what it could be? I won't leave folks hanging forever, just something one should check within a mechanical room.
http://www.37flash.com/
flashheatingand is offline
Old 11-22-2017, 08:03 PM   #2
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 1,873
Re: Pilot Light Goes Out.
Not much to go on there. Exhaust duct/chimney?
Tinstaafl is online now
Old 11-22-2017, 09:35 PM   #3
Trade: H.v.a.c.
Answer was a lack of combustion and dilution air. The grills were there. I figured that maybe the sheet-rock guys covered them up inside. But, when I removed the exterior grills, I saw screens that were completely blocked with dust/dirt.
Never seen that before. As this was one of those, narrow row-houses
(built in the late 90's early 00's), with the furnace and w/h in mechanical room, out back.
Frequently it's those simple things. Probably wouldn't hurt to inspect grills in those setups.
The Following User Says Thank You to flashheatingand For This Useful Post:
SmallTownGuy (11-23-2017)
Old 11-22-2017, 09:57 PM   #4
Capra aegagrus
Tinstaafl's Avatar
That's some pretty impressive choking; I never ran across that either. Seen plenty of pilots blown out by downdrafts, though.
Old 11-22-2017, 11:14 PM   #5
Randy Bush's Avatar
Trade: Exterior Remodeling
Rewards Points: 870
In the past on my own stuff because of where the W/H was I ran a vent pipe from outside right down close to the burner to make sure it gets plenty of fresh air. Never have had any problems. Figured it could not hurt anything.
Randy Bush is online now
The Following User Says Thank You to Randy Bush For This Useful Post:
flashheatingand (11-23-2017)
Old 11-23-2017, 10:09 AM   #6
Trade: H.v.a.c.
The key was puddles by the w/h nipples. The fittings were not leaking, so I knew the moisture had to be coming from somewhere... Which led to the thought that it had something to do with the fire and exhaust.
In retrospect, I probably should have removed the screens altogether. After all, it was a mechanical room, sealed from the living quarters.
Tinstaafl (11-23-2017)
Double pole single throw light switch? Philament Electrical 2 09-20-2016 07:25 AM
Sizing a Pole Light Base 5.4Lariat Architecture & Design 0 05-31-2012 01:45 PM
Door jamb light switch Jer Electrical 19 08-29-2011 07:48 PM
Pilot Light on A.O. Smith Gas Water Heater Keeps Going Out dprimc Plumbing 7 10-10-2010 01:21 PM
ceiling fan light won't go on jhcontracting Electrical 11 07-17-2010 08:22 PM
