Trade: Carpenter/Mechanic
Old And Now New Water Heater Leaks From Pressure Relief Valve
Hey guys
Figured i was ask you official plumbers a question about something thats been bugging me. my old water heater was discharging from the relief valve ever since i bought the house(less than a year ago) then it finally crapped out on me(tank leak, nothing major though) so i replaced it with a new one, the new one discharges out of the relief valve also it seems whenever the tank is filling up, is this just cause of the water expanding when being heated or to much pressure coming in? There is a black knob type of unit about 3 feet up on the first 90 coming down into the water heater, i thought that was the pressure regulator or whatnot. Any help appreciated.. (PS , its not like the water is pooring out, i have a 5 gallon bucket and it needs to be emptied montly it seems) |
The Grand Wazoo
Re: Old And Now New Water Heater Leaks From Pressure Relief Valve
Install an expansion tank on the cold inlet of the water heater and your problem will disappear.
Since the advent of backflow preventers this is fairly common. Adding on an expansion tank should solve the problem. See here http://www.nextag.com/water-heater-e...nk/search-html
Plumber / Carpenter
I agree with KillerToilet and teetorbilt. What happens is when a back flow valve or check valve is installed the pressure from the heating water in your tank expands and has no where to go exept out the T&P. Installing the expansion tank will remedy this problem as it gives the expanding water somewhere to go.
#5 | |
Trade: hjrafiuoashfed
Re: Old And Now New Water Heater Leaks From Pressure Relief ValveQuote:
Call a licensed plumber...like right now. |
Pro Plumber
Trade: Plumber
FYI
Just installing a expansion may not solve your problem, you have to know how they work, knowledge about residual pressure and static pressure play a key role on the proper installation of this tank, I won't get into what it's all about since this is not a DIY site. |
Trade: Plumbing & Electrical
I was going to say the same thing as Ron...An expansion tank WILL NOT solve the problem unless one knows if there is even a BF preventer or a check installed. Check the pressure but first call a plumber who knows what they are doing...
"....And then we all switch places when I ring the bell" -Adrock
Celtic's #1 Fan
Trade: electrical
Re: Old And Now New Water Heater Leaks From Pressure Relief Valve |
Hey, I fixed your post as we all know that a electrician wouldn't be foolish enough to insult his betters.
I was going to flame the op, but sometimes ya gotta wonder if a post is serious (like I know you weren't) and a flippant answer may cause bodily harm. |
Moderator
No, but the second day of plumbing school we're all issued a list of sparky's to call that do know, so we're covered.
![]() The fact that someone put a regulator at the water heater is the second clue that something is not right with the pressure in this home. The leaking T&P is a symptom, not the problem. Installing an expansion tank may make the symptom go away, but it might not fix the problem. There is more going on here than you're seeing and its time to let a competent plumber take a look and see what has been done and why, and how to best correct it. Now, its possible that 'black know thingie 'coming' down into the water heater might be a tempering valve and not a regulator. Again, this is why a competent plumber should take a look (preferable one that has Mahlere on speed dial
Oh look at that...how cute.....She's trying to grow a pair. It really is fun to watch. Good luck with that growing up thing. We all know your a bit challanged
Thanks for the info, My buddy has been a plumber for about 25 years but have not had him over to check it out yet. He pretty much said the same thing as all of you.
This only happens AFTER the tank has been run down a bit, like after a shower or two. |
my thinggy leaks....a few times a week if things go well.
#15 | |
Celtic's #1 Fan
Trade: electrical
my point was this thread has several presumably well versed plumbers (and a couple of questionable characters) who can't agree on what the problem is or how to fix it... |
#16 | |
No I need another 300 hrs to be eligible for my Journy card. I've been crazy busy. I have all but given up on my GC. Too tired to study too busy to need it. ...and yes there are some characters on this forum. Adds to the dynamic and laughter from what some people come up with!
#17 | |
Moderator
Shockwave, did you get this problem addressed?
