One For Well System Pro's.
Old 12-16-2006, 12:57 AM   #1
Teetorbilt's Avatar
My diaphram pressure tank keeps losing pressure. I serviced it about two days ago when the pump started short cycling and it doing it again.
Then, I pulled the Schrader valve, under pressure, to check for a broken diaphram, not a hint of moisture. I pumped up the air to 28, the switch is set for 30. I then spent 30 mins pouring a gal. of dishsoap/water over the entire tank, no bubbles anywhere.
Could it be that the diaphram has become semi-permiable?
That's a lot of air in only two days.
Albert Einstein
Teetorbilt is offline
Old 12-16-2006, 01:06 AM   #2
mdshunk's Avatar
Re: One For Well System Pro's.
Could your schraeder core be leaking? That's a popular place for a/c systems to leak.
mdshunk is offline
Old 12-16-2006, 01:27 AM   #3
Teetorbilt's Avatar
That was my first thought. I filled the stem with soapy water and nary a bubble in 1/2 hr. Same with the base of the stem and all tank welds.
Albert Einstein
Old 12-16-2006, 06:18 AM   #4
gitnerdun's Avatar
Trade: plumber
The air is probably leaking out of the diaphram into the water. I've seen it before where the bladder has no water in it, but is still bad. New tank time.
gitnerdun is offline
Old 12-17-2006, 11:03 PM   #5
plumber jay's Avatar
Trade: plumbing
Correct me if i am wrong but a diaphram tank will work just fine with the diaphram split. Just for a short time. But way more than two days.(months)then you just have to unwaterlog it. the air will still be trapped in the tank giving you expansion cushion. All the old tanks allthough larger do not have diaphrams.
The bladder is what has the water in it and the air is outside the bladder.
plumber jay is offline
Old 12-18-2006, 12:17 AM   #6
K2's Avatar
I agree. I've had non-bladder p tanks and they worked fine most of the time.
K2 is offline
Living Filter Septic System jmic Excavation & Site Work 18 07-20-2007 09:31 PM
Systems Development List Gordo Business 19 01-08-2007 07:28 PM
forced hot-water system daniem1 HVAC 1 03-02-2006 05:37 AM
Hydronic hot air system, help??? GMAN_2006 HVAC 1 02-27-2006 05:17 PM
Question about shower system... Knyte260 Plumbing 59 10-24-2005 06:05 PM
