OD Of Copper Pipe Larger Than 5/8" - Plumbing - Contractor Talk
Old 02-23-2018, 02:47 PM   #1
bcook19791's Avatar
Trade: Carpentry/Remodeling
Rewards Points: 186
I have a situation where a piece of rigid copper stubbed out for the toilet looks like 1/2 copper which should have a OD of 5/8, is about 50 thousands of an inch bigger. Copper fittings and compression valves will not slide on. It has not to my knowledge ever frozen. Has anyone ever encountered this? If so what did you do. I am hoping I don't have to open up the wall but....
bcook19791 is offline
Old 02-23-2018, 02:54 PM   #2
Mordekyle's Avatar
Rewards Points: 3,762
Re: OD Of Copper Pipe Larger Than 5/8"
Shark bite?
Mordekyle is offline
Old 02-23-2018, 06:50 PM   #3
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 13,728
Swage a pipe to fit over it.
Inner10 is online now
Old 02-24-2018, 01:23 AM   #4
Designer/Contractor
Rio's Avatar
Rewards Points: 2,666
Copper's soft, why can't you just work it with the sanding tape until you can slide another copper fitting over it, flux and solder?
Rio is online now
Old 02-24-2018, 07:10 AM   #5
MarkJames's Avatar
Trade: Handyman Services
Rewards Points: 14,023
How did you trim it, or remove the caps? Maybe it's slightly out of round.
Maybe a touch to heat to your fitting ring and ferrule will expand it just about .050
MarkJames is online now
Old 02-24-2018, 07:28 AM   #6
rrk's Avatar
Rewards Points: 2,782
Heating would expand it , he needs it to fit inside the fitting. My plumber just recuts the pipe 1/2" away and it can be pushed on, said cause was either from cheap pipe or cheap fitting. He has also cut it back installed a coupler/small section/valve. The couplers sometimes will fit where a valve will not.
But we never had one that would not go on and we had to open the wall.
rrk is offline
Old 02-25-2018, 07:52 AM   #7
builditguy's Avatar
Rewards Points: 428
My money is on freezing. Usually have to keep cutting it back until we find an area that wasn't frozen.
Shark bite is a good idea. I would try that first.
builditguy is offline
Old 02-25-2018, 08:27 AM   #8
Inner10's Avatar
Originally Posted by Mordekyle View Post
Shark bite?
Don't sharkbites seal with an O-ring on the OD of the pipe and rely on the fact that plumbing pipes are all the same OD. I don't think it's a good idea....but fill your boots.
Old 02-25-2018, 11:20 AM   #9
LRG WoodCrafting
Leo G's Avatar
Trade: Maker of Fine Sawdust
Rewards Points: 5,433
50 thou is almost 1/16". Something happened to that pipe to stretch it out.
Sawdust Follows Me Everywhere
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is online now
Old 02-26-2018, 02:08 PM   #10
bcook19791's Avatar
Rewards Points: 186
Its a crazy situation. All the pipe that I can get to in the house all mics the same OD. I ended up heating up the old valve to remove it from the pipe and cleaned it up and reattached the valve body replacing the insides. Old gate shut off valve was leaking around the handle.
The Following User Says Thank You to bcook19791 For This Useful Post:
ScipioAfricanus (02-26-2018)
Old 02-26-2018, 07:21 PM   #11
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 2,655
It's ACR (Air Conditioning and Refrigeration) pipe; one of the standard sizes is 5/8". Unlike water plumbing pipes, ACR is sized by its OD, not the ID.
I actually ran into that in my house this winter with a frozen/leaking line I tried to cut and cap (in a location not subject to freezing). Since I plan to replace all of the piping in that area soon, I just crimped and soldered it for the time being.
I've since talked to a couple of different guys who've run into that on rare occasions. I assume adapters are available, but haven't looked into it. I'd probably start with a HVAC supply house.
Tinstaafl is online now
Old 02-26-2018, 07:30 PM   #12
Fugetaboutit
Lunicy's Avatar
Trade: Professional fixer upper
Rewards Points: 422
Probably a bit late now, but are you sure it isn't the decorative sleeve they put over the copper?
Alot of older houses I work in have this.
https://www.google.com/imgres?imgurl...act=mrc&uact=8
Lunicy is offline
Barn Water Heater - line frozen artinall Plumbing 16 01-23-2013 09:51 PM
Who needs fuses when you have copper pipe? Static Design Electrical Picture Post 26 08-20-2010 05:31 AM
Copper Vent Pipe Boots tkvandy Roofing 7 08-05-2009 03:21 PM
Kitec attached directly to copper pipe? No fittings A.D. Const Plumbing 29 03-31-2009 07:26 AM
Cement Contact with Copper Pipe Capt2 Plumbing 11 04-17-2007 08:05 PM
