P Trap Placement
Old 09-28-2007, 08:58 PM   #1
Jesse Benson's Avatar
Trade: Handyman
P Trap Placement
My dad has some issues with smell in his bathroom. The P traps are downstream quite a ways from the shower and sink and that is what he thinks is causing the problems. Neither of us are plumbers or claim to be but he would like to get an idea of what the problem could be as he has already had one plumber out and the problem still persists. Any ideas? Would moving the traps closer even make a difference. Thank you for any help.
Jesse
Jesse Benson is offline
Old 09-28-2007, 09:13 PM   #2
David Davis
shed-n-deck's Avatar
Trade: ? No thanks, I like mine better!
Re: P Trap Placement
Try replacing the wax ring on your toilet. I would suggest that you have P-traps installed at the fixture. I don't know that it would make any difference, but, it seems a bit odd that they would be installed a distance away from the fixtures. I'm not a plumber either.
Shed
shed-n-deck is offline
Old 09-28-2007, 09:14 PM   #3
Teetorbilt's Avatar
That could easily do it! Bacteria builds in the standing water that is left in the pipes ahead of the trap(s). Rather than re-plumb, try a healthy dose of bleach (2 cups) every time it starts to smell. Run the water at about 1/3 of normal, add the bleach and then turn off the water for about five min., next go full flow to flush out all of the chlorine.
Albert Einstein
Teetorbilt is offline
Old 09-28-2007, 09:29 PM   #4
The Grand Wazoo
KillerToiletSpider's Avatar
The only standing water is in the trap itself, and any odor would vacate on the vent side of the trap, away from the room.
KillerToiletSpider is online now
Old 09-28-2007, 09:51 PM   #5
Plumber / Carpenter
Bill's Avatar
Trade: Virginia Building and plumbing contractor
Send a message via Yahoo to Bill
I would check the shower drain, there may not be a trap on it. I remodeled a bathroom at a house once owned by a man who worked for Home Depot, he installed the shower drain with no trap at all and could not figure out why he always had a smell.
Is it beer thirty yet
Virginia Department of Licensing
Virginia Plumbing Codes
Bill is offline
Old 09-29-2007, 09:50 AM   #6
Grumpyplumber's Avatar
Trade: Plumber
Another common source of odor, the overflow space inside lav basins.
Try cleaning it out with some bleach if none of the above works.
Grumpyplumber is offline
Old 09-29-2007, 11:51 AM   #7
Plumber / Carpenter
Bill's Avatar
I tell you what else may cause it is improper venting. Toilet may be sucking water out the traps too
Bill is offline
Old 09-29-2007, 01:21 PM   #8
Sounds like do-it-yer-self-ers may have been involved here. I did a gut redo, couldn't understand how they lived with the smell. Turned out the whole bath was vented thru a jambed up 20+ yr old stutter(sp) vent behind the drawer stack in the vanity. Sometimes stuff you'd never dream of in your worst nightmares.
neolitic is offline
Arrgh, nice footing placement, eh? BuiltByMAC Carpentry 31 09-15-2007 08:56 PM
Coil height for condensate drain trap davidchomes HVAC 10 09-10-2007 10:36 PM
Master Bedroom Placement ridgeline_dev Remodeling 4 05-09-2006 08:44 AM
FEEDBACK: New Ad Placement Testing Nathan General Discussion 13 05-08-2006 10:57 AM
Dumb trap Davidw53 Plumbing 2 02-16-2004 08:40 PM
