Pex Colored Lines
Old 12-29-2008, 12:53 PM   #1
ARTSBEST's Avatar
Trade: LANDSCAPER
Pex Colored Lines
In Menards the PEX tubing comes in two colors, red/blue. Both have identical labeling info on them in terms of heat limitations, etc., etc.. The guy there couldn't answer my question, which is WHY two colors? I assumed they're for identifying cold vs hot. If so, is there any zoning violation if one uses one color for both hot/cold water? Thanks.
ARTSBEST is offline
Old 12-29-2008, 01:06 PM   #2
Tech Geek
WarriorWithWood's Avatar
Trade: Property Management/Facilities Manager
Re: Pex Colored Lines
Your assumption is correct.
No, they are the exact same thing except for colors. I had an inspector ask about the heat range when my plumber used all blue in a section after running out of the red, I showed him the heat range is the same no matter what color. He approved and we moved on.
-Dennis
www.bowmanch.com
WarriorWithWood is offline
Old 12-29-2008, 09:50 PM   #3
Pro Plumber
Ron The Plumber's Avatar
Trade: Plumber
The colored pipe is for those that don't recall what pipe was used for the hot and cold lines, means nothing else.
Ron The Plumber is offline
Old 12-29-2008, 09:59 PM   #4
mics_54's Avatar
Trade: contractor
Im still trying to find the purple pex for the outlet of my mixing valve!
mics_54 is offline
Old 12-30-2008, 03:42 PM   #5
JamesNLA's Avatar
Trade: Plumbing & Electrical
Well...I doubt you will find that. Purple is for reclaimed water. They do make spray paint
"....And then we all switch places when I ring the bell"
-Adrock
JamesNLA is offline
Old 01-10-2009, 02:36 PM   #6
ct plumber's Avatar
Trade: plumbing2heating
Stick with mowing lawns.
ct plumber is offline
Old 01-10-2009, 08:49 PM   #7
General Contracting
LNG24's Avatar
Trade: Real Estate Broker, Property Manager
OUCH!
A guy with 8 posts is Flaming a Guy with 12 posts
LNG24 is offline
Old 01-10-2009, 08:53 PM   #8
mdshunk's Avatar
I don't think your town's zoning board really cares what color your pipework is.
mdshunk is offline
Removing blue chalk lines? CaliDesigns Concrete & Paving 9 07-29-2010 12:33 AM
rolling paint lines rservices Painting & Finish Work 18 08-29-2008 06:45 PM
Hello from We Do lines We Do Lines Introductions 5 06-22-2008 09:19 PM
New Townhome purchase.. Figuring out boundary lines bujaly Decks & Fencing 19 05-21-2008 04:20 PM
Bonding Plastic Water/Gas Lines? jevorik Electrical 3 12-29-2006 12:24 AM
