Pex Sizing
Old 04-21-2006, 08:29 PM   #1
MSSI's Avatar
Trade: Electrician
Pex Sizing
Although not up to speed on fluid dynamics.....Am i correct in deducing that running 3/4 pex is the same as 1/2 copper??/ I was looking at the fittings and it looks like the 1/2 fitting has an ID of about 3/8 and the 3/4 has about 1/2 in. So in essence the flow is restricted at the fittings. I dont have the best water pressure on this project and dont want to make it worse....Also do city water meters have any type of flow/pressue control or adjustment ??........Thanks
MSSI is offline
Old 04-21-2006, 10:22 PM   #2
reveivl's Avatar
Trade: Renovations
Re: Pex Sizing
I'm no fluids engineer either, but the restriction won't change the pressure, just the volume. Rich.
reveivl is offline
Old 04-21-2006, 10:44 PM   #3
MSSI's Avatar
Trade: Electrician
Re: Pex Sizing
yes pressure is pressure..but wouldt I get twice as much volume at 100psi than at 50 psi ??
MSSI is offline
Old 04-26-2006, 06:28 PM   #4
Heavy Weight Champ
King of Crown's Avatar
Trade: finish carpentry
Re: Pex Sizing
I'm about a 46d.
Real nice guys
King of Crown is offline
Old 04-26-2006, 07:02 PM   #5
Plumber / Carpenter
Bill's Avatar
Trade: Virginia Building and plumbing contractor
Send a message via Yahoo to Bill
Re: Pex Sizing
Well to tell you the truth most homes probably have 9 fixture units which could be served well with pex without noticing any pressure differential as opposed to copper or cpvc. Sometimes I will run 3/4" to up through the floor and use a 3/4 x 1/2 90 to come out of the wall with. The only time you will notice a difference is if you go with more than 200 foot of hot and cold (400 foot total) In most average homes as I said pex is fine. If you think you will have a problem with adaquit pressure there is a flow rate chart that I have to use in commercial plumbing (And in some residential) Tell me, how many fixtures will you be serving and what are they? These are anything that will use water. If I know this, I could calculate the size of the water main needed. As for the second part no, the city doe's not controll water pressure at the meter nor is there any way to adjust it unless you install a pressure regulator in line. But then again you do not need more than 35 to 50 lbs of pressure to run a house.
Is it beer thirty yet
Virginia Department of Licensing
Virginia Plumbing Codes
Bill is offline
Old 04-26-2006, 07:11 PM   #6
MSSI's Avatar
Trade: Electrician
Re: Pex Sizing
3 tubs- 1 shower stall- kitchen sink- cloths washer-wash tub- dishwasher front and back spicket..on a tankless..Thank you
MSSI is offline
Tricks to sizing a heat pump Danno6102 HVAC 1 06-28-2007 06:05 PM
Looking for quick easy answer of rafter sizing IHI Framing 22 07-23-2006 01:43 AM
deck beam sizing and post spacing? diyerforever Decks & Fencing 5 05-10-2006 10:58 PM
primer/sealer or sizing steeleroller Wallpaper 3 03-09-2006 04:33 PM
Sizing duct questions goalmakers HVAC 1 02-24-2006 03:36 PM
