Overzealous Inspector
Old 01-11-2018, 03:07 PM   #1
3 Jacks 2 Nines
bwiab's Avatar
Trade: Wannabe Homebuilder
Rewards Points: 166
Building under 2015 code and thought this dude was a bit off when he made us fill the waste lines all the way to the top of the vents under test to pass rough.
Had a list 7 items long at 1st correction notice to final. Building a single family home by the way. Plumber made all corrections and recalled inspection. Have a second list of corrections including appliances must be installed to final plumbing. Seems rediculous to me and am mulling making a stink over this but don't want to ruin good will with other inspectors. Anyone see appliance installation as a requirement to final plumbing?
bwiab is offline
Old 01-11-2018, 03:13 PM   #2
TimNJ's Avatar
Rewards Points: 2,242
Re: Overzealous Inspector
I can see for gas appliances.
TimNJ is offline
Old 01-11-2018, 03:16 PM   #3
Goin' Down in Flames....
Seven-Delta-FortyOne's Avatar
Trade: Builder/GC
Rewards Points: 1,860
Top of vents is standard here, unless you can build 10 feet of head above your last fitting.
Never heard of appliances having to be installed. That's a weird one. What kind of appliances? Like stove and oven?
Delta
I have an Edifice Complex.
The Following 2 Users Say Thank You to Seven-Delta-FortyOne For This Useful Post:
greg24k (01-11-2018), Tom M (01-11-2018)
Old 01-11-2018, 04:15 PM   #4
kirkdc's Avatar
Trade: Remodeling (mostly kitch/bath)
Rewards Points: 2,684
yep, fill to tops of vents standard in my part of Colorado.
And "ALL" apppliances need to be installed and functional before CO is issued. And I'm in the friggin boonies.
They just outlawed double and single wides set on piers too.
kirkdc is offline
The Following User Says Thank You to kirkdc For This Useful Post:
Old 01-11-2018, 04:19 PM   #5
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 1,132
We don't fill them, just plug them and charge with air pressure that has to hold for 15 minutes. We can use water, but I've never seen anyone do it.
I've never had to have appliances installed for final.
Tinstaafl is offline
The Following 3 Users Say Thank You to Tinstaafl For This Useful Post:
dayexco (01-12-2018), Joasis (01-12-2018), overanalyze (01-12-2018)
Old 01-11-2018, 04:31 PM   #6
kirkdc's Avatar
water fill and pressurize tests are required as well. $$$$$
kirkdc is offline
Old 01-11-2018, 04:40 PM   #7
John the Builder
SmallTownGuy's Avatar
Trade: Carpenter/Builder
Rewards Points: 8,116
How the hell do they get that from builders who sell new homes without appliances?
"Your talent is God's gift to you. What you do with it is your gift back to God." - Leo Buscaglia
SmallTownGuy is online now
The Following 2 Users Say Thank You to SmallTownGuy For This Useful Post:
rselectric1 (01-11-2018), Seven-Delta-FortyOne (01-11-2018)
Old 01-11-2018, 05:14 PM   #8
Randy Bush's Avatar
Trade: Exterior Remodeling
Air test here , would have frozen pipes otherwise.
Randy Bush is offline
The Following User Says Thank You to Randy Bush For This Useful Post:
Old 01-11-2018, 05:24 PM   #9
kirkdc's Avatar
Good question. I'll have to ask my GC friend...or ask one of the inspectors when I see one. We seem to be getting Californicated here in CO as of late. Not that long ago you could build a new home with scribbled drawings on a restaurant napkin, show it to the county boobs and they'd OK it.
They just outlawed tiny homes too. This is a region with wide open spaces..lots of people with 20-100 acres. Big area, small populace and yet the bull****e keeps getting deeper.
kirkdc is offline
SmallTownGuy (01-11-2018)
Old 01-11-2018, 05:41 PM   #10
Big Johnson's Avatar
Trade: Contractor and Grunt
Rewards Points: 1,593
Washer and dryer too?
Thatís all going to add up to big money.
Here they just do the dishwasher.
Big Johnson is offline
Old 01-11-2018, 05:43 PM   #11
Iíd go to the appliance place and try to buy scrapped out ones. PITA but better than spending $3K+
Old 01-11-2018, 05:43 PM   #12
Why?
