Pex Rings
Old 06-30-2007, 09:54 PM   #1
Plumber's Avatar
Trade: plumber
Pex Rings
I use the stainless steal rings (zurn,wirsbo bow ties) instead of the copper painted black ones( zurn, vangaurd) I heard from one of the suppliers I use , Said that all pex manufactures are going to do away with the stainless steal ones do to: That they lose their tenstion and start to leak. Have you guys heard of this in your areas? I was thinking of all the house I plumbed with those rings
QP
Plumber is offline
Old 06-30-2007, 10:33 PM   #2
Grumpyplumber's Avatar
Trade: Plumber
Re: Pex Rings
QP
I think of PB...thats all I can say...the whole PB thing years ago.
I might be losing money not using PEX, but I'm willing to. For now.
Grumpyplumber is offline
Old 07-01-2007, 06:50 AM   #3
Pro Plumber
Ron The Plumber's Avatar
Trade: Plumber
Re: Pex Rings
I have not heard of this, give us a link.
Ron The Plumber is offline
Old 07-01-2007, 07:42 AM   #4
just a dumb plumber
crb555's Avatar
Trade: Plumbing / HVAC
Re: Pex Rings
From reading the other posts concerning pex pipe... I know that I am in the minority here. I suspect that I cannot change your minds about it, and I also suspect that I will not change my mind either.
Its my opinion that Pex is a great product, for a temporary water service.
I dont have much experience with it... then again, its not too often I have seen an engineer specify pex on a hospital addition, or a school.
I did see it specified on a Dialysis Clinic for potable water distribution (not the RO piping of course). I took it off (and got the job) in CPVC. This was in a county with hard water that makes copper impractical.
Crb5
crb555 is offline
Old 07-01-2007, 10:22 AM   #5
Trade: Plumber
Re: Pex Rings
Crb5
This is a situation where I'm hearing all good things about it, yet I still have to wimp out and "err on the side of caution" when it comes to fittings inside the structure.
Ten years from now I'll likely be slapping my forehead "I shoulda".
Old 07-01-2007, 02:11 PM   #6
Plumber's Avatar
Trade: plumber
Re: Pex Rings
I don't have a link about this I tried to research it today and found nothing! I think I might start to question all my suppliers and see what they have to say. Just out of curiousity what brand of pex piping do you other guys use? I mainly use Zurn. A company I use to work for used Vanguard. The great thing about about those 2 you can use the same black rings. What I like about Zurn there is 3 different type of rings you can use. black rings, Stainless steal like wirsbo used, and the new Stainless steal rings they came out with. They are like the wirsbo ones.(one tool does all sizes) except they cover the whole insert of a fitting and had a stopper on it. (So basically you know how the other ones slide down or up on you, )These slide on until they butt up against the end of the pipe and you slide in your fitting and No up and down movement I wish I new how to download pic on here I would show you if you never seen these ones. But I know for a fact they had a recall on these ones. So I went back to the other stainless steal ones.
Plumber is offline
Old 07-01-2007, 02:58 PM   #7
Trade: Plumber
Re: Pex Rings
All Wirsbo, with the expansion barbed fittings until recently I tried Zurn on baseboard.
Old 07-01-2007, 03:02 PM   #8
Pro Plumber
Trade: Plumber
Re: Pex Rings
Zurn and Aqua Pex here, we use the SS Rings here, I knew there was a new tool and ring out but until they switch totally over to the new tool, I'll stay with this one for now.
Old 07-01-2007, 06:45 PM   #9
Dragonheart's Avatar
Trade: General Contractor & Estimator
Re: Pex Rings
Does anyone have any recommendations of the best tools for working with Pex? I will probably go with the copper crimp rings.
Dragonheart is offline
Old 07-01-2007, 10:57 PM   #10
Future Mod...
rex's Avatar
Trade: Master Plumber
Re: Pex Rings
ive used both types of rings and i prefer the S.S crimp rings...i just recently did my first house completly in pex and it went quick...im still all about copper but if using pex gets me the job then ill do it....ive used pex in commercial buildings just to loop lines then pipe the rest in copper....BTW i use REHAU tubing
rex is offline
Old 07-02-2007, 04:18 PM   #11
Plumbing/Mechanical Insp.
