Trade: Painter
Painting Guy Here...need Opinion Of A Plumber...
This is a personal problem I'm having at my home. I'm about to strangle my water provider.
Townhouse community, use to be on a community water bill or whatever you want to call it, now each unit has it's own individual meter. 1,200 sq place, just me and my wife. Water bill and sewer normally $50-60. The first month of the new meter, my bill is $160. WTF? The water company tells me we used 4,000 gallons of water. They arrive at that number by measuring hotwater usage, then using some multiple for cold water to arrive at total water used. I'm like this is bull****, obviously, so I have a plumber come out. He says the meter is connected to the coldwater line, so he's not sure how in the hell they measure the hot water. He says there is absolutely no leak. So I call them back and they say they know its hooked up to the coldwater and they can read it correctly that way. Again....WTF? Is there any way me and my wife use 4,000 gallons of water? We don't even use hot water for clothes, only showers and dishes. I'm not sure what to do. The water company basically says, "yeah, that seems really high, but tough ****." Now I've had to pay for a plumber to come out, and I'm still at the same spot I was before. Help!!!!! |
Re: Painting Guy Here...need Opinion Of A Plumber...
Do you have individual heaters, one per unit?
Trade: Painter
We have a unit in our townhouse....is that what you're asking?
Pro Plumber
Trade: Plumber
Sorry but there is no way one can decide who much hot water gets used, one only can tell how much water is used all together.
#5 | |
Trade: Painter
Re: Painting Guy Here...need Opinion Of A Plumber...Quote:
Sure enough I come home, crank on the cold water and the meter runs like hell. these people are killing me! |
Pro Plumber
Trade: Plumber
Tell them to come out and show you how they caculate the charges.
Unless something has drastically changed, they have no way of determining your HOT water consumption. You pay for your hot water through the elec. or gas bill. They are only measuring the total flow through your unit. You could have a bad meter but usually that works in your favor, they are slow or stop.
Keep in touch, I want to hear how this ends.
Trade: Plumbing and heating
So if you consider you each work out of the house. You each shower for 10 min a day,
use the toilet a least 4 times each while at home. You also do 4 loads of laundry a week and cook 1 meal at home and clean your dishes. 2 people 1 shower each for 10 mins = 50 gal a day X 30 days = 1500 gals. 2 people wc usage 4 times a day = 12.8 gals a day x 30 days = 384 gals. laundry for 2 say 4 loads a week = 140 gals a week x 4 weeks = 560 gals. Dishes and meal prep. 10 gals. a day = x 30 days = 300 gals. Total = 2444 gals This is an educated guess, I would say you probably use closer to 3000 a month actually |
#9 | |
Trade: Plumbing
One thing you may want to check is the toilets. Make sure they're not leaking by at the flappers...sometimes it isn't always easy to tell. If you look in the bowl, you may see a little rippling at the edges. If so, the flapper should be replaced. It's amazing how much that will run up a water bill. |
Trade: Plumbing
Almost forgot...it could also be the ballcock or fill valve in the tank. If it doesn't properly shut off, the water will just keep running and draining down the overflow tube. That's actually what would cause the rippling at the water's edge in the bowl.
Pro Plumber
Trade: Plumber
Just shut the water off to the toilet/s before you go to sleep, in morning, left the tank lids, if water is low in them them suspect water leaking from tanks into the bowls.
Plumber
Trade: Plumbing
the only way it can be read on the hot side is if they installed a meter there, 1, another thing you may want to check see if the sprinkler system is feed off that meter ,2, also maybe their billing your depoist into that figure, 3,shut off all your faucets in the house and go to your meter and see if the dial is turning, if it is you have a leak somewheres .
#13 | |
Trade: Painter
But, I guess the issues with the toilet would not be a steady leak that could be easily seen on the meter. I'll have to check for that. Then again, the morons I keep getting on the phone are saying it only measures hot water........???????? I'll speak to them again today and let everyone know what they say this time. |
Trade: Painter
Just got off the phone with the guy......he said the meter SHOULD NOT be running when I turn the cold water on. They're going to have someone come out to my house now.
I don't know how the hell this stuff works, but at least I've now got them thinking something in fact may be wrong. I had never heard of this "new" type meter. Maybe this is common, but the thing is inside my house and the water company just drives by my house a shoot a "gun" that reads the meter. When they first hooked it up, I wonder how in the heck they were going to read it. Technology. If I was a guy who checks meters every month, I'd be nervous. It won't be long before its all computer automated and the meter reading just gets transmitted back to headquarters......no one having to go by and read it each month. |
#15 | |
Trade: Fire Suppression Equipment Sales & Service
On meter reading, Cascade Gas reads meters electronically, the meter reader drives down the street and a device in the cab reads the meter. No more going into yarrds and alleys to read meters.
The power company has installed meters in the rural areas that read the meters and sends the information over the high voltage lines to a computer in the office. It is very slow, but faster than going out to the outlying areas. The cost, about $40.00 for the special meter. Previously, there were meter that were not read for several months in the winter time. fireguy |
#17 | |
Plumber
Trade: Plumbing
#18 |
Trade: Painter
thanks for your help guys. It probably is all BS, I have no idea, I'm just glad they've agreed to come look at it and that they've acknowledge something isn't right.
#19 | |
Plumber
Trade: Plumbing
I'm glad you got your point across over to them, I'm still interested as to what they find ,let us know if you dont mind . You can do us all a favor if you would please ,ask them what size water heater they have at their plant to heat the water for the town ,lol |
#20 |
Custom Builder
If water companies would had been in place during the exodus ......Moses would have been broke on the other side.
Bob |
| How profitable is your painting business? | SeanATL | Painting & Finish Work | 13 | 04-21-2007 11:16 PM |
| I need advice from a earnest plumber | AbeBarker | Plumbing | 2 | 02-02-2007 06:01 PM |
| I need work in south fl (PAINTING) | ADMG32 | Help Wanted or Looking For Work | 2 | 11-07-2006 12:15 PM |
| Painting as part of your estimate | Mike Finley | Remodeling | 20 | 05-21-2006 11:25 PM |
| Pricing for painting HELP!! | Keefer | Painting & Finish Work | 9 | 03-16-2006 11:46 AM |