Old 01-11-2018, 05:50 PM   #13
kirkdc's Avatar
I just did a new home Monday, dishwasher, micro, stove/oven, washer dryer and fridge. GC told me if was a must for the CO. This was in Park County in CO.
kirkdc is offline
Big Johnson (01-11-2018)
Old 01-11-2018, 05:58 PM   #14
XJCraver's Avatar
Trade: Building Official
Rewards Points: 156
We ask that "installed" appliances, like dishwashers, be in for a final. Portable, movable, not "installed" appliances don't have to be there.
On the plumbing look at the 2015 IPC, section 312.2 10-foot head of water or filled to the highest point.
XJCraver is offline
The Following User Says Thank You to XJCraver For This Useful Post:
Old 01-11-2018, 06:18 PM   #15
General Contractor
greg24k's Avatar
Rewards Points: 7,088
Like others said we always fill them like that, as a matter a fact in the summer or weather permitting they go on the roof with the hose and fill it up.
As the appliances go, yes they check appliance installation since they came out with a tip-over prevention bracket to make sure the stove is secured so usually they will only check that and now they check the hood-vents to make sure they don't require make-up air.
greg24k is offline
rrk (01-11-2018)
Old 01-11-2018, 06:23 PM   #16
The Sheriff
Jaws's Avatar
Rewards Points: 2,894
Id raise hell about washer and dryer if it was a spec especially. Maybe the people like laundry mats or dry cleaning...
Had one inspector say he wanted appliances and I told him the situation which was that the client bought the appliances through Best Buy or somewhere instead of my vendor and I was not installing them. I said that the co would have to be taken care of later and he was cool and issued it that day. In reality I would have put the appliances in if it was not going to allow them to get a CO. Just more government over-reaching.
Always to the top of vents here
"The sound of the saftey clicking off is the only warning your gonna get......., so cover your ears" Northeast Wyoming 2016
John
Jaws is offline
The Following User Says Thank You to Jaws For This Useful Post:
kirkdc (01-11-2018)
Old 01-11-2018, 06:36 PM   #17
John the Builder
No used crap is ever gong to go in one of my new homes.
Show me where its in the book, and I'll comply.
Hell, I put new appliances in a 700/month rental.
But: No one's pulled that on me here in Oakland or Lapeer Counties.
Typical read of a C of O doc: "All appliances must be installed properly and be in proper working order."
That does NOT mean "all appliances must be installed." No, no, no.
The Following User Says Thank You to SmallTownGuy For This Useful Post:
kirkdc (01-11-2018)
Old 01-11-2018, 06:51 PM   #18
kirkdc's Avatar
Interesting.
I wonder if someone was pulling my leg. I'm calling the County tomorrow.
kirkdc is offline
Old 01-11-2018, 07:13 PM   #19
edward trowelhands
Golden view's Avatar
Trade: Diplomat
Rewards Points: 3,908
D/W makes sense. There's a water and electric connection - safety and water damage reason. Gas stove makes sense. 75% of them I pull out are hooked up wrong. Pipe dope on the fitting. Washer/dryer makes no sense. Visible hose connection and an electric plug.
Fill vents through the roof here. More of a pain on remodels where it means we have to install a test ball fitting to isolate the new.
Golden view is offline
Tom M (01-11-2018)
Old 01-11-2018, 07:18 PM   #20
John the Builder
Interesting.
In Colorado, there is no state adopted, overarching building code. That means individual jurisdictions can write whatever they want.
However - its not what some official "thinks" is the way he wants to run his little dictatorship. Whatever code there is, has to be voted on and adopted by the local municipality - be it county, unincorporated township, Village, city, etc.
And for that to be voted on - this body of rules and standards - it has to be in writing.
"In Colorado there is no compulsory statewide building code. Each jurisdiction in Colorado decides which code they want to adopt but it has to be at least the 2003 IECC."
New home inspector in upstate New York Apizur Introductions 7 02-19-2013 09:40 AM
Becoming a building inspector Michaeljp86 General Discussion 16 02-17-2012 06:31 AM
Inspector!! fireguy General Discussion 4 04-23-2011 02:58 PM
Building inspector wth??? insane Masonry 26 07-21-2010 12:33 AM
Hail inspector Mike Finley General Discussion 11 08-07-2009 07:27 PM
