PEX For Air Compressor Lines
Old 03-07-2013, 07:06 PM   #1
lifestooshort81's Avatar
Trade: Home Remodeler
Rewards Points: 75
Anyone know if I can safely use PEX for running compressed air lines in my shop? I know metal lines are better for the sake of condensation but I need to run a few lines in odd places that would just be a huge pain in the a$$. I refuse to use other plastic pipes for fear of explosion and plastic shards becoming shrapnel. I feel like PEX wouldn't have this issue as it's a real soft plastic and would just split.
I did a bit of research and I've seen quite a few people using pex just don't know what the pro's / con's are. I probably have enough copper to do what I want to do, I also don't feel like sweating the copper. I have to refill my acetylene tank and that's not going to happen for a few more weeks until there's money in the bank account. LOL
Thoughts? Opinions?
Thanks,
-Al C."Jack of All Trades" Stage 1 LLC Home Remodeling.
sometimes too inquisitive for my own good...
lifestooshort81 is offline
Old 03-07-2013, 07:14 PM   #2
tccoggs's Avatar
Rewards Points: 874
Re: PEX For Air Compressor Lines
There are kits that are specifically for this pupose:
http://www.rockler.com/product.cfm?p...FYdT4AodB0kAWA
Not sure I would use regular plumbing pex. You can probbaly get this stuff in bulk, most of your CNC equipment has some sort of plastic air lines on it with push style fittings.
tccoggs is offline
Old 03-07-2013, 09:17 PM   #3
rrk's Avatar
Rewards Points: 1,122
Use Rapid Air, http://rapidairproducts.com/
It's on my list of "to- do" this spring
rrk is offline
Old 03-07-2013, 09:27 PM   #4
tenon0774's Avatar
Trade: Remodeling Carpenter
Rewards Points: 2,270
Pressure Ratings for pex.
100psi at 180F
160psi at 74F
If you'll notice, these are far below the standard 300 psi ratings of a typical air hose.
Had a guy at the Gun Club ask me the same question. I'll tell you what I told him.
"I wouldn't do it."
-Scott
tenon0774 is offline
Old 03-07-2013, 10:08 PM   #5
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 10,668
I dunno about pex...why not use PVC?
Inner10 is offline
Old 03-07-2013, 10:12 PM   #6
rrk's Avatar
Pvc explodes under pressure
rrk is offline
Old 03-07-2013, 10:22 PM   #7
Inner10's Avatar
News flash son everything explodes under enough pressure.
Inner10 is offline
The Following 2 Users Say Thank You to Inner10 For This Useful Post:
SAW.co (03-08-2013), TimelessQuality (03-08-2013)
Old 03-07-2013, 10:58 PM   #8
BCConstruction's Avatar
Trade: Construction
Rewards Points: 2,394
Pex is fine. Dont use PVC as if it does crack it will send srapnal all over the place. It's a big no no and OSHA don't even allow it because it's so dangerous.
The rapidair line is cheap at about $50 for $100 foot.
www.bcconstructionllc.com
BCConstruction is offline
Old 03-08-2013, 07:59 AM   #9
rrk's Avatar
No S Sherlock
When it does explode at pressures that a normal compressor produces you will be picking long pvc shards out of everything.
rrk is offline
Old 03-08-2013, 08:36 AM   #10
Inner10's Avatar
I don't know the US rules but where does it not allow pvc?
What pex rated too? 150psi?
What's pvc sch 40 rated too 300psi?
Inner10 is offline
Old 03-08-2013, 08:38 AM   #11
Tom Struble's Avatar
Trade: siding
Rewards Points: 4
can you make a potato gun out of pex?
Tom Struble is offline
The Following 2 Users Say Thank You to Tom Struble For This Useful Post:
joethepainter (03-08-2013), TAHomeRepairs (03-08-2013)
Old 03-08-2013, 09:03 AM   #12
Trade: Construction
http://www.osha.gov/dts/hib/hib_data/hib19880520.html
Im sure it can handle the pressure just fine but i would hate to be around if it ruptured. I would def use something design for them pressure with air in mind.
The Following User Says Thank You to BCConstruction For This Useful Post:
Inner10 (03-08-2013)
Old 03-08-2013, 09:08 AM   #13
Trade: Construction
yes you can this is my mates one.
The Following 2 Users Say Thank You to BCConstruction For This Useful Post:
Tom Struble (03-08-2013), woodworkbykirk (03-08-2013)
Old 03-08-2013, 09:32 AM   #14
Trade: siding
Rewards Points: 4
GOD bless America!!
BCConstruction (03-08-2013)
Old 03-08-2013, 10:04 AM   #15
Inner10's Avatar
Damn new one on me!
But it mentions they allow types of ABS? I didn't even think ABS was pressure rated.
Inner10 is offline
Old 03-08-2013, 10:18 AM   #16
Trade: Construction
Damn new one on me!
Never looked ad ABS ratings but i think it is a little softer than the PVC so may not fracture like PVC.
Old 03-08-2013, 01:02 PM   #17
Rewards Points: 75
last I checked, abs is for drain/waste/venting only...and even if PVC is rated for pressure I wouldn't use it. I'll take my chances with standard plumbing pex before I used PVC. Albeit black iron is the best but I'm not cutting and tapping pipe for my air system. If anything I'd use copper. I don't see why pex wouldn't work. If it can handle water pressure why can't it handle air pressure? I'm trying to do this on a very economical level. Even if I went copper, I have miles of pipe and fitting I just don't want to deal with sweating all the fittings or buying shark bites.
I'll try pex in a trial run and see what happens!
Old 03-08-2013, 05:07 PM   #18
Inner10's Avatar
You would take your chances with something not rated for use in your application what so ever before using something rated at over 3x the operating pressure you require? If you feel it's unsafe use sch80 or 120.
Inner10 is offline
Old 03-08-2013, 07:18 PM   #19
Future Post Deleter...
rex's Avatar
Trade: Nothing
Rewards Points: 1,092
Run it in black pipe.
rex is offline
The Following User Says Thank You to rex For This Useful Post:
tenon0774 (03-09-2013)
Old 03-09-2013, 12:06 AM   #20
tenon0774's Avatar
FINALLY!
A plumber speaks up.
Thanks Rex.
-Scott
Made in USA product list J.C. General Discussion 344 12-24-2017 11:54 AM
what's fair is fair maxv65 Online Leads Services 1 07-29-2010 09:58 AM
