Pex Vs. Cpvc
Old 02-15-2009, 03:27 PM   #1
mrhbuilder's Avatar
Trade: home builder
Pex Vs. Cpvc
Getting ready for another new house, again the choice pex or cpvc. I've used both in the past without any major problems. Would like to know from the pro's , after everything is said and done which one comes out
ahead? Cost is not a factor to me, mainly long term performance.
Thanks for your help....
mrhbuilder is offline
Old 02-15-2009, 08:53 PM   #2
PLUMBINGITALL's Avatar
Trade: PLUMBING/ MECHANICAL LIC SC
Re: Pex Vs. Cpvc
I would use cpvc just because i have had no promblems in the past and the way we run pex with manafolds you can make the cpvc look alot better.
PLUMBINGITALL is offline
Old 02-15-2009, 08:58 PM   #3
KemoSabe
loneframer's Avatar
Rewards Points: 12,202
Re: Pex Vs. Cpvc
I kinda like being able to shut down fixtures from the manifold location, even though it's not as neat and clean. Pex by a small margin.
loneframer is offline
The Following User Says Thank You to loneframer For This Useful Post:
mrhbuilder (02-16-2009)
Old 02-15-2009, 09:17 PM   #4
PA woodbutcher's Avatar
Rewards Points: 1,000
Re: Pex Vs. Cpvc
High end? Why not copper if cost is not a factor. I've repaired more pvc then copper in the past 10 years and copper has been out the a whole lot longer.
When you rob Peter to pay Paul, chances are pretty good you will receive Paul's vote. Apparently the object of the game is to create more Pauls than Peters....What happens when the Peters can no longer support the Pauls? .
PA woodbutcher is offline
Old 02-15-2009, 09:43 PM   #5
threaderman's Avatar
Trade: Plumbing & Gas Contractor
Re: Pex Vs. Cpvc
Even though I like CPVC,nowadays I normally do a pex/copper hybrid.Pex for everything that's not exposed ,and then stub out and trim with copper.
threaderman is offline
The Following User Says Thank You to threaderman For This Useful Post:
Old 02-16-2009, 12:27 AM   #6
AutumnWood Inc.'s Avatar
Trade: Deck Builder
Rewards Points: 550
Re: Pex Vs. Cpvc
I think CPVC is more difficult to work with, and if it ever freezes it cracks badly...... Pex installs easier, no glue, can freeze and usually never breaks
AutumnWood Inc. is offline
Old 02-16-2009, 12:28 AM   #7
Joemel's Avatar
Trade: Power Jack Foundation Repair
Re: Pex Vs. Cpvc
I understand Pex has volume restrictions when the fittings are installed so most of the fixtures have to be home runs (back to a central manifold). Good news, this eliminates a lot of joints in the walls, bad news is a lot of material is used and bundles of tubing take up space in the walls, joists, soffits etc. It would seem 10 or 12 home runs to the other end of the house to catch a couple of bathrooms may eliminate the cost savings vs. one 3/4 copper line.
I've heard (from local plumbing board official studying whether to allow the stuff in our area) pex does not perform well when water has high chlorine, so it may not be right for some municiple water systems.
It seems most plastic tubing, fittings etc, have some type of recall, weakness, failure over time. It would be nice to know how this stuff will be performing 10-40 years from now. I know copper is tried and true.
building a french drain maybe a mind numbing task but you can just leave it to the experts~
Joemel is offline
Old 02-16-2009, 03:02 PM   #8
plumber1a's Avatar
Trade: plumbing
Rewards Points: 75
Re: Pex Vs. Cpvc
Pex makers claim to have systems in use today that are 30+ years old with no problems..
plumber1a is offline
Old 02-16-2009, 05:02 PM   #9
mrhbuilder's Avatar
Trade: home builder
Re: Pex Vs. Cpvc
I have copper in my house, but down here in my area the water wears down the pipes, some paper thin after 15 years, I have to play it safe
with plastic...
Old 02-18-2009, 07:42 PM   #10
the pipe master
protechplumbing's Avatar
Trade: plumbing, solar
Rewards Points: 502
Re: Pex Vs. Cpvc
Ever see what happens to cpvc when the bug guys get their chemicals on it? It melts. cpvc is effected buy petroleum based solvents. Paints, caulks, all kinds of things destroy cpvc. When it bakes in the heat of an attic for about 10 years it becomes extremely brittle.
Plumber, Repiping, Replumbing, Leak Detection, Solar Water Heater, Polk County Plumber, Lakeland Plumber, Winter Haven Plumber
protechplumbing is offline
Old 02-18-2009, 10:09 PM   #11
Pro Plumber
Ron The Plumber's Avatar
Trade: Plumber
Rewards Points: 2,000
Re: Pex Vs. Cpvc
Pex baby, you better use pex, if you have any clue at all.
Ron The Plumber is offline
Old 02-19-2009, 06:17 PM   #12
mrhbuilder's Avatar
Trade: home builder
Re: Pex Vs. Cpvc
Looks like pex....................
Old 02-19-2009, 08:00 PM   #13
the pipe master
Rewards Points: 502
Re: Pex Vs. Cpvc
A picture is worth a thousand words........
Old 02-19-2009, 08:38 PM   #14
Burritos
bamawildcat's Avatar
Trade: Lectrical
Rewards Points: 27
Re: Pex Vs. Cpvc
Looks like a homeowner and his glue monster got a hold of that.
bamawildcat is offline
Old 02-19-2009, 09:10 PM   #15
the pipe master
Rewards Points: 502
Re: Pex Vs. Cpvc
The pipe melted after being sprayed with bug spray from the exterminator.
Old 02-21-2009, 07:57 PM   #16
PARENOS's Avatar
Trade: Environmental Contracting, General Contracting
Rewards Points: 150
Re: Pex Vs. Cpvc
I have just had a fight with a CPVC system, and am not a fan. It is easy enough to install, but when you have to fix it you start a nasty cycle of cutting back and installing more and more couplers and t's. IMHO I would use PEX wirsbo. It will expand and you will not have to worry about busted pipes from freezing, Also if you have a bad connection, all of the connectors are reusable, just cut out the piece, cut a new piece and set it.
PARENOS is offline
The Following 2 Users Say Thank You to PARENOS For This Useful Post:
mrhbuilder (02-22-2009), protechplumbing (02-21-2009)
CPVC underground NYCplumber.us Plumbing 21 06-07-2008 06:20 PM
Galvanized Copper ABS CPVC pscinteriors Remodeling 2 05-27-2008 07:58 AM
cpvc under a slab ? tzzzz216 Plumbing 16 11-14-2007 08:39 PM
CPVC bending radius Jess Plumbing 17 12-01-2006 11:33 AM
Cpvc OsNap Plumbing 8 11-03-2006 08:05 AM
