Trade: Control Systems
Pex Question
Sorry for the ignorant post but I can't help to notice all the different ways I've seen pex terminated on jobsites. I've seen copper rings, stainless steel crimp rings (look like a mini version of CV boot clamps) and stretched pipe.
Are they all good or is there one that is clearly better then the rest? |
Trade: Home Repair
Re: Pex Question
Ive been using copper rings for a couple years now I just guage them and have had no problem. I now only use pex for my supplies and PVC on my waste.
Re: Pex Question
When I built my house in '99 the two choices I considered were copper, (too expensive + the freezing and busting thing) and pvc (easy to repair if necessary + price efficient) My plumber talked me into pex but I always had a bad feeling about it.
After ten years it looks like I wasted my worry on the pex. So far no trouble. I still use pvc in my remodels and additions though. Old habits I guess |
Trade: Construction
Re: Pex Question
I would always use copper over plastic. I have seen far to many plastic supplys fail. If copper is put in correctly and all pipes are insulated where they could freeze then you should have zero problems with copper. I know it takes longer to install but it's def a long term option. They have a system in the UK called speedfit and it's a twin walled design. They say that the fittings have an average lifespan of 15 years! Plastic is also affected by hot and cold cylcles a lot more tha copper and becomes brittle over time.
Trade: contractor
Re: Pex Question
inner10 I prefer the stainless ratchet clamps...one tool for all size clamps. Also they are easier to remove for repair...but I've only had to repair one. All the repair I've done is on copper.
Re: Pex Question
Thanks mics, I see this Wirsbo (or something like that) pipe that uses the expander, then the pipe shrinks over the fitting, it looked really positive. I guess they are all approved methods and just as good as the other; as long as its done correctly.
Not knowing anything about plumbing it was sort of a curiosity thing. |
Trade: contractor
Re: Pex Question
I tend to avoid wirsbo since their official attitude is to limit sales "plumbing contractors". I couldn't believe one supplier here asked me to get my plumbers business info before they would sell to me. I'm a general contractor and they wouldn't sell it to me directly.
Money Changer
Trade: Residential Remodeling
Re: Pex Question
I just did a repair consiting of removal of the corroded cold water piping in a basement.
Replaced it all with PEX. USed the stainless ratchet rings. This was the 3rd time I used it. First two the HO insisted on it for his hot and cold supplies as well as for a radiant system. I was skeptical then but 2 years now and no leaks. We used the sharkbite fittings for that. Mucho bucks! After this recent job with the rings and the reduced cost of installation, I probably won't go back to copper. I was impressed. |
Re: Pex Question
I ripped up part of my kichen and had to move some copper pipe around, I cut it popped on a shark bit cap and then when I was ready to re-hook poped it back off like nothing. I was blown away how easy they go on and off; very pricy but what a slick system!
Tech Geek
Trade: Property Management/Facilities Manager
Re: Pex Question
I've used both the ss ratchet and the copper rings. I like the copper rings because they're cheaper and look better, but they require different dies in my crimper for different sized pex. I like the SS ratchet because 1 tool does all sizes. It's a preference thing, I like them both the same.
Trade: Construction
Re: Pex Question
I noticed the other day that lowes now stock fitting like the speedfit type made by Vanguard. They are the most simple to remove and extremly secure.
Moderator
Re: Pex Question
Are these code approved by your local code? Just because Lowe's sells them bears in no way on their code approval.
As for a plumbing supplier not wanting to sell to a non-plumber, more power to them. They are picking their products and the client's they sell them to. What is wrong with that? Do yo have to be licensed to install plumbing in a home that you don't own in Alaska?
Trade: contractor
Re: Pex Question
No I hire and fire plumbers as it pleases me. I buy materials to build houses. It's another means the plumbing trade uses to flex its he-man mentality to protect a trade that can't stand on it's own merits without illegitimate means of coercion.
#14 | |
Trade: plumbing
Re: Pex QuestionQuote:
Trade: Construction
Re: Pex Question
I shouldnt see why not. They are basicly an upgrade to the sharkbite fittings but a lot easier to remove when serviceing. In the UK they are the only system that is used. The sharkbite type fittings tried to make a hit in the UK but they couldnt compette with the JG Speedfit. They aint cheap though.
#16 | |
Trade: contractor
Division 8 pro
Re: Pex Question
IMO... PEX Sucks... i know im going to get ALOT of
for this comment.. but i cant help it... the ONLY place PEX should be Allowed is in Mobile Homes. most plumbers will tell you the reason they use it is because its Quick and Easy to run. the problem comes when a home owner wants to add a dish washer or ice maker they are forced to hire a plumber to come in and install it. or go rent the correct tools to do it. so a 10 min job turns out costing 500 dollars. Stick with Copper or at least PVC.
"Don't be a fool and die for your country. Let the other sonofabitch die for his." ~ Patton |
#18 | |
Trade: contractor
#19 | ||
Division 8 pro
i know there are alot of pros as well... like ease of install so as to lower labor costs... the reason i like copper or PVC over PEX is ease of end use. PVC is dirt cheep and any one with a second grade education can make repairs. Copper costs alot more but it (like you said) looks better and is still easy to repair. Dont get me wrong, PEX has its place, mobile homes, under-floor heating... i just dont think it should be used in commercial construction. (hotels and motels)
#20 |
Trade: Renovations
Re: Pex Question
I don't get it, why is it bad for the ho? Crimping pex is harder than soldering Cu? Why would you as a gc worry about what is easier for the ho to repair or remodel...
Why is it ok in mobile homes but not elsewhere? Maybe I'm missing something, please explain.
| Question from lawyer trying to help contractor | scp | Business | 52 | 02-25-2011 01:23 AM |
| Contract question | MACEXCAVATING | Excavation & Site Work | 4 | 12-20-2008 09:24 PM |
| HVAC Licensing question | kdan | General Discussion | 2 | 08-25-2008 09:17 AM |
