Trade: Roofing
P Trap
I'm replacing my bathroom petalstool sink. I removed the sink from the wall and water lines. I left part of the "P" trap in place (the down spout). My wife ran the washer machine and water came out when the washer went to it's rinse cycle. Is this normal? Should I have left the the "P" trap on?
My home is on a slab and the washer is on the same floor. |
Remodeler Extraordinare
Re: P Trap
Sounds like you may have some kind of venting issue in your plumbing, or maybe a clog.
The pee trap is designed to keep noxious waste gasses from entering the house.
A.W. Davis Construction Co. http://www.awdavisconstruction.com/ Your friendly remodeling contractor Last edited by A.W.Davis; 03-30-2008 at 09:15 AM. |
Trade: Handyman Services
Re: P Trap
You say the washer is on the same floor....is it also backed up to this bathroom or close?? It may be on the same stack as the bathroom, which, by all rights shouldn't matter, but for some reason it may be flowing through the wye, and coming out in the bathroom. Probably wasn't noticable before with everything hooked up because the drain elevation was higher than the wye, now it's not. Seems you would have noticed some gurgling and such tho, in the bathroom sink, when the washer was draining...... may have some debris buildup in the drain below the wye........but i would wait for the real plumbers to chime in....i'm just doing my own process of elimination here, giving you things to think towards...
Trade: Roofing Contractor
Re: P Trap
Thanks for posting on ContractorTalk.com. The Moderators of this forum would prefer if you post Do It Yourself related topics on our sister site www.DIYChatroom.com
ContractorTalk.com is designed for professional contractor's to discuss issues and topics related to the construction and remodeling industries. Many of our professional contractors are also members at DIYChatroom.com and are looking forward to assist you with your needs. Please take a moment to post your question at www.DIYChatroom.com If your not already a member of DIYChatroom.com you can sign up for a free account by going to http://www.diychatroom.com/register.php/ We apologize for any inconvenience that this may have caused. This thread has been closed. |
| Eternal Trap? | neolitic | Plumbing | 6 | 02-24-2008 03:36 PM |
| Help-sand Trap Slow Drain | PARA1 | Plumbing | 2 | 12-31-2007 08:53 PM |
| P trap placement | Jesse Benson | Plumbing | 7 | 09-29-2007 01:21 PM |
| Coil height for condensate drain trap | davidchomes | HVAC | 10 | 09-10-2007 10:36 PM |
| Dumb trap | Davidw53 | Plumbing | 2 | 02-16-2004 08:40 PM |