Moscow's Avatar
Trade: plumbing/mechanical/building inspector
Re: Pex Rings
I see Wirsbo, Vangaurd, and Rehau here in Moscow. The clamp the plumber is talking about I think is called the RTI clamp it is not allowed here by Idaho state rule for the fact that they split and leak, However that could of changed because the state is not very good at telling plumbers what has changed in the code. I used Rehau in my houes I feel that it has a better joint but that is just my opinon. I would say that 90% of the plumbers here use vangaurd and Moscow will be a good testing ground because you will not find a new house that has been build in the last 5 years with out pex pipe in it. Guess if it fails like PE pipe did they lawers will make a good living in law suits.
Moscow is offline
Old 07-06-2007, 04:24 PM   #12
Plumber
All Clear Sewer's Avatar
Trade: Sewer Rat
Re: Pex Rings
I use the black rings because I want a complete cremp all the way around the fitting. I still dont like the uses of pex as I use to be a plumber for a trailer house mfg and now all that gray crap I installed over the years back in the 80`s is now making me money. I know this pex is gonna do the same thing
All Clear Sewer is offline
Old 07-06-2007, 09:51 PM   #13
JamesNLA's Avatar
Trade: Plumbing & Electrical
Re: Pex Rings
Your statment of "having a crImp all the way around" is just wrong. Silly actually. The black painted copper rings are not at all as good of a connection vs. the SS rings. If anything the copper is much softer than the SS and more prone to loosen over time.
"....And then we all switch places when I ring the bell"
-Adrock
JamesNLA is offline
Old 07-12-2007, 02:15 PM   #14
Plumber
Trade: Sewer Rat
Re: Pex Rings
I think your nutz Silly actually
the old gray had SS and it all leaks now
I want a 360 crImp
I`ll post pictures later as I have one to replumb today
Old 07-16-2007, 08:50 PM   #15
Plumber
Trade: Sewer Rat
Re: Pex Rings
Ok now tell me that a 360 crImp is not better
Old 07-16-2007, 10:44 PM   #16
Pro Plumber
Trade: Plumber
Re: Pex Rings
Thats the old quest pipe and rings, thats not in use today.
Old 07-16-2007, 10:56 PM   #17
JamesNLA's Avatar
Re: Pex Rings
This is the SS ring...I've never even used those other ones.
I might have better pics - gotta look...
-Adrock
JamesNLA is offline
Old 07-16-2007, 11:09 PM   #18
JamesNLA's Avatar
Re: Pex Rings
The only time I have had any issues with these SS crimps is when I had put them on wrong. If it's not correctly crimped right, it will leak. But that was my fault.
-Adrock
JamesNLA is offline
Old 07-16-2007, 11:12 PM   #19
Pro Plumber
Trade: Plumber
Re: Pex Rings
Attachment 6011
Are those the new rings Zurn has come out with?
Old 07-16-2007, 11:38 PM   #20
JamesNLA's Avatar
Re: Pex Rings
These are a little different than what I was buying 6-8 months ago. They have like little tabs that actually make it so the pex can't 100% butt up to the fitting. The pic of the 1/2" red is the new style, the mixing valve is the older style. I gotta bunch of pics of a tankless relocate I did last week. Came out nice, owner was a milf.....no complaints from me
-Adrock
JamesNLA is offline
Zern Changing Crimp Rings Ron The Plumber Plumbing 33 09-26-2009 04:22 PM
Rings? joasis General Discussion 24 05-12-2007 02:18 AM
Under mount sink rings woodmagman Kitchens & Baths 0 04-01-2007 01:14 PM
toilet wax rings AbeBarker Plumbing 8 01-15-2007 09:29 PM
new rings jmic Off Topic (Non Trade) 14 01-03-2006 01:25 AM
