Pex - Ceiling Or Under Floor
I've got a plumber wanting to run pex above instead of below in the crawlspace. How many of you guys would be comfortable running pex without home runs above vs. below in a very adequately spaced crawl space.
Thom
Re: Pex - Ceiling Or Under Floor
I build 2 story on slab-on-grade. I have the plumbers install the pex between floors. They are accustomed to running underground. Have no problems with it between floors and, in the event of a leak, it's easy to find and repair.
I am leary of installation in an attic space. You must be really vigalent in insuring it is completely within the heated space. The insulation must be on top of it. |
Plumber
Trade: Plumbing
I have done a lot of track homes, and in almost all of them I have ran the pex in the attic. There are a few problems with it,heat can be a problem I don't know how hot it gets out where you live but in the summer in CA the pex can get very hot and stay hot for a while. The only problem with going under your house is having rats or mice chewing on it, but if you d-con the rats you won't have that problem.
Plumber
Trade: Sewer Rat
Re: Pex - Ceiling Or Under Floor |
Plumber
Trade: Plumbing
I need an imprint of those teeth. CSI is on the way. Seen Pex chewed through in attics also. Dpending on where you are. I'd rather have a leaky pipe in crawlspace than attic2 to 1. Is the plumber lazy? More protection underneath...Now and in the future.
Strap it to the floor joists and move on! |
| Carpenter tells HO to install floor first | Frankawitz | Flooring | 12 | 03-02-2007 06:50 PM |
| Remodel - Floor sag | tmenting | Framing | 0 | 01-28-2007 06:56 PM |
| bouncy kitchen floor, will grout crack? | kmd | Ceramic & Stone Tile | 3 | 01-26-2007 10:23 PM |
| Help with clear coating a hardwood floor | pdiesel5 | Flooring | 5 | 11-03-2006 08:56 AM |
| Basement floor dilemma | ron schenker | Flooring | 11 | 07-02-2006 09:36 PM |
